Page 153 of 165 FirstFirst ... 53103143149150151152153154155156157163 ... LastLast
Results 4,561 to 4,590 of 4948
Thread: Trailer Towing the Einstein way....
  1. #4561
    Sonova Beach
    5,756
    He means Air brakes, how'd he generate the air to "Un-lock" them.
    Correct.
  2. #4562
    8,563
    You do know you can mechanically release air brakes?
    Fwiw, the truck looks like an F450. They're rated to tow upto 8.6 tonnes using a bumper pull, ie ring feeder/pintle hook/Barnet ball.
    If he's serious he's probably got a dedicated air brake system for the trailer anyway, know a few people who have air brakes for their 5th wheel RVs being towed by F450s.
  3. #4563
    Jan 2006
    5,756
    Correct.
    realised it as soon as I hit post, i blame a long day and the silly session. Carry on then
  4. #4564
    Nov 2017
    486
    CSH. He obviously was towing it so he obviously had a way to override the brakes or use them. I donít know what F truck it is but as above probably a F-450 the thing is not far off being a fucking truck. A F-650 would probably out tow some trucks that are prime movers.
  5. #4565
    Sep 2007
    532
    Or he just adjusted them until they were released. Just need a shifter...
    Ring feeder will just drop over a standard 50mm ball. Nothing to stop it bouncing off but I do it in the yard occasionally
  6. #4566
    Nov 2017
    486
    Quote Originally Posted by Fiona View Post
    You can buy balls with a latch to stop the ring from jumping off.
  7. #4567
    Ellis Juan mizone's Avatar
    3,888
    Quote Originally Posted by XAlent View Post
    Umm, If that's empty then it's within the tow limit and brake of the F 350. I don't understand what's wrong, unless he hasn't unlocked the brakes and was dragging it down the motorway
  8. #4568
    Canberra - ACT
    3,066
    Isn't there a license limit on Gross Combined Mass for us schmucks with regular car licenses?
  9. #4569
    LASERs `R' Us JamesB's Avatar
    Corberrie, Nova Scotia, Canada
    2,812
Name:	ball and pintle mount.png
    They're called an "Integrated Ball and Pintle Hook". I'm looking at one for situations where I need to go past the 7000lb rating on my forged ball mount. A 12,000lb Reese integrated ball and pintle mount is cheaper than buying a drop forged ball mount plus a ball that both have more than a 7000lb rating (need 7500lb rated fittings to rent the heavy duty U-Hail car trailers, as U-Haul checks the ratings on your hitch before they'll hook up the trailer).
    James
    Quote Originally Posted by Malcolm Nance (35+ years in US Intelligence)
    Coincidence takes a lot of planning!
    1989 Jaguar XJ-S V12
    2008 Chrysler Aspen Limited (mini van on steroids)
    2003 Land Rover Discovery SE7
  10. #4570
    2,812
    Dunno what it's like back in Oz, but here, my standard Class 5 car license here allows me to drive any single vehicle not in excess of 14 000 kg (30 864 lbs.) G.V.W. or a towed vehicle combination of the same limit providing the trailer does not exceed a G.V.W. of 4500 kg (10 000 lbs.). Air Brakes require a separate air brake endorsement.
    James
  11. #4571
    8,563
    If that's an F450 which it looks like it is, he'd need at least an LR license anyway since the GVM is more than 4500kg. Unless some idiot derated it to 4495kg in which case an HSV Maloo has a greater payload capacity.
  12. #4572
    14,540
    Not sure if they have a hard limit, IE no more than Xkg. But listed ratings change between cars.
  13. #4573
    Registered User Falc&Send's Avatar
    Nations Capital
    2,827
    There are countries out there where an articulated vehicle license is required, even for a 6x8 box trailer.
    But something definitely needs to be done. I'm on the road enough to see towing-related incidents on a weekly basis. Sure, some stacks are just sheer bad luck, but a lot of it is caused by total idiocy.
    Should be in Oz too, you just need to look at all the incompetent numpties at the rubbish tip/Bunnings on Saturday mornings trying to manoeuvre their box trailers around
  14. #4574
    Nov 2017
    486
    Quote Originally Posted by Falc&Send View Post
    I'm a numpty at manoeuvring trailers but I know this so I refrain from trying.
  15. #4575
    Happy Little Boozer NicholasY's Avatar
    Tassie
    35
    My guess (based on Tassie rules) would be that the trailer has a GVM (maximum loaded mass) over 9 tonne so is classified as a heavy trailer. The F-Truck is likely registered as a LR truck, and so isn't allowed to tow a heavy trailer, needs to be registered as a combination truck to be able to. Even if the trailer was empty and is less than 9t the rules are still based on GVM.
    Could have been perfectly safe and within towing limits (if empty and brakes working) but doesn't meet regulations.
    Air brake kits are available so it may have functional brakes. http://5thwheelers.com.au/product/air-brake-kit/
  16. #4576
    240
    This came up in my facebook memories the other day from a few years back
  17. #4577
    Nov 2017
    486
    Quote Originally Posted by Andy San View Post
    Is that trailer made to tow cars like that?
  18. #4578
    Sonova Beach
    5,756
    Common in Europe and the UK.
    Not so much here. Worked for a place that had one to do auction runs.
  19. #4579
    2,812
    Standard 2 wheel dolly trailer. Very popular in North America, especially for towing FWD cars. About half the cost to rent from U-Haul as a proper car trailer. In Canada, the catch is that because 2 wheels are touching the road, the car being towed needs to be both licensed and insured.
    James
  20. #4580
    Mar 2017
    xxxxxxxxxxxx
    1
    Trailers often have a yellow service button alongside the red 'park'
    yellow releases enough air from reservoir tank on chassis rail to release brakes in order to just move it
  21. #4581
    Jun 2007
    Yeppoon
    4,069
    In Launceston...
  22. #4582
    Gippsland
    186
    This just popped up on the local buy/swap/sell group.
  23. #4583
    Sep 2007
    532
    SA Police are doing a blitz on trailers tomorrow if anyone is out and about
  24. #4584
    Sonova Beach
    5,756
    Not sure what's more fucked, the Patrol or the trailer it's on.
  25. #4585
    9,328
    3 axles just means you have two spares
  26. #4586
    Registered User womblesti's Avatar
    May 2004
    1,959
    Saw an old speed boat being towed yesterday. The bar below the prop was only an inch of the ground and on closer inspection the tandem trailer only had one axle.
  27. #4587
    2,812
    Probably should have gone in the YouTube topic, but ...
    James
  28. #4588
    Defective Faux Forg's Avatar
    Sydney Traffic
    1,583
  29. #4589
    Tycoon Donald Trump's Avatar
    Jan 2015
    Off White House
    630
  30. #4590
    6,083
    I dunno if this fits here. But whatever...
    CJM 4 Life yo!
