Page 25 of 25 FirstFirst ... 152122232425
Results 721 to 744 of 744
Thread: Building MX5 Time Attack Cars
  1. #721
    On the Shelf
    5,142
    A claw hammer......?
  2. #722
    Bentleigh Victoria
    3,132
    Quote Originally Posted by jimmyg View Post
    You do seem to change you plans a wee bit dont you.
    Not really, it started as a Time attack car, now being built as a 2B race car. That's only one change. 😊
    Claw hammer was to hit the spanner to loosen the exhaust manifold nuts.
    I will port the wastegate and the manifold flange this morning. And hope that fixes the boost creep when the 3" exhaust goes back on.
  3. #723
    Bentleigh Victoria
    3,132
    Pic of the inlet side of the head, and another pic showing the size of the tiny turbo going on.
    image url upload
  4. #724
    Bentleigh Victoria
    3,132
    Ported the flow to the wastegate and unshrouded the exit path. And decided to open up the manifold for good measure.
    image hosting 12mb
  5. #725
    canberra
    3,437
    That's a lot of nasty cast iron splinters to deal with, ouch
    GT8
    1UZ Celica
    1.07 flat Wakefield Park
  6. #726
    Bentleigh Victoria
    3,132
    Better than carbon fibre splinters.
  7. #727
    Bentleigh Victoria
    3,132
    I figured I should check the port match from the head to intake since I am changing intakes. Lucky I did, the manifold is almost 15mm too low. I think this is a GTR head, not an MX5 head. Would explain it. So now the inlet has to have bits welded to it, and all the holes redrilled. I picked up the 1000cc injectors. I assembled the 3.6 Torsen diff, replaced the bushes with nolathane and fitted the lot into the car. PPF is on, tailshaft is on, the whole exhaust is on. The worst part is trying to find the nuts, bolts and bits that I removed 6 years ago.
    adult photo sharing
  8. #728
    syd
    2,480
    would the block have the familia guts in it too?
  9. #729
    Bentleigh Victoria
    3,132
    I will have to try find the old paperwork from the build. I can't remember everything that was done to this motor. I do recall him saying the block was a very low k one. It has forged rods and pistons, etc. The bottom end was about $5000 or more. Has some rifle drilled things, chamfered oil galleries and modified oil pump from memory. Not sure if it is an MX5 block. I do remember giving him 3 heads (2 turned out to be soft), and in the end he swapped the head he was going to use with this one as a guy spent a lot of money on the head, and then wanted my head to fit into some class.
  10. #730
    syd
    2,480
    ahh ok
    getting a handle on whats compatible with what is in the back of my mind if my motor pops.
  11. #731
    Bentleigh Victoria
    3,132
    If your tune is right and you do regular oil changes, there is no reason your motor will pop. I thrashed these motors in stock or near stick form with turbos. It doesn't bother them. Only failures where my fault- first time was a radiator hose came loose, overheated and melted the Pistons. 2nd time was a guy screwed the wastegate so it wouldn't open. Over boosted on a stock $300 motor.
  12. #732
    syd
    2,480
    good to know
    i better get my heap to a tuner to check i suppose
  13. #733
    Moderator Cal's Avatar
    Nov 2002
    Brisbane, Queensland
    21,489
    I've never seen an MX5 exhaust welded to a subframe brace like that. Does it cause vibration or manifold cracking at the other end?
  14. #734
    Bentleigh Victoria
    3,132
    The hanger is a bit like a subframe brace I suppose. I ran it like that in the silver car and it was fine. The engine mounts are as close to solid as you can get. And there is a flex join. I think there is more stress mounting on rubber hangers. The exhaust moves so much around corners. This way nothing can move at all.
  15. #735
    Bentleigh Victoria
    3,132
    I am trying to finish cleaning the garage, and I have told myself that instead of moving parts around that go on this car. I may as well install them. It's not really working on the car, it's putting parts away properly. But like the diff, it can't just be installed without doing some prep. I bolted the door inner halves on properly. But had to remove some metal from the hinges. They are not that heavy, but when you hold the (sub 2.0kg) door, it's front heavy with the hinges on.
    image ru
  16. #736
    14,697
    Are you keeping an eye on the rule book as you go?
  17. #737
    Bentleigh Victoria
    3,132
    Nope, well I did try. Am I doing something wrong? I did ask and was told I can run c.f doors, roof, bonnet and boot.
  18. #738
    14,697
    It's forever since I looked at the 2B rules, tis why I asked.
  19. #739
    Sep 2014
    Ballarat
    233
    2B Art 3.9 permits removable non-swinging panels to be replaced, bonnet and bootlid as well as outer door skins (in this case, intrusion bars are required) are specifically mentioned. Since Art 3.9 by implication does not declare the door frame to be free construction, methinks that CF door-frame may well be a yard too far. David - form your own opinion. I'm not too sure that anyone cares, BUT the door frame is not specified as free and therefore should be OEM
  20. #740
    Bentleigh Victoria
    3,132
    I don't know why there isn't an English translation somewhere. How hard would it be to write up some rules that someone like me can understand?
    I spoke with Owen who has been doing Prod Sports for years. He told me it was ok to run c.f bits. At the end of the day if I need to swap something over (like doors - 30minute job) its not a big deal. I will build it with all the carbon fibre bits and do a few track days until the car is sorted. Then get it logbooked and do any changes. But it should be close to being right once it built.
  21. #741
    Cronulla
    1,263
    There isn't a class in motor sport where you can understand the rule book.
    turbosurfer
  22. #742
    MX-5 Hairdresser bbeavis's Avatar
    Oct 2012
    131
    They make it convoluted so that they (the governing body for the class/competition) can swing the rules to suit depending on who the competitor is and how they want to influence that competitors success.
  23. #743
    Bentleigh Victoria
    3,132
    I had to get the NB8B inlet manifold bolt holes changed to suit this head. Then port match to the head. The Injectors are assembled and installed. So basically the motor is all together. Next is to bolt on the intercooler and intake/pod filter. Then that's pretty much the engine done once the oil filter/cooler set up goes on. Finding the time to work on it now is becoming scarce.
  24. #744
    Bentleigh Victoria
    3,132
    This car is now on its way to China as scrap metal. R.I.P.. I decided to give up on it as I lost motivation to finish it. The mechanicals and bits are going into the red NA MX5.
