Results 1 to 4 of 4
Thread: How to recondition Victa 2-stroke lawnmower plastic carburettor
    2JZ EL Fairmont tandy ass's Avatar
    1,406
    1) Remove carb by twisting anticlockwise 25 degrees then pulling from motor. Unplug all hoses.
    2) Disassemble carby and clean it.
    3) Reassemble and away you go.
    There are like 10 parts in the whole carby, it's super-simple. I setup a large clean bench expecting 30-60 parts all to be taken apart in order, cleaned and reassembled carefully. Whole job took an hour. There are two springs in it, both under the rear of the carby (where the air intake and throttle cable goes) and the small one goes under the diaphram and the big one goes above the diaphram. In case you can't figure that out
    Hope this encourages someone to do it rather than paying a shop to do it...
    Quote Originally Posted by paul05
    don't waste your time asking questions about real cars on the rice forum go to ls1 .com ,it's alot more accommodating and informative than pf.
    WTB in Melb - Ford AU 6 cyl engine - needs to be in good condition
    Can't Touch this oldenholden64's Avatar
    2,323
    was about ot say.. if someone was asking how to do it i was gonna slap them... could do it upside down underwater with only 1 arm..hmm sounds like somethin to try actually
    Central Coast - NSW
    3,152
    Its called a G4 carby, i used to be a lawnmower mech years and years ago
    3,908
    I hated the thing so much, I replaced it with a slide carby.
