Page 18 of 18 FirstFirst ... 81415161718
Results 511 to 530 of 530
Thread: VL street/circuit
  1. #511
    Registered User DJ345's Avatar
    melb eastern subs
    167
    TS Astra Around 2000 I think.
  2. #512
    . motoxray's Avatar
    Dec 2005
    Dans' den
    667
    TS is 1998 to 2005.
    The Ebay link I provided also says AH, which is the later model, but I have found they are usually not suitable, unless it's early AH.
    tl;dr TS is safer bet
  3. #513
    Apr 2003
    Roleystone
    3,341
    I have the TS pump on my VN also. Used many of them
    GURU ENGINEERING PTY LTD
  4. #514
    6
    I should have some somewhere.
    I will dig them up and post them for you.
    I will be at Phillip Island on grand final weekend for the last round of the state series if you want to have a look and chat.
    Quote Originally Posted by DJ345 View Post
    Yes it is Johnno.
    Have you got any pics of how you attached the bracket to the car?
  5. #515
    1,557
    Thanks Andrew.
    To the commo anoraks, I've got 3 racks to try, VL/VN wont fit, but a VP p/s rack just about fits with a little extractor clearance required. Problem is i dont have the VP intermediate shaft, i've got the VL/VN version. Will a VP shaft adapt to the VL column? I know it locates different to the rack end. Anyone got a photo and length of a VP intermediate shaft ?.
    No chance i can get a VN rack to fit.
    Adam
    Sandown 1.23.31
    Calder 1.05.76
    Phillip Island 1.47.95
    Winton 1.33.30
    Bathurst 2.47.49
  6. #516
    Bentleigh Victoria
    3,385
    Mine has a VN rack. It is very tight and needed some work.
  7. #517
    1,557
    Things going well, for those playing at home,
    You can swap the top casting where the hydraulic lines go between VL/VN to a VP/VR power steering racks. You will also need to swap over the metal lines that run to the rack. The benefit being you get to keep your existing intermediate shaft and steering column and the pipes are far more compact allowing a little extra room for extractors. If you want to be the coolest kid in the class, you could theoretically run the VS variable p/s rack in a VL/VN and be an internet legend.
    Next job is to run the high/low pressure lines and power up the Astra pump.
    Sandown 1.23.31
    Calder 1.05.76
    Winton 1.33.30
    Bathurst 2.47.49
  8. #518
    Bentleigh Victoria
    3,385
    Are you doing Winton?
  9. #519
    1,557
    Yep
    Sandown 1.23.31
    Calder 1.05.76
    Winton 1.33.30
    Bathurst 2.47.49
  10. #520
    1,557
    As the Lightyear mentioned, Winton started well, new PB of 1.33.8 in Qualy. Powersteer was very nice to have and made the Walky easy to drive. I got some data on tyres and made a few changes to Race 1 to unlock more speed. Lightyear was beside me in 6th position.
    MotoXray came up and said hello to Dave and myself, always good to see fellow PFers
    Race 1, Started 5th, good start and said good bye to Dave's VN, sat in 4th for the race until the water temp got a little high stuck under the HT TCM Car. I was in a 3 way battle, so let Vics Coupe car past and finished 5th. The Lightyear was behind. Dave would have been closer but he threw it off the road on lap 2 and had to fight his way back.
    Pretty happy with the car at this point, i went the wrong way with adjustments for race 1 and was confident for race 2. It did look very nice all clean for race 2.
    Race 2 started ok, this time Dave got a better start, i had him pinched behind the XB Coupe. Got a clear run through the flip flop but got clobbered by the XB coupe as he lost control in the marbels, got into a tank slapper and made a V-Line to the wall. My car was in the way and hit the A pillar pushing me into the wall instead. Pics tell the story, mostly panel and strut damage, it will buff out and be back on the track soon enough.
    Adam
    Sandown 1.23.31
    Calder 1.05.76
    Winton 1.33.30
    Bathurst 2.47.49
  11. #521
    melb eastern subs
    167
    Bummer not good at all, but you'll be back there in no time.
  12. #522
    7,470
    Cunt. Both sides bjorked
  13. #523
    Bentleigh Victoria
    3,385
    It's a pity that happened, we would have had a tight race being so close in lap times. I suppose new brakes are not in the budget now. Are you going to upload any video? I caught the whole thing.
  14. #524
    Aug 2013
    gawler
    1,486
    Ah Bugger!
    Still you are OK, car can be fixed...
  15. #525
    Peoples Champ Fatboy's Avatar
    11,362
    Fuck Adam, glad you're ok mate...
    The dude who bought my N14 ran it on the weekend down there too, it didn't come home straight either...
  16. #526
    1,557
    Update,
    Car is pretty much finished, as always a few more mods get thrown in the mix. It's looking pretty sharp with virtually a new full respray.
    Due to the some suspension damage, i have re-engineered the front end. Plenty of upgrades to get the lazy thing to turn in and hold some corner speed. Also a new Harrop brake package to be fitted.
    IPRA have made a few key changes also this year, biggest win for me is the 6 speed can now stay in the car and I can fit a floor mount pedal box. Very good chance I'll be at a round this year.
    Adam
    Sandown 1.23.31
    Calder 1.05.76
    Winton 1.33.30
    Bathurst 2.47.49
  17. #527
    Canberra Nth
    2,965
    Good to hear it made a decent recovery!
    - PSN: rotacoupe
  18. #528
    1,367
    Sorry to see it get banged up Adam. Good to see it back bigger and better ! Always an opportunity for improvements
  19. #529
    melb eastern subs
    167
    Update ?
  20. #530
    1,557
    Yep, Its all been repaired, its in better condition then when i first built it. Brakes sorted (ish). Hoping to complete it in the next 4 weeks. I'll get some pics when i pic it up.
    Adam
    Sandown 1.23.31
    Calder 1.05.76
    Winton 1.33.30
    Bathurst 2.47.49
