Just get a non ac belt and keep the serpentine system. It's neater and has less drag anyway.
Originally Posted by seedyrom
Yep, I'm keeping the circustime belt. I have plans for the 'tina should it survive...
Anyhoo... I smashed out a small rust repair out of some sheet. I know it's rough, but it'll work...
Back at it then, I guess... :P
Got my 5 stud conversion today, would have fitted them but they gave me the wrong seal. $20 for the old rotors from a wrecker, $45 for the bearings and seals. No discount on the bearings... bugger. Dummied up the mag off the val to see what it'd look like :P
Good thing about these rotors is that they use a hat pressed onto the hub: I might be able to fit a better rotor on it in future...
OK........ Just spent a stack on eBay. $219 on a chinese special GT35 and another $49.97 (lol at the exact exchange conversion) on oil lines. Sent the exhaust gasket to the engineer to be copied into a flange to build a manifold. Gotta start watching the pennies now...
Got some EA calipers to fit to it... Does it classify as safety items or do I have to add it to the total?
As for "win", things are starting to happen but I'm not yet cranking about it...
definately not performance.. brakes only slow you down![]()
Originally Posted by Rdyno
Originally Posted by Tripper
Finished the lower section of the A-pillar this morning, and picked up some more steel.
great metal work as usual !
Wow thats a lot of effort to go to for a shit box that only has to do a few drag passes. I say that in the most loving way possible as my first car was one of these. I would love another but they all seem to have rust like that. With those skills you might fully resurrect the beast. Top work.
Cheers guys! Like I said- if it survives I have plans for it lol.
Something I knocked up for a mate, if you're interested in a little fab work...
Got a prezzy in the mail today!!! AWESOME!
Should do the job...
Specs? Cost?
flogged from ebay page:
GT35:
Inlet Diameter 101.6MM 4"
Outlet Diameter 65MM 2.55"
Turbine Housing AR: A/R.63
Comp. Housing AR: A/R.70
Turbine Wheel: *56-65.25mm
comp. wheel: *61.4-82mm
Flange:T3 Flange
Bearing Housing: TB34 M8*2 Oil:M14 M10*1.5*2
Oil and Water cooled: Water cooled
Thrust Bearing:360
Wastegate: Internal
v band:79mm
Good size, it'll be interesting to see how it goes.
Thats basically a copy of the turbo fitted on the BA XR6Teseses.
Knocked up half of the rail (they are 2 halves spotted together on the 'tinas) this arvo, tomorrow will be the other half then the engine goes in on saturday.
You're a brave man.![]()
Just a day in the life, man!
Chassis rail is done for the best part. Now motor in tomorrow.
Underside view when half in.
Done.
Why I replaced it...
More to come later!
Fuck what a effort in replacing the rusted out stuff, must be near alone $1300 in beer/alcohol consumed after rust repairs alone
It's a holiday, so I've been working at 1:5 can/minutes and amount of work has been quite minimal... Now at least there is heaps of room for the 4L!
And the turbo flange is done- picked it up friday...
Might do a little more prep work on the motor but I'm getting to the CBF stage of the day...
Plonk!
And it'll be in and out while I build the sump... :|
good progress!!
loving the grants and cola! my fav scotch mix. pity we cant buy it here in a can anymore![]()
Nope
I couldn't resist the temptation...
Hahaha! sweet!!
hahaha fuck yeahhhh!
I am really digging this project! Love your work.
