Page 4 of 25 FirstFirst 1234567814 ... LastLast
Results 91 to 120 of 744
Thread: Building MX5 Time Attack Cars
    Bentleigh Victoria
    3,517
    O.K, so it's not as bad as that guys.
    4,845
    just need to find the right craftsman to weld it up correctly
    Bentleigh Victoria
    3,517
    I had an engine builder look at it, he said it can be fixed, but it will be cheaper to port a good second hand head rather than to rebuild this one.
    Bentleigh Victoria
    3,517
    The guys at meridian did a great job on the cage. Now it is time to clean up the shell and get it ready for all the c.f panels.
    Bentleigh Victoria
    3,517
    Took a pic of the other car. We haven't started on them yet as we where working flat out on the old mx5 rebuilding a new motor and getting it ready to race. It is done now so we can start on the new ones. I will do the widebody moulds first.
    Registered User matt b's Avatar
    brisbane,qld
    1,574
    Subscribes
    I do not like V slicers.
    "Give it the full rissole son" random old mate 2011
    "If you can't fix it with a hammer it's electrical" Hoops 2007
    Bentleigh Victoria
    3,517
    I got a start on the widebody tonight, it's about 45mm wider each side.
    Jul 2010
    798
    A mate of is thinking about one of these. I'll send him this way. Love the carbon!
    Bentleigh Victoria
    3,517
    I think they can be a pretty quick car.
    Here is a pic i found with the fuel tank hump, parcel shelf and seatbelt towers surgically removed.
    later
    Queanbeyan, Australia
    4,617
    The car weighs 1026 from factory. I reworked out the numbers. It would be minimum 260kg's of stuff that has come off that won't be needed. Replacing that with about 60-65kg's of new stuff. Plus cage 40-50kg's Minus metal removed 20-30kg's. should weigh between 836kg's and 861kg's finished. We will see at the end how close i get. It is not so easy getting them under 800kg's. I will be looking into making a jig to replicate the subframes in tubular steel as well as all the suspension arms. That should save another 20+kg's.
    1026kg for an MX5? Jesus, my 121 was just over that with a full tank of fuel and me in it. And mine was a lardarse, towbar, A/C, driving lights etc.
    Bentleigh Victoria
    3,517
    I had a mighty boy ute years ago that weighed just a bit more than the steak i had for dinner. Doesn't mean it makes a good track car. Not with the 3 cylinder motor and 2 speed semi auto box anyway.
    later
    4,617
    Don't get me wrong, I know the MX5 is a better track car. I was just suprised how heavy they are compared to the similar sized, and porky, 121. I guess Mazda made the MX5 stronger then I thought, never really thought about how strong they were before.
    Bentleigh Victoria
    3,517
    Being a ragtop they need to put in a lot of extra reinforcing. But they did try to keep the weight down all the same. I don't think they are too heavy, but they still need to go on a diet to be quick, seeing as we don't have 500hp to throw at them.
    Bentleigh Victoria
    3,517
    I went up to winton and set a new p.b of 1:36 with my new kumhos, and then i decided to put the old toyo's on and just do a few laps as i didn't want to wear out the kumhos. The toyos felt really good even tho they were cold, and i was showing off a bit doing power slides in front of the crowd. It just went out too far. Hopefully i will fix it quickly.
    If you can't see tread on that rear tyre, that's because there isn't any.
    Moderator Cal's Avatar
    Nov 2002
    Brisbane, Queensland
    22,162
    Opps is that a wrecked 6UL or 2?
    Registered User tinkerbell's Avatar
    3,018
    good to see that such light rims can take a bit of a hit?
    Bentleigh Victoria
    3,517
    The rims appear to be fine as they hit flat on. I just gotta scrape off all the paint (from the wall) and get them spun up on a balancer to check.
    Bentleigh Victoria
    3,517
    I am now getting the NB ready for track work with all the gear from my NA. First thing i did is cut out some more metal and remove the sound deadening and seam sealer, as well as any brackets and bolts that looked a bit shifty.
    There is a hole in the boot floor.
    Engine bay ready for paint.
    Painted the cage, didn't like the colour, so doing it again in the gt3 rs highlight colour as well as the engine bay and other bits.... like the gt3 rs.
    Bentleigh Victoria
    3,517
    I have upoaded a few videos to youtube. Here is a link, click on more videos from me once in there to see the others.
    http://www.youtube.com/watch?v=ouLgTmocZ_s
    Bentleigh Victoria
    3,517
    Painted the engine bay, but for some reason the pics come out looking pink. The colour is actually bright orange.
    Bentleigh Victoria
    3,517
    Painted the cage. Just have to paint the floor now then i can get a start on assembly.
    Registered User fattima's Avatar
    Aug 2010
    436
    Looking good mate.
    What paint did you use?
    Bentleigh Victoria
    3,517
    2k clear over base. Which means you have to paint it 3 times. I painted it the first time with cans, (primer then orange) but it was shyt. So i got some rags and thinners and washed it all off. Wasn't too hard, but still took about 3 hours. Then i prepped it again, used 2k primer, put the patio heater on it for a couple of hours, then put the colour on, patio heater again, then cleared it. And you guessed it patio heater again......
    Took most part of the day to do.
    Bentleigh Victoria
    3,517
    Inside is painted now. It took me hours to mask.
    Bentleigh Victoria
    3,517
    Finished the painting.
    Opens HoonBoy's Avatar
    9,820
    Cool, time to get busy with the mechanical bits
    Bentleigh Victoria
    3,517
    I am going to get a start on it, but unfortunately i have to go up to brisbane for 3 days to tile a good friends pool area. About 100m of 600x600 granite. I hope the slab is good.
    Nov 2002
    22,162
    Wow nice cage.
    HoonTV RotaUte's Avatar
    Phucknose
    4,471
    Either way, looks good. Doors etc staying raw carbon?
    Newest member of the PF divorce club
    Bentleigh Victoria
    3,517
    Yer, it looks pretty good. All c.f panels will be finished in a clear coat to help with longevity. It will be easier to put stickers on and off.
    Here is another pic of the cage.
