Results 1 to 17 of 17
Thread: Some great suspension tuning info- Thanks Carroll Smith RIP
    12,590
    CARROLL SMITH’S CAUSE AND EFFECT GUIDE
    RIDE AND ROLL RESISTANCE-SPRING
    Too much spring: overall
    • Harsh and choppy ride
    • Much unprovoked sliding
    • Car will not put power down on corner exit – excessive wheel-spin
    Relatively too much spring: front
    • Understeer – although the car may initially point in well
    • Front breaks loose over bumps in corners
    • Front tyres lock while braking over bumps
    Relatively too much spring: rear
    • Oversteer immediately on application of power
    • Excessive wheel-spin
    Too little spring: overall
    • Car contacts the track a lot
    • Floating ride with excess vertical chassis movement, pitch and roll
    • Sloppy and inconsistent response
    • Car slow to take a set – may take more than one
    Relatively too little spring: rear
    • Excessive squat on acceleration accompanied by excessive rear negative camber, leading to oversteer and poor power down characteristics
    • Tendency to fall over on outside rear tyre and ‘flop’ into oversteer and wheel-spin
    ANTI-ROLL BARS
    Too much anti-roll bar: overall
    • Car will be very sudden in response and will have little feel
    • Car will tend to slide or skate rather than taking a set – especially in slow and medium speed corners
    • Car may dart over one wheel or diagonal bumps
    Relatively too much anti-roll bar: front
    • Corner entry understeer which usually becomes progressively worse as the driver tries to tighten the corner radius.
    Relatively too much anti-roll bar: rear
    • If the imbalance is extreme can cause corner entry oversteer
    • Corner exit oversteer. Car won’t put down power but goes directly to oversteer due to inside wheel-spin
    • Excessive sliding on corner exit
    • Car has a violent reaction to major bumps and may be upset by ‘FIA’ kerbs
    Too little anti-roll bar: overall
    • Car is lazy in response, generally sloppy
    • Car is reluctant to change direction in chicane and esses
    Relatively too little anti-roll bar: front
    • Car ‘falls over’ onto outside tyre on corner entry and then washes out into understeer
    • Car is lazy in direction changes
    Relatively too little anti-roll: rear
    • My own opinion is that on most road courses a rear anti-roll bar is a bad thing. Anti-roll bars transfer lateral load from the unladen tyre to the laden tyre – exactly what we don’t want at the rear. I would much rather use enough spring to support the rear of the car. The exception comes when there are ‘washboard ripples’ at corner exits, as on street circuits and poorly paved road circuits.
    SHOCK ABSORBER FORCES
    Too much shock: overall
    • A very sudden car with harsh ride qualities, much sliding and wheel patter
    • Car will not absorb road surface irregularities but crashes over them
    Too much rebound force
    • Wheels do not return quickly to road surface after displacement. Inside wheel in a corner may be pulled off the road by the damper while still loaded
    • Car may ‘jack down’ over bumps or in long corners causing a loss of tyre compliance. Car does not power down well at exit of corners when road surface is not extremely smooth
    Too much bump force: general
    • Harsh reaction to road surface irregularities.
    • Car slides rather than sticking
    • Car doesn’t put power down well - driving wheels hop.
    Too much low piston speed bump force
    • Car’s reaction to steering input too sudden
    • Car’s reaction to lateral and longitudinal load transfer too harsh
    Too much high piston speed bump force
    • Car’s reaction to minor road surface irregularities too harsh – tyres hop over ‘chatter bumps’ and ripples in braking areas and corner exits.
    Too little shock: overall
    • Car floats a lot (the Cadillac ride syndrome) and oscillates after bumps
    • Car dives and squats a lot
    • Car rolls quickly in response to lateral acceleration and may tend to ‘fall over’ onto the outside front tyre during corner entry and outside rear tyre on corner exit.
    • Car is generally sloppy and unresponsive
    Too little rebound force: overall
    • Car floats – oscillates after bumps (the Cadillac ride syndrome)
    Too little bump force: overall
    • Initial turn in reaction soft and sloppy
    • Excessive and quick roll, dive and squat
    Too little low piston speed bump force
    • Car is generally imprecise and sloppy in response to lateral (and, to a lesser extent longitudinal) accelerations and to driver steering inputs
    Too little high piston speed bump force
    • Suspension may bottom over the largest bumps on the track resulting in momentary loss of tyre contact and excessive instantaneous loads on suspension and chassis
    Dead shock on one corner
    • A dead shock is surprisingly difficult for a driver to identify and/or isolate
    • At the rear, that car will ‘fall over’ onto the outside tyre and oversteer in one direction only
    • At the front, the car will ‘fall over’ onto the outside tyre on corner entry and then understeer.
    WHEEL ALIGNMENT
    Front toe-in: too much
    • Car darts over bumps, under heavy braking and during corner entry – is generally unstable
    • Car won’t point into corners, or if extreme. May point in very quickly and then dart and wash out
    Front toe-out: too much
    • Car wanders under heavy braking and may be somewhat unstable in a straight line, especially in response to single wheel or diagonal bumps and/or wind gusts
    • Car may point into corners and then refuse to take a set
    • If extreme will cause understeer tyre drag in long corners
    Rear toe-in: too little
    • Power on oversteer during corner exit
    Rear toe-in: too much
    • Rear feels light and unstable during corner entry. Car slides through corners rather than rolling freely
    Rear toe-our: any
    • Power oversteer during corner exit and (maybe) in a straight line
    • Straight line instability
    Front wheel caster or trail: too little
    • Car too sensitive (twitchy?)
    • Too little steering feel and feedback
    Front wheel caster or trail: too much
    • Excessive physical steering effort accompanied by too much self return action and transmittal of road shocks to the drivers hands
    • General lack of sensitivity to steering input due to excessive force required
    Front wheel caster or trail: uneven
    • Steering effort is harder in one direction than in the other
    • Car will ‘pull’ towards the side with less caster – good on ovals, bad on road courses
    Camber: too much negative
    • Inside of tyre excessively hot and/or wearing too rapidly. At the front this will show up as reduced braking capability and at the rear as reduced acceleration capability. Depending on the racetrack and the characteristics of the individual tyre, inside temperature should be 10°-25° hotter than the outside. Use a real pyrometer with a needle rather than an infra red surface temperature device.
    Camber: not enough negative
    • Outside of tyre will be hot and wearing. This should never be and is almost always caused by running static positive camber at the rear in an effort to avoid the generation of excessive negative camber under the influence of aero download at high speed.
    • A better solution is improved geometry and increased spring rate. Dynamic positive camber will always degrade rear tyre performance and if extreme, can cause braking instability and/or corner exit oversteer.
    Bump steer, front: too much toe-in in bump
    • Car darts over bumps and understeers on corner entry
    Bump steer, front: too much toe-out in bump
    • Car wanders under brakes and may dart over one wheel or diagonal bumps
    • Car may understeer after initial turn in
    Bump steer, rear: too much toe-in in bump (same as solid axle steer on outside wheel)
    • Roll understeer on corner entry
    • Mid phase corner understeer
    • ‘Tiptoe’ instability when trail braking
    • Darting on power application on corner exit
    Bump steer, rear: too much toe-out in bump (same as solid axle steer on outside wheel)
    • Instability on acceleration
    • Good turn in followed by a tendency to oversteer at mid-phase and exit
    TYRES
    Too much tyre pressure
    • Harsh ride, excessive wheel patter, sliding and wheel-spin
    • High temperature reading and wear at the centre of the tyre
    Too little tyre pressure
    • Soft and mushy response
    • Reduced footprint area and reduced traction
    • High temperatures with a dip in the centre of the tread
    Front tyres ‘going off’
    • Gradually increasing understeer – Enter corners slower, get on power earlier with less steering lock
    Rear tyres ‘going off’
    • Gradually increasing power on oversteer – Try to carry more speed through corner and be later and more gradual with power application
    LIMITED SLIP MALADIES
    Limited slip differential wearing out
    • Initial symptoms are decreased power on understeer or increased power on oversteer and inside wheel spin. The car might be easier to drive, but it will be slow
    • When wear becomes extreme, stability under hard acceleration from low speed will diminish and things will not be pleasant at all
    Excessive cam or ramp angle on coast side plate (clutch pack) limited slip differential
    • Corner entry, mid-phase and corner exit understeer. Incurable with geometry changes or rates – must change differential ramps. In 1998, virtually everyone is running 0/0 or 80/80 ramps.
    SUSPENSION GEOMETRY
    Excessive front scrub radius (steering offset)
    • Excessive steering effort accompanied by imprecise and inconsistent ‘feel’ and feedback
    Excessive roll centre lateral envelope: front or rear
    • Non-linear response and feel to steering input and lateral ‘G’ (side force) generation
    Rear roll centre too low (or front r/c relatively too high)
    • Roll axis too far out of parallel with mass centroid axis, leading to non-linear generation of lateral load transfer and chassis roll as well as the generation of excessive front jacking force.
    • Tendency will be towards understeer
    Rear roll centre too high (or front r/c relatively too low)
    • Opposite of above, tending towards excessive jacking at the rear and oversteer
    Front track width too narrow relative to rear
    • Car tends to ‘trip over its front feet’ during slow and medium speed corner entry, evidenced by lots of understeer (remember trying to turn your tricycle?)
    • Crutch is to increase front ride rate and roll resistance and increase the camber curves in the direction of more negative camber in bump (usually by raising the front roll centre)
    HTH
    12,590
    CARROLL SMITH’S PROBLEM AND CAUSE GUIDE
    INSTABILITY
    Straight line instability: general
    • Rear wheel toe-out, either static due to incorrect (or backwards) setting, or dynamic due to bump steer or deflection steer
    • Vast lack of rear download or overwhelming preponderance of front download
    • Wild amount of front toe-in or toe-out
    • Loose or broken chassis, suspension member or suspension link mounting point
    • Dead shock absorber
    Straight line instability: under hard acceleration
    • Malfunctioning limited slip differential
    • Insufficient rear toe-in
    • Deflection steer from rear chassis/suspension member or mounting point
    • Rear tyre stagger (car pulls to one side)
    • Dead rear shock absorber
    • Wildly uneven corner weights
    Straight line instability: car darts over bumps (especially one wheel bumps)
    • Excessive Ackermann steering geometry
    • Excessive front toe-in or toe-out
    • Uneven front caster or trail settings
    • Insufficient rear wheel droop travel
    • Dead shock or uneven shock forces or incorrectly adjusted packers/bump rubbers
    • Front anti-roll bar miles too stiff
    Instability under hard braking: front end wanders
    • Excessive front brake bias or uneven corner weights or excessive front damper rebound force
    Instability under hard braking: car wants to spin
    • Excessive rear brake bias
    • Insufficient rear droop travel
    • Excessive rear damper rebound force
    • Unbalanced ride/roll resistance – too much at rear
    • Insufficient rear camber (usually in combination with one or more of the above)
    RESPONSE
    Car feels generally too heavy and unresponsive
    • Tyre pressures too low
    • Insufficient ride and/or roll resistance (springs and bars)
    • Excessive aerodynamic download, or insufficient spring for the amount of download
    • If high speed acceleration is sluggish, the culprit is often too large a rear wing Gurney lip
    Car feels sloppy, is slow to take a set in corners, rolls a lot, doesn’t want to change direction
    • Insufficient tyre pressure
    • Insufficient damper forces
    • Car too soft in ride and/or roll
    Car responds too quickly – has little feel – slides at the slightest provocation
    • Excessive tyre pressure
    • Excessive bump force in shock absorbers
    • Car too stiff for inexperienced driver
    • Excessive ride or roll resistance
    • Excessive front or rear toe-in
    • Insufficient aerodynamic download
    Understeer
    Corner entry understeer: car initially points in and then washes out
    • Excessive toe-in or toe-out (car is usually ‘darty’)
    • Insufficient front droop travel (non droop limited cars only)
    • Incorrectly adjusted packers (car rolls on to packers)
    • Insufficient front damper bump resistance (similar to roll stiffness example)
    • Insufficient front roll stiffness – car may feel like it is pointing in but may actually be falling over onto the outside front tyre due to insufficient front roll stiffness or diagonal load transfer under heavy trail braking. Initial understeer can often be cured by increasing front roll resistance, even though doing so may increase the amount of lateral load transfer.
    • Non linear lateral load transfer due to spring and/or bar geometry. Or to non-optimal roll axis inclination
    Corner entry understeer: car won’t point in and gets progressively worse
    • Driver braking too hard, too late
    • Relatively narrow front track width
    • Excessive front tyre pressure
    • Excessive front roll stiffness (spring or bar)
    • Relative lack of front download (excessive rear download)
    • Incorrectly adjusted packers or bump rubbers (car rolls onto packers)
    • Insufficient front toe-in
    • Insufficient Ackermann effect in steering geometry
    • Front roll centre too high or too low
    • Insufficient front damper bump force
    • Insufficient front toe-out
    • Insufficient front wheel droop travel (on non droop limited cars only)
    • Nose being ‘sucked down’ due to ground effect
    • Can also be caused by unloading the front tyres due to rearward load transfer under acceleration – cures include:
    • Increasing front damper rebound force
    • Increasing rear damper low speed damper rebound force
    • Increasing rear anti-squat
    • Droop limiting front suspension (will also make turn in more positive and will reduce overall understeer)
    Mid-corner (mid-phase) understeer
    • Excessive relative front roll stiffness
    • Excessive front toe (in or out)
    • Insufficient front dynamic camber
    • Insufficient front wheel travel (car rolls onto packers or bottomed shock)
    • Insufficient droop travel (on non droop limited cars)
    Corner exit understeer: slow corners
    • Often a function of excessive corner entry and mid-phase understeer (whether driver induced or car induced) followed by throttle application whilst maintaining the understeer steering lock. The first step must be to cure the corner entry and mid-phase understeer. If this is impractical, then corner entry speed should be reduced slightly in order to allow earlier throttle application. Sometimes we have to be patient.
    Corner exit understeer: fast corners
    • Relative lack of front download – often caused by negative pitch angle (squat) due to rearward load transfer on acceleration. Can be helped by increasing rear anti-squat and/or by increasing rear low speed bump force, increasing front droop force and by limiting the front suspension droop travel.
    • Excessive ramp angle or pre-load on clutch pack or plate type limited slip differentials.
    Understeer stronger in one direction than in the other
    • Uneven corner weights
    • Uneven caster
    • Uneven camber (especially front)
    OVERSTEER
    Corner Entry Oversteer
    • Excessively heavy trail braking
    • Excessive rearward brake bias
    • Severe rearward ride rate/roll resistance imbalance
    • Rear roll centre too high
    • Diabolical lack of rear download
    • Severely limited rear droop travel
    • Broken or non-functioning outside rear damper
    • Broken or non-functioning front anti-roll bar
    Note: A slight feeling of rear ‘tiptoe’ type hunting on corner entry can be due to excessive rear toe-in or excessive rear damper rebound force.
    Mid-corner (mid-phase) oversteer
    • Driver threw the car at the corner to get through initial understeer – only cure is to educate the driver and/or decrease understeer
    • Excessive rear tyre pressure
    • Excessive relative rear ride and/or roll stiffness
    • Rear suspension bottoming in roll
    • Insufficient rear droop travel (non droop limited cars only)
    • Very loose rear anti-roll bar linkage
    Corner exit oversteer: gets progressively worse from the time the power is applied
    • Worn out limited slip differential
    • Excessive anti-squat geometry
    • Excessive rear ride and/or roll stiffness
    • Insufficient rear spring, bar or shock (low piston speed bump force) allowing the car to ‘fall over’ onto outside rear tyre
    • Excessive rear negative camber
    • Too little dynamic rear toe-in
    • Relatively insufficient rear download
    Note: If car feels as though it is sliding through the corner rather than rolling freely, reduce the rear toe-in and see what happens.
    Corner exit oversteer –sudden – car seems to take a normal exit set and then breaks loose
    • Insufficient rear suspension travel (lifting the inside wheel on non droop limited cars or bottoming the outside suspension due to lack of bump travel)
    • Dead rear damper
    • Sudden change in outside rear tyre camber
    • Too much throttle applied too soon –often after the drivers confidence has been boosted by the car taking a set.
    Car does not put the power down smoothly on the exit of smooth corners
    • Excessive rear ride/roll resistance
    • Tyres gone
    • Excessive rear damper low piston speed bump force
    • Excessive rear dynamic camber – either from download or from camber change on squat
    • Relative lack of rear download
    Car does not put the power down on the exit of bumpy corners
    • Any or all of the above for smooth corners
    • Excessive rear damper high piston speed force
    • Excessive rear damper rebound force (jacking down)
    TRANSITIONS
    Understeer in, snap to oversteer on power application
    • The most common complaint of all ! Usually caused by too little roll resistance – car falls over on entry and then snaps.
    • Increase front bar and/or spring and/or front damper low piston speed bump force. Stiffening the bar will also transfer some load on to the inside rear tyre on acceleration.
    • If the suggestion above cures the understeer but the car still snaps, the culprit is almost always the car falling over on the outside rear tyre on longitudinal plus lateral load transfer. Add rear bar or spring. Bar will transfer load away from the inside rear tyre. Spring will not. Spring will, however, decrease traction over exit bumps while bar will not.
    • Loose anti-roll bar linkage/blade sockets can have the exactly same effect
    Car is slow to change directions in chicanes or esses
    • Insufficient ride/roll stiffness, especially at front.
    • Relatively narrow front track width.
    • Insufficient front damper low piston speed bump force.
    BRAKES
    Brake pedal gets soft, spongy and/or long during session or race
    • Fluid boiling in calipers. Not pad fade ! Upgrade fluid and/or cool calipers.
    Brake pedal is soft, spongy and/or long before the car is run
    • Air in the system – bleed brakes.
    • Brake pads badly taper worn – replace
    Reduced stopping power with normal brake pedal
    • Pad fade – due either to unbedded new pads or to temperature beyond pad capacity. Upgrade pads.
    Long pedal with little effort required
    • Master cylinder(s) too small or pedal mechanical advantage too great.
    Rough braking – pedal vibrates under pressure
    • Organic pickup on discs – clean discs with garnet paper (not aluminium oxide sandpaper) and upgrade pads
    • Warped (not grooved) rotors. Grind (or, if you must, turn) rotor surfaces
    • Insufficient axial float on floating discs
    Uneven braking – car pulls to one side
    • Stuck piston(s) – rebuild calipers
    Brake bias changes during application
    • Excessive clearance between master cylinder push rod clevises and bias bar bearing housing.
    • Rod end bearings used instead of clevises on master cylinder push rods.
    • Bias bar incorrectly adjusted. Bar must be perpendicular to vehicle longitudinal axis with full foot pressure applied. Contrary to popular opinion, relative length of master cylinder pushrods is immaterial.
    HTHtoo
    Rallyist
    Queanbeyan: Canberra's Bitch
    1,697
    That shit is fantastic, Muz.
    Awesome.
    Right now I'm eating scrambled egg. With a comb! Out of a shoe!
    12,590
    I just looked for an email from a bloke and found it- I'd forgotten it completely!
    It really is awesome. The basis of it is open wheel cars from the eighties which is what Carroll was doing as a race engineer, however, the gist of it is true for all motorsport cars.
    Glad you enjoyed it!
    11,230
    Thanks Muz.
    10.83 @ 125
    Away
    18,150
    lol, I think I paid $30 for a book that had all that in it. Its got lots more too, worth buying...only trouble is I cant remember which one it was!
    2,801
    Nice, thanks Muz. Gotta book another tuning day now, try some of these changes!
    Alex.
    Melb
    7,880
    "engineer in your pocket"?
    Sir John Monash
    Registered User Bob Saget's Avatar
    1,452
    Where does one find Carroll Smiths books? Amazon?
    Meh
    Jan 1970
    26,940
    Quote Originally Posted by FaTs
    Um, when it starts working again ... http://www.bevenyoung.com.au/
    You can safely buy everything Smith has ever written and learn a lot from it.
    12,590
    http://www.carrollsmith.com/books/purchase.html
    http://www.carrollsmith.com/books/boxedset.html
    Boxed set for the win- $100 US plus shipping for every book he wrote.
    Jsut noticed the sae released a compilation he was working on when he passed away, photocopies of 15 sae papers on chassis and suspension design. $100 just for that! They're acting like it's a 'tribute' to him. Wankers...
    Melb
    7,880
    yep, tech bookshop in vic has it...not worth the money IMHO
    Sir John Monash
    dangerous fugitive
    2,749
    I can only add a 'me too' for the recommendations on his tune to win, engineer to win, drive to win and screw to win (which is possibly 'actually' listed as the book on fasteners )
    Drive to win is probably the most amusing (though the humour is likely subtle and mild for most people's tastes, I liked it) and for 95% of us if we were only allowed one of his books, tune to win would be the one. there's absolutely bugger all in it that is 'dated'. Perhaps a little about tyre and shock absorbers, but it's very obvious as to where things have headed, and how to still be able to optimally apply everything he discusses in a modern context. Absolutely brilliant.
    John McKenzie
    Science flies people to the moon.
    Religion flies people into buildings.
    Feb 2007
    Manor Farm
    1,692
    Quote Originally Posted by bigmuz
    That is where I got mine from.
    Trendsetter is awesome cheapracer's Avatar
    Jan 2010
    Sichuan Province, China
    3,165
    Thanks for your time and effort Muz.
    Meh
    Jan 1970
    26,940
    There's a cheaper place now ...
    www.abebooks.com
    I've bought a lot of books from them, very cheap and lots to choose from.
    Mar 2014
    South Melbourne
    4
    Excellent..! Thanks for sharing the above useful guidelines.
