Page 4 of 32 FirstFirst 1234567814 ... LastLast
Results 91 to 120 of 937
Thread: 13s for $1300
    Opens ALLMTR's Avatar
    Newcastlish
    23,489
    Ea falcon + au motor with holley 4 barrel
    24,324
    Quote Originally Posted by OKE020 View Post
    I was just thinking manual if you could find a car with a good clutch still. Should be way less effort to get it to 60', budget does not allow for convertors etc, should also be ok with the tall diff gears then to.
    From a quick read around there is not much head room in the standard fuel system so maybe 1 or 2 additional stock injectors in manifold supplied with fuel via there own pump and lines. Maybe even rig up a cheap tank with slighlty higher octane brew to mix in under boost. Hobb switch could activate the extra injectors, come to think of it might be easier to use the pre mpi engined car so can run a staged set of injectors using the drivers from the stock 2 injectors.
    black malpassi 1.7:1 FPR sort out extra fueling?
    Country Member Boxer's Avatar
    Around the corner
    3,106
    Quote Originally Posted by Asteroid View Post
    Long time fan of the N12, shame you would be hard pressed to find one these days.
    Back up plan Pulsar ET turbs, same hairdrier on 25psi, cheap water meth and s/h drag bags should see 14's easy, gutted, maybe dip into 13
    Jul 2010
    Newcastle
    2
    Old turbo Ovlov, FMIC, exhaust, boost. Ebay spec turbo upgrade if needed. I reckon it would shit it in. Manuals might not fit in the budget tho and I don't know how well the autos hold up.
    Talga Vassternich Stalker440's Avatar
    2,436
    N13 pulsar Vector has extra cubes to play with, weigh fuck all too...
    Quote Originally Posted by thecrackfox
    I wanna put you in a dress and hurt you...
    11,230
    Old mate ran 175rwkw and 13.7 with stock ECU and AU injectors. I assume only 6 of them. But an extra injector setup with E85 would be cheap and full of even more win. Manual would be the go but there will be a manual tax. I also have my doubts on the clutch holding up. I thought 4.11s and a smallish turbo would get the auto to 60 OK. You can get a pintara diff for $50. Plus I believe the power this car would have would real it in like a 12 sec car in the deep end. However I do know a usual EL etc is pathetic off the mark usually! The question is would the gears and smallish turbo get it to launch?
    10.83 @ 125
    Around the corner
    3,106
    Quote Originally Posted by komori440 View Post
    You'll spend too much on custom manifolds, decompressing and shit.
    N12's already Turbo
    Bush Mechanic mick.wheelz's Avatar
    Aug 2010
    Brisbane AU
    18
    Camry (either 3SFE or 5SFE powered) - $200ish
    e.g
    http://cgi.ebay.com.au/Toyota-Camry-...item3a61862fa0
    5SFE Rev 2 would be preferable, as it has a knock sensor and makes a fair load of torque when turbo'd
    a new head + gasket kit would be under $200 for the above camry
    3SGTE CT26 stock turbo + manifold + dump - $200 or less (i got mine for $170)
    Dodgy ass exhaust - $100
    Cheap ass boost tee - $20-50
    2bar map sensor - $20-50
    300cc+ Denso injectors - $50 (maybe)
    Ebay ass IC and piping kit - $200
    Misc shit - $200
    Strip as much weight as possible from the camry, turbo/etc will just bolt on, retard the arse out of the timing with the dizzy, chuck in the 2bar map and new injectors, set to 16psi and prob crack high-mid 13s.
    Meh
    Jan 1970
    26,940
    AE-70.
    4AGZE.
    Cheap turbo + home-made manifolds.
    Not sure of the costings of that sorry but if you did enough scrounging it should be close.
    Jun 2007
    no longer Wollongong
    47
    AE-70.
    4AGZE.
    that's what I was thinkning... could probably do it even cheaper with an AE82
    Dirt Turbo Gavatron's Avatar
    397
    Quote Originally Posted by mick.wheelz View Post
    e.g
    Misc shit - $200
    This has merit. Thinking this wouldn't work with the stock 5SFE computer, then reading one link about using the 'magic triangle' of parts changed my mind completely.
    http://warp.scl.utah.edu/mr2/Turbo5sfe.html
    12,894
    valiant with 265 - free to $200
    4bbl manifold with holley -$200
    2nd hand hot cam and new lifters and valve springs - $200ish
    cm val manifolds and bodged up exhausts -$20
    1c mod on bw35 - 1c
    pintara gears + falcon LSD - $150
    historic rego - $80 per year.
    done. total $850.01 and still enough left over for a n2o kit to get you deep into 13's, maybe even 12's with borrowed slicks and a convertor
    2,643
    Build me that car and i'll give you 1k for it
    2JZ KE20 Corolla 7.97 @ 178
    SR20DET Gemini 8.70 @ 157
    1UZFET KE20 Corolla 9.60 @ 140
    http://www.oke020.com
    12,894
    lol. id love to do it, all i need is an auto column and pitara gears and id have all the stuff to do it too! gotta save for wedding though
    how about i build it and i let you race it for me since ill be a poor cunt
    2,643
    Tell me about it, christmas just wiped me out real well
    12,894
    the car will be garaged 10mins from heathcote raceway too..
    fuck it. if i pick up some backyarders, ill blow it on the val
    Newcastlish
    23,489
    I cant see a turbo setup coming in under budget. I don't see much of a challenge with nitrous. So is anyone actually going to try this?
    Thank you for smoking <---cop's Avatar
    Nov 2007
    6,272
    Fuck you cunts!
    I'm opening presents and thinking of combos lol
    Thinking FWD for $500, stripped to sub 800kg, eBay turbo manifold, factory RB20 turbo or similar.... Hmmmmm
    Ps merry Xmas cunts
    furious masturbater SausageFingers's Avatar
    Jan 2006
    1,332
    Fuck you cunts!
    Ps merry Xmas cunts
    Yeah, I think I am keen give this a crack.
    I attended the PF vs Powerchip thread 2010 and all I got was this lousy Signature.
    Came for the drinks, but stayed for the gangbang.
    4,629
    1c mod on bw35 - 1c
    Hmm... I have a CM with a 265 and extractors sitting around which could do this. $70 invested so far and it's almost roadworthy. Where does one get a decent 4bbL with holley from for $200?
    11,230
    e.g
    Misc shit - $200
    That is interesting. I am trying to figure out how the tuning works. I will read that link later as I am getting ready to go out.
    The 2 bar map sensor will mean less fuel is injected at any given load point. So fitting correctly sized bigger injectors will bring AFRs back to normal plus add the fuel required for boost. But with massively advanced ignition timing, so you use the dizzy for retard. Close?
    This would fit the bill as a good daily too.
    10.83 @ 125
    2,643
    Yeah i am keen to try it with a coon, it ill be the first ford i have ever owned doh!
    14,981
    Cheap holden with a red 6 motor, a Jmac ghetto spec turbo setup, run water injection instead on a cooler to keep cost down, would have to go close to 13's
    2,643
    So lets come up with some guidelines and a new thread to get this going
    Aug 2010
    Brisbane AU
    18
    Quote Originally Posted by Gavatron View Post
    I know for a fact it works because i did it to my celica, hehe.
    That said, I spent a bit more and got an emanage blue and wideband, better quality bits, etc, etc.
    But on a rev 2 with a knock sensor, it can pull timing (plus you set base timing to like 7deg btdc (factory its 10)... if (when) it knocks under boost the sensor will tell the ecu to pull timing.
    The bigger injectors take care of your fuel needs (although rich as a cunt at some places in the fuel map without a way to tune it)
    this is basically how it works, and yes you retard the base timing at the dizzy, and prey your knock sensor works!
    Nov 2007
    6,272
    Quote Originally Posted by oke020 View Post
    so lets come up with some guidelines and a new thread to get this going
    +1
    Newcastlish
    23,489
    1. No nitrous
    2. Within rta capcity guidelines (no big block 120ys)
    3. Safety items not counted in total ie ball joints/wheel bearings
    4. "reasonable" cost of items ie can't claim big block chev for $12.95
    Smrt.. Kyle's Avatar
    Apr 2004
    nsw
    5,904
    10s for $100?
    Nov 2007
    6,272
    Agree with allmtr.
    Tyres part of cost? Clutches?
    Both probably fucked and would take a chunk of cash.
    Newcastlish
    23,489
    IMO clutches are part of the cost but tyres can be borrowed. . . . .
