Page 5 of 5 FirstFirst 12345
Results 121 to 143 of 143
Thread: Elektra the Valiant - 13's for $1300 project
  1. #121
    12,772
    VE sedan Cam.
    Pics of Safaris not loading!
    the VF is a piece of shit and cbf taking photos of it. the VE isnt too bad actually. thinking of keeping it and rat rodding it (if i ever start and finish current projects)
  2. #122
    Serenity now! VE Safari's Avatar
    Apr 2004
    Carso
    2,676
    Looks fine mate. It's original colour is the same as mine. Front brightwork seems excellent - score!
    Remember - Ignorance in the true sense of the word does not equal stupidity.
    Wilful ignorance does though.
  3. #123
    12,772
    so as you can tell, nothing much has happened with this.
    have most of the rear brake parts, just have to get the handbrake cables off the old diff, then assemble that and fill diff with oil.
    got the CM front end out of the old wreck i have, but it needs discs and bushes. so rather than spend $600+ i thought i could try fitting VH- front drums to the existing brakes. then i realised they are non existant. might just leave the early stud pattern on the front and put hubcaps over it and see if the club inspector notices.
    bought a KKR660 for it. guy is getting postage for me on monday.
    will get a turbo flange gasket off a mate this week some time, then i can start making my own J pipe setup at work.
    oh and JMAC is coming over to drop off the convertor tomorrow
  4. #124
    deep south, NSW
    3,132
    Did you end up selling the VE wagon?
    I was almost going to make an offer on it at COTM, but knew my nopics would kill me if I did.
  5. #125
    Mar 2009
    Bendigo, Vic
    1,694
    So ya got a huge turbo now so, e85 or gas and 1/4's time? 700hp turbos dont spool in ya back room. i/we want to she an old beast mumbo.
  6. #126
    12,772
    man, im so ashamed ive done fuck all to this in a year and a half!
    anyways, i havent done nothing at all..
    got the diff mounted, its not great though, had to pull the leafs out to get it to line up with the spring pads. so now all that pressure has squished the bushes. not sure how thats going to work. will suck it and see.
    also got some wheel cyls for the back brakes and chucked them on.. and thats all ive done. now the problem is the rubber caps on the cylinders have perished, so need to look for some more before i can finish the rear end off.
    however i have been buying shit.
    first off, the turbo and wastegate. KKR660, and synapse wastegate. wastegate was $100, and i think the turbo was around $250 (i cant find the PM's about it)
    got a BW51 auto at the shepparton swap meet the year before last. IIRC i got it for $35! also stumbled on some freshly machined VH front drums for $20.. fucking score!! so will have matching stud patterns now.
    got some carb hats, one is a proper polished up carb hat, but its not the proper thick ones for boost, so im not sure how it will go (and not alot of meat to oring the base) but couldnt leave it there for $35. also got a LPG type hat that i figure i can cut up and make work, that was $10. oh and scored a carter low pressure fuel pump at the bendi swap meet. cant remember how much that was??
    then as per the ignition thread elsewhere here, 1jzracing kindly sold me a 2nd hand megajolt cheap. will need to convert it from TPS to MAP, but thats like a 1/2hr job to do.
    Dimi supplied a surge tank for $50, and Gruelius a smaller noname wastegate for $25ish.
    and just won an 044 bosch on egay for $51, should be in the mail soon.
    so plans have changed slightly, now the comp is over i have shitloads more time to get this done. and my knoledge of carbies/boost/tuning/E85 is basically zero, so im going to try and get club reg on the sucker so i can do some on the road tuning. should end up cheaper than paying $50 every weekend for a drag race, and spending the entire time working on it in the pits!
    so yeah, i want to go E85 now, as i think it will be a fair bit kinder to the pistons, and thus will allow me more boost, power etc. also i wont have to use the intercooler now, so i wont have to hack the rad support panel for piping.
    now having a gay 3 speed manual will be beneficial for road tuning, so ill worry about converting to auto at a later date.
    so basically its shitloads of little things to do. fittings, gauged, tools, piping, fuel hoses, etc. already have a techedge a/f meter with logging. will attempt to make a knockboard so i know whats going on ign wise.. hopefully the rattles that is a hemi 6 are at a different frequency to pinging, otherwise im fucked!
    will need to buy jet drillbits. theres a fuckload of mods to do to make a holley blowthrough, and ill be flying blind for the most part. there is writeups for boosting, writeups for e85/alky fuels...but not both! almost half thinking of making the cunt drawthrough.
    hopefully the 044 will be enough for fuel, otherwise ill have to buy a VL pump to go with it. luckily theres room for 2 in the surge.
    the beauty of the megajolt (apart from perfect timing and strong spark thats completely programmable) is it also has 4 RPM outputs, so i can use it to trigger pumps and shit to keep the flow down if need be. if i only need 1 pump ill probably use a val ballast resistor to run the pump at 9v until i need full flow.
    next big spend.. getting the windows and interior put back in it, and 3/8 alloy fuel line for feed and return.
  7. #127
    Aug 2008
    2,136
    Fuck yeah.
  8. #128
    Chrome bumper cunts! Soopy's Avatar
    Aug 2011
    6,287
    Awesome.
    I've never said or implied everyone on that page was a deadshit - just that there's a concentration of deadshits there. Think of it like a mine, but instead of a rich vein of gold bearing quartz, it's a rich vein of spastic bearing facebook posts.
    Any peanut who thinks they could have done it better from the comfort of their armchair or work desk is a genuine mong level potato.
  9. #129
    loves the Cressy
    Jul 2005
    Gympie Australia
    2,449
    Good to see stuff happening to this.
    Cheers, Richard
    - Long Term Jobs
  10. #130
    deep south, NSW
    3,132
    E85 is going to kill your budget I reckon because you'll need a compatible fuel cell, pump and lines.
    But good to see it back on the job list.
    It's funny scrolling up the thread and seeing the orange VE wagon. Once I sell my old house that thing is getting a massive makeover
  11. #131
    12,772
    Yep, it will cost a bit more, but I would need to buy a bigger fuel system anyways, so wouldnt cost that much more. Tank I think would be ok if hot tanked clean. The main thing Im thinking with e85 is it should be kinder to the motor. As im sure you know first hand, unopened hemis dont like too much boost. Hard to keep the headgaskets in them. From the reading ive done is roughly 10psi on petrol. I reckon I could get away with 15psi on corn juice.
    So yeah I havent done much with this. Come into some cash though so could probably buy the rest of the bits I need. Just hanging to get back into racing and buying tools, and getting sidetracked by the turdness and the wifes mini lol.
  12. #132
    deep south, NSW
    3,132
    Quote Originally Posted by MRGREATWALLMAN View Post
    Go the wreckers and find a cheap late model tank and mount it in the boot. Old school steel tanks and E85 aren't the best mix, they tend to rust heavily in the seams.
  13. #133
    12,772
    good idea! late model EFI tank would make pumps and shit heaps easier
  14. #134
    Ellis Juan mizone's Avatar
    4,060
    Oi, you had time to get anything more done on this?
  15. #135
    ACT Now!
    27,109
    I want to see this on the road so bad!
  16. #136
    12,772
    Ive been buying a few little bits and pieces for it. I dont really have room to work on it and lost motorvation
    Once I clear some cars out of the way and my kids start sleeping better Ill get back into it.
    Trying to get the turdness going whenever I get a spare arvo. Its at my oldies so I have plenty of room to work on it.
  17. #137
    Mar 2009
    Bendigo, Vic
    1,694
    This running 11's yet?
    Mmmmmmmmm beer.
  18. #138
    6,191
    Yeah!
    CJM 4 Life yo!
  19. #139
    12,772
    It is running, yes.
  20. #140
    deep south, NSW
    3,132
    It is running, yes.
    11s??
  21. #141
    12,772
    0-60kmh possibly lol
  22. #142
    Desert Nigga vet 180's Avatar
    Dubai
    3,005
    Good to hear its running
  23. #143
    Under a BMW
    6,222
    we should talk about swapping some kind of Valiant for some kind of Mazda.
