Page 1 of 53 123451151 ... LastLast
Results 1 to 30 of 1570
Thread: Fiat 131 Sports Sedan
    8,637
    Thought it was about time to post up some pics of my 1970 Fiat 125 Special.
    Current specs are as follows:
    Block: rebuilt 1983 Fiat 131 Superbrava Mk11 2litre, 7.6:1 compression custom short skirt forged pistons, custom length forged Argo rods, external oil filter with -10lines and fittings and Serck 13 row oil cooler & custom catch can
    Head: 132 1756cc head, raised inlet ports, modified chamber shape, 45mm cut down Landcruiser inlet valves, standard exhaust valves, billet Fiatorque inlet and exhaust cams, vernier cam wheels
    Induction: custom Quickspool plenum, 67mm billet Plazmaman throttle body, custom Quickspool airbox with cold air feed, K&N filter
    Turbo: Garrett GT3076R with 0.63 extreme coated exhaust housing, 300x550x76mm intercooler with alloy piping & billet BOV, 38mm Tial external wastegate
    Exhaust: Quickspool merge collected exhaust manifold, Cleveland Exhaust 3 dump pipe, single muffler and resonator, twin 2.25 tips, extreme coated to half way point
    Fuel: 57l RCI alloy fuel cell, Carter pre pump, 2.5 litre surge tank, Bosch 044 main pump, Aeromotive pressure regulator, Bosch 1000cc injectors, custom billet fuel rail with speed flow fittings throughout
    Ignition: cut down standard distributor, RB30 crank angle sensor, LS1 coil packs, drycell battery LHR footwell, 85amp EA Falcon alternator
    Computer: Haltech E6X (one 15psi map for 98 & a 20psi map for E85), Gizzmo boost controllor
    Cooling: ARE aluminium radiator & Moroso recovery tank, twin SPAL thermo fans (1x6.5, 1 x 7.5)
    Gearbox/clutch: 131 Borg Warner (fixed yoke large bearing), lightened 131 flywheel, 3000 pound modified clutch plate, standard pressure plate with extra bands custom driveshaft
    Diff: Hilux 4.33 lsd
    Suspension: (front)400 pound (275 pound wheel rate) King springs with Koni reds, camber pins in lower control arms with 4degrees negative (rear) Koni red rear shocks from IPRA RX7 with reset leaves and one extra full length leaf
    Brakes: front: Mazda RX7 4 pots, Ferodo DS3000 pads, braided lines, 280mm x 23mm vented redrilled Volvo discs. All new hardlines, adjustable bias and twin Willwood master cylinders
    Rear: rebuilt 132 callipers with stainless pistons & EBC black pads
    Wheels/Tyres: 15x7 Performance Superlight GTR's with 205-50-15 Toyo R888s (track) and 15x6" 10 spoke Superlights with 195-55-15 for the road
    Body/Paint: standard olive green, body resprayed in 1998, all rust removed/ body restored at the same time, all standard chrome polished, rear arches flared 25mm per side
    Interior: 11ty billion point cage by Norm Singleton, painted in POR15 grey, restored dash, RPM suede wheel, Sparco drivers seat, ERG 6 point harnesses
    Previous specs:
    Block: rebuilt 1984 Fiat 131 Superbrava Mk111 2litre, 10.2:1 compression, balanced rods and crank, custom harmonic balancer, external oil filter with -10lines and fittings and Serck 13 row oil cooler
    Head: 132 1756cc head, ported and polished, 45mm cut down Landcruiser inlet valves, standard exhaust valves, billet Tighe inlet and exhaust cams, vernier cam wheels, flows well over 200HP
    Induction: custom twin dual throat 48mm throttle plates, custom upswept ram tubes with uni filter air filter
    Exhaust: Fiatorque extractors and primaries high temp coated into 2.5
    Fuel: Carter pre pump surge tank, Bosch 070 main pump, rear mounted Camira Fuel pressure regulator, Bosch 803 injectors, custom billet fuel rail with speed flow fittings,
    Ignition: cut down standard distributor, RB30 crank angle sensor, LS1 coil packs, battery in boot, 85amp EA Falcon alternator
    Computer: Perfect Power Cuffer Spec V4.0 or some shite
    Gearbox/clutch: standard Colloti 5speed, 1608cc 215mm flywheel, 1750 pound modified clutch plate, standard pressure plate with extra bands custom driveshaft
    Diff: Hilux 4.875 locker
    Wheels/Tyres: 15x7 Performance Superlight GTR's with 205-50-15 Kumho V70A's (track) and 15x6" 10 spoke Superlights with 195-55-15 cheap shite for the road
    Power: 134RWHP
    Times: (in various levels of specs)
    QR Sprint Track: 62.97
    MP short: 48.9
    Leyburn: 48.95
    Maryborough: 49.37
    Bathurst Esses: 33.21
    Mt Cotton: 51.25 (only had 5 runs up the hill in 3 years, there's sub 50's once I learn the track)
    Wakefield: 75.91
    ARE YOU REAAAAADY? Grunt's Avatar
    SYDNEY
    3,707
    very very cool.
    love that colour - cleverly understated.
    Manta Manta GTREA's Avatar
    7,639
    Geez there Ugly...but geez its beautifull
    Love what you've done exactly how I like to modify cars ie Subtle / Standard appearance with sporting twist (Seat , steering wheel Suspension engine etc)
    Good to see something different also...I'm a fan
    1978 Opel Manta SR Berlinetta 1UZFE - Project
    2013 Opel Insignia OPC - Daily
    2011 Hyundai iLoad - Work
    2015 Skoda Octavia Scout premium 132TSI - Mrs
    10,171
    It may have caused you much pain but you're left with a great result!
    Anti-drifter XAC15T's Avatar
    Sydney, NSW
    4,044
    Love it
    Social media marketing for the automotive industry (plus a motorsport blog) - www.boxthislap.com.au
    Registered User Cameron_Datto's Avatar
    SE QLD Australia
    789
    So are going to Wheels on Wide bay this year ?
    ________
    Interracial college
    2ofdem
    Guest
    This thing has the coolest induction noise ever. Nice car with plenty of time and money spent on the bits that matter.
    Oct 2006
    218
    Fark, that is awesome!
    24,344
    Awesome car & i can confirm it pulls twin spinner skids.
    got one out the front if my place
    Registered User boosted's Avatar
    Hobart
    311
    Sweet as mate, very nice! Is that an 8V head? I just scored my bro's 124 coupe with a nice worked 2L and shit.
    I've got a bit of work to get it like yours though!
    12,588
    This one nice one.
    (I've never seen it, but Guido is a nice kid, so his car would be a nice car.)
    Tectaloy Chemist oxy's Avatar
    Not in the diner, Alf
    6,991
    I've got a spare diff for one of these things in the backyard if you want it
    Ipswich, Qld
    2,747
    Awesomely cool, total radness! What a great little car you have there... you must be very proud.
    Moderator Cal's Avatar
    Nov 2002
    Brisbane, Queensland
    22,351
    One of the coolest cars around. Reckon it's awesome that a young bloke has spent as much time and money on an old piece of Italian history as Sam has on this thing. It goes like stink and sounds as only an Italian can.
    Cal.
    15,070
    Ok, that is fuckibng hot. Can I PLEASE get a high res shot of the engine bay shot? I can PM you me E-mail addy.
    Registered User mightyboy's Avatar
    Mar 2006
    qld
    278
    fuck your engine bay wasn't that clean on teh weekend
    very nice car, have witnessed this racing both at Bathurst and QR now and am very impressed!
    ..... speaking of which, heres a pic
    Away
    18,150
    Its a credit to Sam to have been so bloody determined & focussed with this thing. Im not sure, but I think he could have built a space shuttle instead.
    Nov 2002
    22,351
    Nah Space Shuttle's are cheaper.
    Cal.
    6,991
    Quote Originally Posted by Guido
    Fiat 125 Special
    What's so special about it?
    Away
    18,150
    Like a special child is special...
    8,637
    Thanks blokes.
    Of course being a project car it will probably never be finished but I hae owned it for over 12 years now so there'll be no selling it.
    Cameron - Definately will be at Wheels on Wide Bay. Really need to get my entry in. Was hoping to have the cage in by then but that will probably have to wait until after Leyburn.
    Datzed - not sure if I have a high res version of that pic. Will have to get into contact with who took the photo.
    After the weekend the RHS of the engine bay doesn't look as pretty. 3/4 stuck open throttle + stupid driver refusing to come in = brake fluid overflow and damaged paint.
    15,070
    Damn, that would have made a wicked wall paper. Car is uber hot though mate.
    Jun 2005
    Sunshine Coast
    385
    Saw your car at GSR getting the suspension fixed the other week. Looks great in the flesh, ahh metal?
    get lead like a leader
    Sensei Cobra
    Bris-bain
    6,796
    Quote Originally Posted by no1200
    Probably right the first time. It's a Fiat after all, not much metal left in it!
    Looks great Sam, even though I haven't actually seen it in ages!!
    The royal penis is clean tremolo's Avatar
    Jul 1979
    Zamunda
    4,905
    Looks great mate. Got any vids or audio of you revving the tits off it?
    Nov 2002
    22,351
    Leyburn.
    What date is that on this year? As I can't make it to Speed on Tweed AGAIN, I plan to camp up there and get all pissed up.
    Cal.
    8,637
    Datzed - I am tracking down a high res copy.
    No1200 - Yeah, I really have Phil to thank in getting many aspects of this car sorted.
    Cal - Usually the third weekend in August.
    Tremolo - this may or may not be the car on the rev limiter on a private test track. Contrast/brightness may need to be adjusted.
    15,070
    [/url]
    Hell yeah! Would be ace.
    Whats the rev limiter set at? fark I'd be nervous as hell holding it against the limiter like that
    Inanimate Carbon Rod Blind_Goat's Avatar
    perth, WA
    1,243
    [QUOTE=Guido]
    Holy shit that sounds good
    8,637
    Limiter is only set at 7600.
