Page 3 of 7 FirstFirst 1234567 LastLast
Results 61 to 90 of 202
Thread: LB Lancer Track Car
    850
    Strange option but it is free, I hoping it will have 28spline axles like the rx4 if not I won't bother.
    What year hilux is that? it might be too heavy for such a little car.
    Opens HoonBoy's Avatar
    9,820
    Not sure of the year, think it was a RN40?? I don't know how much heavier it would be over the standard diff, but any decent option is going to be heavier.
    909
    Quote Originally Posted by RESON8 View Post
    Pretty sure the 929 is the 28 spline just like a RX4, fuckin hilux is too big, also the spectron diff is the same if IIRC
    SA IPRA cars 15, 51, 77 and 25
    (Sharperto Racing)
    http://www.iprasa.mx.com.au/
    850
    Adam Allan mentioned something about a spectron diff, it is meant to be narrow maybe no chopping needed.
    I will go to the wreckers and see if I can find one to measure up.
    9,820
    Any updates on the diff or wider flares?
    850
    No updates on the diff yet.
    But i am picking up the vr4 donk this week and cage is going in on 31st
    9,820
    Progress, cool
    Registered User Regina's Avatar
    Jul 2002
    91
    Diff
    Reason,
    Something also to consider with decision on a diff is the sprung Vs unsprung weight with handling characteristics.
    Cars looking very nice.
    Cheers,
    Mick
    850
    Just got the car back from Walker Chassis today they did all roll cage work, and I am very happy with their work and turn around, highly recommended.
    It is a 6point weld in with harness bar, rear diagonal brace and diagonal in the roof plus side intrusion bars. You can see in the picture that they also put small diagonal gussets from the main hoop to the b-pillar and top bar. I wanted it braced to the b-pillar but because the main hoop is set so far back they had to do it like this, it worked out well. I might have to squeeze some padding over the diagonal on the drivers side as I am sure I will hit it with my helmet over bumps.
    The front legs are nice and tight against the a-pillar and dont obstruct your view or the pedals.
    I am still waiting for my engine to be pulled out of the front cut a the wreckers then I can get stuck into the fun stuff.
    Here are the pics.
    ACT Now!
    26,837
    looks good! what diameter is that? looks pretty thin!
    dude...yellow...
    9,820
    Nice! No harness bar?
    Registered User BENN0's Avatar
    707
    The yellow looks good in the flesh. The price was right also!
    850
    I wanted it green but was told it was unlucky on race car then saw 20L of the yellow up on ebay for $100.
    Main hoop OD is 45mm 2.6mm wall thickness, all other are 38.1mm OD 2.6mm wall thickness.
    Hoonboy, the harness bar runs between the two lower back legs, the camera angles aren't that good but the harness can get through and at the right angle.
    9,820
    I wanted it green but was told it was unlucky on race car ...
    You suck
    OK, looks a little low, I know mine is about 10cm higher then that and I would of preferred higher but had to compromise due to the co-drivers lack of height. As long as it's not more then 45 degress you will technically be fine anyway.
    ACT Now!
    26,837
    fair enuff. Yellow does look better on racecars than road cars, and green vice versa (sorry hoonboy lol) but a fresh coat of Spitfire Orange looked fantastic on my rally car.
    5,037
    [jeffs dad]the cams "legal"harness bar is already fitted in the cage...horizontal bar between the rear wheel arches!..as long as it isn't lower than 40 degrees from shoulder horizontal.also [in sa]i like to see 2 "stops "
    1each side of harness to stop it sliding sideways eg.2..large cable ties or[neater]a "u"shaped metal bracket over each belt,especially if there is any extreme length between seat& rear mntg. point.10 degrees is ideal but still allowed 40 deg.for harness angle.
    909
    You obviously know ashley I recognize the trailer, I towed my car to PI with it, it was fuckin awesome.. I havent seen Ash for a while how is the sigma going... ready to hit the track
    Cheers
    John
    (Sharperto Racing)
    5,037
    Here are the pics.
    looks great - how much extra did you pay for the additional bars?
    BLING BLING PLAYA's Avatar
    adelaide
    5,952
    where the bars meet the top of the hoop can u take a pic how close they are? and also feel if they welded all around, im getting heaps picky these days lol.
    3D scanning
    3D modelling
    Structural certification
    3 and 5 axis milling
    850
    John, goood work picking the trailer I used to work with Ash at ZF he convinced me it would be good idea to build the car. I think all of the body work is done on his sigma just needs some paint and he has a different box to go aswell.
    The trailer does tow well apart from my lack of brake controller, I plan to get a trailer but something smaller my car is just wide enough for Ash's.
    Da9jeff - He did charge me any extra for the braces, even kept the same price that he quoted me 3months ago when I booked it in.
    Playa - the weld goes all the way around even up around near the roof where the would only be 10mm clearance. Here are the photos of the bars meeting on the main hoop at the drivers side, first one is driver side of the hoop the second is through the rear door opening. If you want to come around and check it let me know.
    adelaide
    5,952
    that dude must be pro++, i know he does do it for a living but still thats close where the A piller bars go
    is there holes in your floor where he dropped the cage down?
    3D scanning
    3D modelling
    850
    No holes in the floor there is steel plate welded to the floor the tube welded to that. For the main hoop feet he boxed up a section, below picture is of the passenger side.
    850
    Hoonboy or Jim do you anything about the Lancer a175 diff? I might be able to get one with a 3.9ratio and mech LSD but I don't know anything about them and how much power they can take.
    I will go and measure it up tomorrow.
    adelaide
    5,952
    yea the box is how he got to the top, tack it all up then drop it down fully weld it then put the box in. smart
    3D scanning
    3D modelling
    9,820
    Interchangable with the stock diff... I bent an axle with the old motor and only 106bhp at the wheels..
    14,971
    Is there a good reason that brace next to your head doesn't continue back to the rear feet?
    adelaide
    5,952
    its how they always do it, seen same thing in the cams manual
    also where is your taxi bar for harness mounts?
    3D scanning
    3D modelling
    14,971
    Doesn't mean its the right way... Terminating a diagonal in the middle of a span is bad practice - doesn't transfer the loads anywhere except into bending the span.
    adelaide
    5,952
    that tube is larger then usually used, have a look at every WRC car, they use it to strengthen that junction, usually around 20 cm long from what i seen.
    I mean the door bars terminate in the middle of the hoop too....
    3D scanning
    3D modelling
    9,820
    See the posts above, he is using the bar going between the rear legs.
