Page 20 of 20 FirstFirst ... 101617181920
Results 571 to 595 of 595
Thread: The next project - painting the shed floor
  1. #571
    10,303
    Any idea when it starts?
    Saturday. I stopped in yesterday just in case they'd laid a few tins out but no dice.
  2. #572
    3,584
    Does it go off if say I don't use it for a year or two? I'll have to pull down all my Rack It stuff which will take some motivation....
    Not really - it's a 2-pack epoxy and even though water based tends to have a pretty long shelf life. Just give the Part A a good stir before using.
    The down side of these packs vs buying a similar product in a paint store is only that you don't get any colour choice, its AS2700 N23 Neutral Grey. The up side is that you get the concrete etchant included and it comes in a natty box with instructions.
    Yes we Chemistry
  3. #573
    VIC
    1,060
    Cheers mate!
  4. #574
    Moderator Cal's Avatar
    Nov 2002
    Brisbane, Queensland
    22,176
    Quote Originally Posted by lumpy View Post
    They're so cheap you'd be mad not to. There's 4L in total of epoxy (when you mix A and B) in each pack. That 32 sqm per pack is really at maximum coverage (16m2/L, x 2 coats). You usually thin the first coat out a little to soak in better but still for a more generous coverage bank on closer to 12m2/L.
    So how many tins would be requires to do 120m2?
  5. #575
    3,584
    2 coats of 120m2? So in reality 240m2?
    The kits are 4Lt so to do it on the generous side of 12m2/L is 5 kits.
    Going by the pack instructions of 16m2/L is ~4 kits.
    Yes we Chemistry
  6. #576
    Nov 2002
    22,176
    At that price, we'll get 6
  7. #577
    Caught in the ACT
    17,241
    And for shed wall painting, I recommend and use pf services.
  8. #578
    Aug 2011
    255
    How does the rustoleum epoxy stuff handle steel wheels (engine crane/stand)? Probably best to get some nylon castors I guess?
  9. #579
    Caught in the ACT
    17,241
    haven't seen any wear yet - but ive only hung the hoist off the engine hoist... and moved it around.
  10. #580
    10,303
    Valid question actually for the Aldi Wattyl gear, has anyone actually used it and then given it some abuse in a typical car enthusiasts garage with oil spills, engine cranes and tools thrown about in disgust at yet another fucked Z32 piece of shit destroying your life and sanity?
  11. #581
    Registered User Zutroy's Avatar
    Mar 2014
    Brisbane / Toowoomba
    165
    I bought 3 of the Wattyl satin kits from Aldi at the sale. Used 2 yesterday on my 6x12m shed (other one is for the garage on the house). The etching/wash seemed a bit thin across the ground and wouldn't shift some stains. Has come up alright but the patchy finish is due to the operator (first time using a roller). The first quarter of the shed is a bit average because my roller tray was too small and wasn't getting good coverage on the roller. Once the nopics raced to the hardware and grabbed a bigger tray morale and uniformity improved. Looks shit hot where I had a shit ton on the roller or did a second coat with the leftovers. Other parts look a bit meh and really needs a second coat. But at the end of the day it's quite an improvement over the bare concrete and I probably won't care once there's cars parked on it.
    Halfway through
    Finished, 1 day later (glassy bits are areas of overlap between sections)
    Paul
  12. #582
    Caught in the ACT
    17,241
    the saw cuts in my floor that i filled and painted over have cracked - as the paint guy told me they probably would - the cracks are less annoying than the slots... bfw.
  13. #583
    6,501
    What did you fill with. A good epoxy shouldn't shrink enough to crack
  14. #584
    U gon dun wha now? Speedyblue's Avatar
    Mar 2007
    Queensland, The Tax State
    1,105
    Quote Originally Posted by GSRman View Post
    All the cracks in my slab were cut and filled and still show no signs of cracking 5 years later. But my slab is pretty stable overall. Any signs of movement in the slab as if it's still moving, cracks will appear?
    Ya'll don't know what it's like. Being male, middle class and white.
  15. #585
    Caught in the ACT
    17,241
    The rustoleum specific 'use this expensive one'
    it's a big slab - im not upset about it - just posting it as information.
  16. #586
    May 2016
    Maitland
    72
    Going to epoxy my shed tomorrow, are 13mm rollers ok for epoxy or should I go shorter
  17. #587
    May 2016
    Maitland
    72
    Quote Originally Posted by stocko View Post
    Used a 10mm it was fine. Concrete sucked up the epoxy. I'll be buying another kit.
  18. #588
    Registered User BiH's Avatar
    215
    Some good tips in this doc. The jotun coatings are top quality as well.
    Jotafloor Easy Painting Guide for Concrete Floors brochure
    https://jotunimages.azureedge.net/images/images/Jotafloor-Easy-Painting-Guide-for-Concrete-Floors_tcm189-5703.pdf
  19. #589
    Oct 2014
    15
    Just been through the exercise. Would do it again. It wasn't too painful and a lot cheaper than my last shed which I paid a pro to do.
    Most of the 12x6 shed was a granny flat prior so once all the bullshit was ripped out the slab was pretty clean due to being under Lino or carpet (Lino glue was fun to remove....) But I still followed the degrease, etch then paint process most on here used. I could have done a third coat I reckon but run out of time to allow it to dry and get my shit out of this horrid wet weather we have had the last few weeks. Good enough for now to keep my OCD at bay while I finish making a mess on it. Used PPG EXT 2k epoxy.
  20. #590
    124
    Just got this done through NuLook floors.
    Garage floor is 5.6mx2.5m
    Cut the concrete so it was 100% flat, bogged any imperfections on the slab, primered, 2 x coats of expoxy, spread the flakes through then 2 coats of clear, came out excellent.
    $1100
    sorry for the side pic
Name:	GARAGE FLOOR.JPG
  21. #591
    Registered User eatabag's Avatar
    Of dicks
    82
    Where does Juan find a colour palette for the epotec 370? Also can any old bloke walk in off the street and purchase this?
    Quote Originally Posted by Marv
    "The bitches," he proclaimed, "are wet"
  22. #592
    Ellis Juan mizone's Avatar
    4,203
    30% off the Rustolelum at Supercrap tommorowz.
  23. #593
    Probationarily unbanned
    5
    4,132
    Quote Originally Posted by eatabag View Post
    They'll colour mix it to whatever you want, they do have some standard colours but that's just to make choosing easier and yes, you can just walk into a PPG dealer and buy it, noting my post earlier about it getting a new name.
  24. #594
    Registered User Captain Kermit's Avatar
    Dec 2012
    Newcastle
    335
    https://www.supercheapauto.com.au/sh..._2019_WK10_FRI
    Supercheap have 30% off rustoleum floor coatings for 3 days. Don't actually know if it's good value, figured I'd throw it in for the experts to judge.
  25. #595
    Registered User Uwish's Avatar
    Jul 2002
    1,827
    I also used Nu-look flooring. Will use them again when I build my new house
