Results 1 to 30 of 54
Thread: Extending ute/truck chassis? How do they do it?
    ACT Now!
    27,145
    How do they lengthen chassis on utes and light trucks? is it even possible to legally do so? There's a whole bunch of legal issues around chassis welding and modification but there must be methods considering there's all these lazy axle kingswood tonners and 6x6 landcruisers...
    Jul 2007
    Blackwater, QLD
    1,613
    i have an isuzu truck that has ahd a metre added to the chassis. the cuts were made at an angle, and it has a plate bolted along the outside of the chassis. it looks like it was done a long time ago, and it's standing up fine.
    Central Coast - NSW
    3,154
    Working in the truck industry ive seen both, older trucks are usually welded and have long plates also fitted into the rails which are welded or bolted.
    The the newer ones have heat treated rails and cant be welded so they use a staggered bolt arangement with a long u shaped sleave that fits inside the rail and also a flat plate on the outside. The bolts have to be torqued up bigtime and it gets quite technical.
    I remember once i was working on a streched prime mover and the guy who owned it was telling me his life story and how bad it was. I felt terrible telling the poor bastard one of his welded rails had cracked right through and the tray was basically holding it together
    Opens HoonBoy's Avatar
    9,820
    Stretched rodeo for towing?
    Learner The-Kid's Avatar
    694
    I've had my Rodeo dualcab extended to fit a spacecab tray on the rear.
    Was done right and done by Custom shop, but there are Chassis aligners/Engineers that'll do it.
    I had the rails cut from underneath the rear door of the cabin, pulled out the
    right length, an internal rail placed inside the two ends and then finally the rail where the gap is done again to match thickness with each end.
    Mounts are matched up for the longer tub, tailshaft lengthened and electrics.
    ACT Now!
    27,145
    cheers!
    The question is mainly due to the fact that there's very few small trucks the right length to be converted into a racecar carrier.
    I did see something interesting in Sweden, which was the front half of an Audi CD100 grafted onto a car float, making it a FWD six wheeled audi trayback car carrier. Might work with a sprinter cab van or something.
    Registered User GreyBeard's Avatar
    A galaxy far far away
    1,119
    Completely doable, safe and legal (in Qld), if done correctly.
    HtH
    PerformanceForums
    Now bringing you more
    iFagging
    Lycra wearing
    Watch wanking
    Cricket playing
    Ignorance airing
    Feelings sharing
    Porsche licking
    Boostloserness
    9,820
    If you were going to do that, wouldn't you be better off with a Falcon one-tonner?
    5,353
    Bob 'Quarter Mile Smile' Shepherd does this for a living.
    ACT Now!
    27,145
    cool!
    Falcon one ton is probably a good option considering the "chassis" appears to be sheet steel boxed up.
    9,820
    One of my "dream tow cars" is an XR8 tonner with a removable rear section that extends the tray enough for towing the car and moves the diff back as well. Would leave a usable length ute for most stuff and a long one for towing the car. Wouldn't be technically hard, after all it is leaf spring, just have two sets of mounts and a longer tailshaft. Don't think the rego boys would be happy with it...
    Registered User F-Trukin's Avatar
    Mar 2006
    East Coast Tassie
    268
    There was a slide camper that was made to fit AU tonner that had clip on section with lazy axle behind rear drive wheels..also had a longer tray part if you didnt want the camper on. Cant remember what they where called
    Central Coast - NSW
    3,154
    I recon an older dyna with a flat tray would be perfect for private towing. Probally just have to make a set of ramps for it.
    Think about it... cheap, easy to drive, easy to get parts for and needs a normal drivers licence.
    Streching is going to need $$$ engineers reports and lots of work.
    9,820
    Quote Originally Posted by F-Trukin View Post
    Google is failing me
    ACT Now!
    27,145
    Quote Originally Posted by carcrazy View Post
    yeah its just that the long wheelbase ones are not real common.
    the annoying thing is there is one on the way to work that is perfect in length etc for $1500 that looks in reasonable nick from a distance but I don't have the room or the money right now.
    Thornbury Melbourne
    1,252
    Bringing this thread back from the dead.....
    Anyone know an approximate cost to extend an F350 chassis?
    NB:
    Truck delivered running, with no tray or excess bracketry like Gas tank, tool boxes etc
    Spare chassis supplied
    Assumes Tailshaft and brake line will need doing.
    Want it certified by Engineer so VicRoads douche can argue with it. Prefer a one-stop-shop. Drive in/out as a cab chassis.
    Ballpark $'s?
    LS7 Prius = Proper HYBRID Walt Kowalski's Avatar
    May 2010
    WWG1WGA
    1,521
    I put two metres into a shitty light Jeep Wrangler chassis. Needs engineer for rego. Worked well too. 25% over each wheel.
    Cheaper to buy right vehicle.
    Boz has one for sale already done
    http://my105.com/listingdetails.aspx?id=13945&latest=1
    Thornbury Melbourne
    1,252
    For starters that truck isn't extended.
    Thornbury Melbourne
    1,252
    Already have the F350 and go-fast bits. Looking to do something like the white truck, but painted like the Gunmetal one and 18inches to 2 feet longer in the chassis like the xxx truck.
    http://www.aussiev8.com.au/sale-cars...nana-back.html
    http://forums.v8owners.com.au/showth...ect-2293.html?
    http://www.calaisturbo.com.au/showthread.php?t=139035
    7,598
    i endorse this thread
    Manta Manta GTREA's Avatar
    7,639
    I had two Isuzu Giga prime movers stretched to the legal maximum limit for a rigid vehicle for transporting bread.
    Overkill really for purpose but Power!!!!
    Both have since been rolled......
    1978 Opel Manta SR Berlinetta 1UZFE - Project
    2013 Opel Insignia OPC - Daily
    2011 Hyundai iLoad - Work
    2015 Skoda Octavia Scout premium 132TSI - Mrs
    6,062
    Back when I actually liked my Ranger I had evil thoughts about extending it and putting on a single cab ute body. Seems the authorities here don't give a fuck about cutting the chassis and no inspection of the mods are required.
    Turning a front wheel drive whitegoods into rear wheel drive with a 1UZ sounds like a better way to waste my monies...... one day.
    Registered User Splash's Avatar
    1,238
    Quote Originally Posted by GTREA View Post
    .. transporting bread.
    Warwick
    15,134
    Bread rolls?
    ― Jim C. Hines
    ― Daniel Patrick Moynihan
    ― Napoleon Bonaparte
    Thornbury Melbourne
    1,252
    Hooroo! Nitephyre's Avatar
    ormeau@gc.qld.au
    6,789
    ... transporting bread.
    I sense something seedy going on here!
    16,069
    Quote Originally Posted by Nitephyre View Post
    Looking to get a raise?
    CNGAF rowdytoot's Avatar
    hotel vast horizon
    9,975
    Should have seen the bun fight for the wrecks
    16,069
    Bet there was a bit of dough in it!
    hotel vast horizon
    9,975
    these puns about buns are getting a bit stale, doughnt ya think?
