Results 1 to 17 of 17
Thread: Removing deep scratches from aluminium?
    At work :(
    18,018
    I have an aluminium petrol tank on my bike. Unfortunately it has a couple of deep scratches in it. Is there any way of "sanding" this back to remove the scratches? Simple polishing won't work.
    (TM - AVENGE)
    Away
    18,150
    yes...use a flapper wheel...then go finer & finer with sandpaper until its all gone, then polish with autosol or similar.
    It will probably take ages!
    At work :(
    18,018
    Cheers. Might have to look into it.
    (TM - AVENGE)
    Away
    18,150
    Get a big one of these & work over a big area so you dont get a step. I assume it will stay polished & not get painted? Also assuming the scratches are on a bit which is curved in at least one direction, not a nice easy flat bit that you could sand back really easily using an orbital sander or something.
    Fondles
    Guest
    How deep are the scratches and how thick is the tank ?
    At work :(
    18,018
    Thanks again edo. Yes will remain unpainted.
    Fondles - the scratches are only a mm or so deep. Its just too deep to just buff out. The tank is pretty thick. Its a custom jap style tank.
    (TM - AVENGE)
    Meh
    Jan 1970
    26,940
    So it really will buff out?
    10,457
    ^^hehe let's hope so in this case, will be a first.
    TOKEN AUSSIE BOGAN tut's Avatar
    stupid sexy flanders
    6,544
    scratches should be removed from the skin as soon as possible. The preferred method for scratch removal is by blending the scratch out. Scratches are starting points for corrosion.
    If scratches in clad aluminium are to be removed, it is necessary to examine wether the scratches have gone through the cladding
    if you want i can give you the test for this, too..
    722
    More rabbit less turtle!
    http://www.Tutter.net
    12,348
    http://catalogue.3m.eu/en_GB/GB-ASD/...ing_Disc~SC-DB
    You need to find someone who welds and finishes aluminium and get them to use a series of surface conditioning discs to remove the scratch and then finish it ready for polishing. Flap wheels are terrible cause they load up. Sandpaper scratches it and takes heaps of finishing to get rid of.
    Scotch brite by hand is the way to finish it to a brushed look if that is what you are after.
    Away
    18,150
    I took out heaps of scratches on various bits of TRX just as I described...worked a treat...
    If I had of thought of those scotch brite wheels I might have used them...but seeing as though I had the flapper wheels I probably wouldnt have bothered going out to get the scotch brite ones due to being a slack arse.
    At work :(
    18,018
    Will take a picture during the weekend so that you guys can get a better idea of what I'm talking about.
    (TM - AVENGE)
    ...... marcus_h's Avatar
    1,365
    Slightly off topic.
    How do I get my alloy bullbar looking all shiny? Ive tried autosol but it doesnt seem to get it mirror and without a buffer is a pain in the arse. Any other products out there?
    Registered User RX-20B's Avatar
    372
    Wet and dry sand paper, 180 grit, 240 grit and 400 grit.
    Use the right buffing wheels and polishing compounds on a good bench grinder.
    I JUST SHARPENED A PENCIL IN MY BUM AND NOW I NEED A BANDAID
    12,348
    Quote Originally Posted by marcus_h View Post
    Slightly off topic.
    Alibrite.
    http://www.septone.com.au/detail.asp...395&page_num=9
    Edo- well done. I'm sorry I trod on your toes but generic abrasives aren't great on on ferrous metals. Well done that your flap wheels worked for you.
    1,365
    Cheers i'll give it a go
    Ready... Take aim... oldcorollas's Avatar
    Apr 2004
    floatin around
    2,225
    why not fill it in instead? might be better to add a mm depth of filler, then to remove a mm from a large area of tank...
    "I'm a retarded Doctor, not a retarded Mechanic"
