Page 4 of 63 FirstFirst 123456781454 ... LastLast
Results 91 to 120 of 1878
Thread: XW getting built for the corners n shit
    10,479
    Cheers Oxy, Yea it's a massive job to clean up an engine bay and to hide all that shit, My biggest issue is the LPG shit that requires additional lines that seems to clutter things up,
    I will take your advise and run the wiring like that and also going to try to reduce some other hoses and crap.
    10,479
    Far out its been a while but there has been some progress,partially welded in the notching kit, the one on the LHS has the centre bracing welded in and the RHS got finished after this pic. there is still a fair ammount of welding and grinding to do, then weld up all the holes and smooth over the welds on the tower.
    These are the coilovers adjustable for ride height and spring rate and the new hubs which have larger dia bearings.
    10,479
    This also found its way into my boot this afternoon and was promptly transferred to the garage for much chubbyness.
    Came from an XR8 that fell over and kindly decided that I needed it more. Tremec T56.
    Perth Cunt
    3,508
    Nice find XW. That'll go sweet in there.
    Originally Posted by Stang:
    Registered User Monza's Avatar
    May 2005
    Perth, WA
    992
    fuck dude! this is going to rock
    Has AIDS - BRT-393 Bermo's Avatar
    Blue Mts NSW
    2,615
    Nice one dude!
    What you doing with your old box?
    Im not only sure Im HIV positive.
    10,479
    Cheers fellas,
    Bermo, a nice young man came over and paid me cash for my C10 and Dominator, said he wanted to race his XE but couldn't get below 12.5 with his toploader.
    Perth Cunt
    3,508
    Quote Originally Posted by xwgasaxe View Post
    Damn. I was eyeing that off
    10,479
    Oh yea oops sorry about that but I needed the cash real bad as my $1200 a day meth habit kicked in.
    10,479
    Ok what's the go with welding holes up in the engine bay that are say 8-10mm? Do you just weld a small piece of CS inside the wheel arch and then smooth over with filler.
    Chicken strip paradise Jay_G's Avatar
    2,478
    find someone or a sheet metal business with a turret punch, spend 5 mins punch out a heap of different size circles and weld them in. i would me nicer to get them flush, i have seen someone on a car show use magnet to hold the circle while it was welded.
    yep
    10,479
    Ah cheers so what you saying is that I should use the Water Jet Cutter that I have at my work and cut out various size circles and just tack them into the hole?
    Awesome didn't know it was going to be that easy.
    10,479
    Ok so started working on the rear suspension this week, the diff is from an EF XR6 wagon and bolted straight into the spring mounts. I then grabbed from the wreckers the Watts link diff cover and rods from an EL sedan.
    What I am assuming is that the rods should be parallel to each other which leaves them about 20mm inside the verticle line of the chassis rails and about 300mm on the drivers side and about 400mm on the passenger side lower. I knocked up a really simple bracket from 50sq mild steel tube and notched it on one side to hopefully wrap around the chassis rails and the fasteners will have crush tubes put into brackets.
    Question I have is will this be strong enough if I put some gusset bracing on the inside to the area where the fuel tank used to mount?
    Any other thoughts?
    Tectaloy Chemist oxy's Avatar
    Not in the diner, Alf
    6,970
    That's what I (with the help of a mate) did. Welded some small plates on the non engine bay side of the holes, then tried to weld up as much of the hole as possible and then smoothed over with filler. Was interesting when welding a plate on to the fire wall and the carpet caught on fire
    Opens HoonBoy's Avatar
    9,820
    For welding up the holes, grab a thick piece of copper and get someone to hold it behind the hole whilst you weld it up. You can use a small piece of metal in the middle for bigger holes, but not really needed with this method as the weld won'ttake to the copper.
    Watts link bars should be parallel to the ground at ride height. they will cop a fair bit of sideways forces so you need to make sure the brackets are very strong. The stiffer they are, the better they will work. Hard to comment on your design with the pictures given but I would make sure they have a good brace towards the centre of the car to stop movement. It may require putting a cross brace between the rails if there is nothing to put it on to.
    15,632
    AU rear cover will give you a lower rear roll centre from memory.
    You may wind up doing what I did, which was cut big chunks of the tank well out so I could weld doublers to the rails and then the box sections, and then weld the sheet metal back in. How's your clearance to where the tank well rolls down behind the diff in the middle? A 9" uses up every last ounce of clearance in there by itself...
    As for bracing - I'd run a small diagonal running backward up to the rail, and a pair of longer braces up tp the centre of the tank well, but I'd use alot of reinforcing where it ties in.
    New Zealand bro Dave's Avatar
    Dec 2004
    Powernats
    5,848
    That powercable without the grommet is scary
    Jan 2009
    hobart
    682
    Can you educate me on what the benefits of a watts linkage is when combined with leaf springs?
    5,135
    Quote Originally Posted by ahk068 View Post
    lateral stability, if youve ever watched a leaf sprung car go around corners, youll understand.
    Watch the bathurst telecast, Neil Crompton will explain it about 11ty thousand times lol.
    I'd rather put a 253 than efi
    Jan 2009
    hobart
    682
    Quote Originally Posted by greenhj View Post
    Figured that, just never thought it would be a massive issue on a car being built for the quarter. Return for investment of time type of deal.
    6,970
    Isn't he trying to get in to circuit stuff now though?
    Jan 2009
    hobart
    682
    Haven't read all the thread but if he is it explains everything. Carry on
    10,479
    Yea was thinking that I could do that to start with but me and the crazy engineer at work are going to try to cut some 8.5mm circles with the water jet cutter. we haven't tried anything this small yet so should be interesting
    thanks for the info and confirmation on the parallel at ride height. I will have to grab some weights for the rear to simulate a full tank of fuel.
    Yes I asked about the AU cover but the boys at the wreckers insisted that they were the same. never the less I may stick my head under an AU and measure. I am goeing to have to do the same as you and cut some sheet metal as the centre link will hit and the sides will need to be cut to make the diagonal braces.
    Quote Originally Posted by old Dave View Post
    The grommet is somewhere further along the cable as it go pushed through when I moved the cable, but you comment is noted.
    Yep Auto is chucked in favour of T56, got some new front suspension and doing these mods for roundy round stuff.
    out in the boonies...
    4,380
    i'm glad the grommet issue is under control, could have been nasty.
    top notch work otherwise, it's a rather big undertaking...
    12,368
    Low roll centre is not necessarily what you want. The front and rear roll centres work together- rellay low at the rear and really high at the front isn't right imho.
    It is miles better than leafs only so do the lateral location thing and see how it drives.
    15,632
    With the RRS strut front end you wind up with a pretty low roll centre at the front, so i don't think the super mega low roll centre of an AU rear cover is an issue.
    With my car, because it's going to be traction limited and I want to try to maximise the drive off of corners, I'm pushing the rear roll centre as low as possible to soften the rear in roll as much as possible to try to keep it planted. If understeer is an issue, i can just wind the rear roll centre back up, or bolt on a rear arb.
    You can run into bind problems with the conflict between the differing roll centres imposed by the leafs and the watts link - answer here is to either superimpose them, or run rose joints in the watts and put stock rubber back in the spring saddles, shackles and front eye to ensure the springs are but springs. This also means you need a 3link or a torque arm to control the axle tramp/hop. This is what i'm doing (within the limits of the Nc rules)
    10,479
    Cheers for the help Gamma with the rear sheet metal, I cut out a section last night as the metal will foul most areas of the Watts. It is must easier to see what's required also.
    I have the old 50mm angle iron from the gas tank that I am thinking of bolting back inline with the Watts links and then using some triangular bracing up to the iron, that or just use 25mm sq box tube and brace from one side to the other.
    10,479
    Had some free time in the office this arvo, so me and the mad scientist decided to make some spacers for the RRS rack, the thing is pretty close to the sump and I wanted to move it away. the mounting studs are long enough to allow a 9mm movement, so we grabbed some 3mm Titanium Grade 2 sheet and cut these strips out and also while we were there made some new strut top braces from the same material.
    9,820
    I need to get some of that equipment in my office!
    10,479
    Woohoo, thanks Aussie dollar!!
    Just ordered me a Holley 750DP HP Street and one of those Anodised carby brackets from Summit racing USA!!
