Page 27 of 28 FirstFirst ... 17232425262728 LastLast
Results 781 to 810 of 834
Thread: 1966 Alfa Romeo Giulia Sprint GT Veloce
  1. #781
    16,053
    I figure it's probably hard enough to keep one in good nick and one piece as a street car let alone thrashing it in the dirt. I've not looked in to it but I imagine it has some supporting chassis mods to keep it one piece.
    Nope. Even has the stock rear control arms, which is why the back tyre is almost eating the corners of the rear arches. Not even a sump guard. At least it was a shitbox to start with.
    I've just seen a vid on Hoonigan of it being jumped (smashing the sump, and driing it into a fence). Retards going to retard. And judging from the way the filler spouts came off the jerry cans on the roof, it's never, ever been "offroad" (All the photos of it "offroad" are places I could get in the wagon).
    https://www.facebook.com/TheHoonigan...4511147903243/
  2. #782
    16,053
    full vid:
  3. #783
    PF Brisbane Cuntarm
    17,164
    Yeh ok, that's all the stupid.....fucking hipster youtube wannabe cunts.
    16,053
    Some minor progress last night. Input shaft rocked up, robbed the shift forks from the spares box - there was about .4mm wear on one fork, the spares box had zero wear on the forks (immaculate synchro rings too, but all the dog rings were fucked - a really weird mix), installed the bearing and synchro assembly on the input, slotted it all into the box and measured to check the shim stack - spec is 42.0-42.2mm across the back of the 3rd and 4th dogs, measured at 42.1/42.15. Might swap a shim in the stack to tighten it up by .05.
    Need to rattle the yoke off the back of the main shaft and install the 5th/reverse selector ring, 5th gear assembly and rear bearing (used an old one as a spacer), can then button up the cases.
    End of play last night:
    Attachment 104729
    So since the above post, the other half of the gearcase has been on and off twice now, and is hopefully on for the last time! (first time, recenter the shift forks - forgot to put the detents in to lock them up properly, second time I discovered that I'd dropped an interlock tic-tac when I had the cases apart, didn't waste time looking for it and just robbed one from the spares box).
    Flywheel cover, clutch cable holder and exhaust hanger all got a tidy up and fresh coat of paint last night, bellhousing and tailhousing should go on tonight.
  5. #785
    16,053
    Gearbox is buttoned up and ready to go back in (tonight's job).
  6. #786
    16,053
    Gearbox is in, looks like the rear crossmember needs some hydraulic press love next time it's out, it's been flattened a little and the holes are further apart than the captive nuts in the shell now, just enough to make it hard to get the bolts in. Also stuffed my left shoulder because the car isn't high enough to let me get under the box to lift it.
  7. #787
    16,053
    Last night was filling the box, buttoning up the starter, discovering a broken dizzy cap, discovering that the new, allegedly copy of a NOS clutch cable, not only had a clevis end that was for a 6mm pin (drilled to 8mm easily enough) but had a slightly taller clevis that means I need to make up a new, taller clevis pin. After the weekend I'd had, I couldn't be fucked firing up the lathe, so I filled the box, reassembled the interior, discovered that the new shift knob doesn't fit that well and refitted the old one with the manky grommet, and went to bed.
    Jobs for tonight: Find and fit the front exhaust clamp that doubles as a hanger (where the fuck did I put it?), make a new clevis pin, re-seat one of the rear springs that I noticed is not sitting quite right and bang the nopics.
    Then reconnect the battery, give it a wash because it's friggen filthy, and enjoy.
  8. #788
    PF Brisbane Cuntarm
    17,164
    Depending on what else you find, that might be a super angry bang!
    16,053
    Lol. I'm too tired for that!
  10. #790
    8,936
    UpDates?
  11. #791
    PF Brisbane Cuntarm
    17,164
    He was tired from cars so ended up thumbing in a softy.
    16,053
    Yeah, only got one of those things done, then had to travel for work. Sorted the missus last night when I got back though.
    Threw a high tensile M10 bolt into the lathe, turned it into a custom length clevis pin, then heated it red hot and dumped it into some oil to flame harden it. That'll get fitted tonight, the spring re-seated on the way off the jack stands, and job done.
  13. #793
    16,053
    Old vs New:
    Car is back on the ground - you kinda forget how low it is when it's been up on stands for 2 months. Would have been much less if I hadn't had family holidays, fixing the daily driver and assorted other shit chewing up weekends.
  14. #794
    8,936
    Good work on the cleavis pin?
  15. #795
    16,053
    Finished it up with a wash and a test drive on Saturday morning. It works, seems to work pretty well too. Had forgotten how loud the loud pedal is with the open carb trumpets.
  16. #796
    9,227
    This is one car I'd love to see a video of getting driven in anger.
  17. #797
    16,053
    Probably best filmed from another car - I've stuffed around a couple of times with camera placement and for the video to be any good i have to have the windows up to kill wind noise, and I flat out hate driving it with the windows up. Otherwise the camera needs to sit on the windscreen and that's boring as shit.
  18. #798
    3,302
    get a lapel microphone with one of those fuzzy covers and tuck it into the centre console or something? im actually planning on doing exactly that with the adub as the gopro mount transfers too much engine vibration into the camera
    1988 AW11 9A-GTE - project #1 | 1980 KP60 4K - project #2 | 1994 UZZ31 Soarer 1UZ-FZE - Cruise missile
  19. #799
    16,053
    The camera I've got doesn't have an external mic jack or anything. I tried using the waterproof case for it to muffle the wind noise, but the frigging thing fogged up.
    Just had a thought, about 15 years ago I used some pelican case pick and pluck foam for a mic baffle on the outside of a helicopter, might try taping some over the camera mic location next time... just happen to have a chunk of pick and pluck infront of me.
  20. #800
    PF Brisbane Cuntarm
    17,164
    I've done this on my bike before to good effect as the older Go Pro's were fucking shocking for wind noise.
    16,053
    So, I realised during the week that I'd accidentally filled the box with Redline 75W90 instead of 75W90NS - the friction modifier that counters LSD chatter does unkind things to the Porsche type synchros - luckily I've only done maybe 8-900km in it, so after going to Cars and Coffee, I dropped the gearbox oil. Because of the filler location, it's actually easier to lift the carpet, strip the gearbox boots and shift lever and fill through the shift tower - even if it probably adds 15 minutes of R&R to the job. I probably should have done a diesel flush on it, but it seems to be coming good.
    Drove home from C&C with some guy in a red beetle - he took some pics on the way. Really highlights how small these cars are in modern traffic.
    Crap photo I took at C&C.
    Will try and get some in car vid in a couple of weekends time.
  22. #802
    The royal penis is clean tremolo's Avatar
    Jul 1979
    Zamunda
    4,836
    Nice!
    I love riding in/driving my mates one, the way you look up at Mazda 3s like they're CX9s in traffic is hilarious.
  23. #803
    Moderator Cal's Avatar
    Nov 2002
    Brisbane, Queensland
    22,085
    I enjoyed that drive back. From Coorparoo the cars don't even get warmed up.
  24. #804
    Registered User the big fist's Avatar
    1,145
    Great pictures. Looks fantastic going down the road.
  25. #805
    8,409
    Cheers for the invite kents!
    Nov 2002
    22,085
    ^to cruise back from C&C that you didn't attend?
  27. #807
    16,053
    You mean this one?
    http://www.performanceforums.com/for...#post842972071
  28. #808
    16,053
    Skiiiiids.
  29. #809
    1,145
    And looks damn fine doing it !
  30. #810
    16,053
    It needs better tyres. These Falkens are terrible in the slighted bit of wetness. The above photo was probably not far off walking pace.
