Page 34 of 36 FirstFirst ... 2430313233343536 LastLast
Results 991 to 1,020 of 1071
Thread: Porsche 944 turbo road to racecar.
  1. #991
    Registered User 333pg333's Avatar
    2,251
    Yeah, seriously!
    ...and yet we persist and the Carrot continues to dangle...Muthafuckin' Carrot!!
Name:	JB Weld (2).JPG
  2. #992
    Registered User aerobrick's Avatar
    Jun 2016
    Central VIC
    412
    Quote Originally Posted by 333pg333 View Post
    Anyone had good experience with JB weld? Looks like it needs a full 24 hours to really set.
    Definitely give it the full curing time. My old hilux is still out there somewhere with kilos of JB weld in important places, including radiator top tank. Really sorry to see you're having to resort to agricultural methods, hope it works out for you!
  3. #993
    Jun 2007
    690
    After all the shit you've been through with this car, the latest setback must be a real kick in the guts. I'm sorry to see it end up like this after all of the time and effort, not to mention cubic dollars. Here's a "glass half full" scenario for you:
    If it works you could approach JB Weld for sponsorship, this would be an excellent example of how good their product is!
  4. #994
    2,251
    Ha..thanks for the tip! Be happy to become a World Wide statesman if this works...
  5. #995
    1,302
    I once bogged over a crack in a Detroit Diesel V12 block, I think I used Devcon, it lasted years....
    but did eventually fail.
  6. #996
    2,251
    Assuming it's more or less the same stuff. Here's hoping!
  7. #997
    Registered User dougmo's Avatar
    1,363
    you are a bigger man than me pat, i was done before this point.
    what pressure cap do you run on the cooling system? might be worth seeing if you can drop it a few psi (if it isnt low already)
  8. #998
    2,251
    So the situation at the moment is. Drilled about 25 3mm holes in and around the cracks. Applied liberal amount of JB. Allowed more than 24 hours to set. Then the plan is to put a 'serve' of Chemiweld into the system and get the motor up to about 120c. Idea is to hit it from inside and outside. Then take it to dyno and see what we can find. They're just playing with the new ECU at the moment trying to get it to read cam/crank signals so I guess it's holding so far. tbc....
    EDIT: So far so good. Dyno now on Monday. Sleep optional until then.
  9. #999
    1,302
    I'm confident it will see you through the coming event and longer.
    " Money is for those without skills"
  10. #1000
    Registered User Justengt4's Avatar
    canberra
    3,438
    If you cleaned the surface well JB weld will hold fine....Ii held my water pump together after snapping it in two!! That's a stressed part taking clamping force and the turning force.... never leaked. As shit as your luck has been, that fix should hold.
    GT8
    1UZ Celica
    1.07 flat Wakefield Park
  11. #1001
    2,251
    Yes. So far so good. Dyno on Monday will definitely give us the feedback we'll need to determine if we're going to make it or not. No leaks yet.
  12. #1002
    Registered User I'm DJ!'s Avatar
    Jan 2012
    Beach-ville
    8,254
    Fuck yeah. All the luck of the Irish mate!
    DJ's don't need sigs
  13. #1003
    2,251
    Ha, lets hope so. Thanks.
  14. #1004
    2,251
    Been on dyno for a few hours. Chasing some electrical noise. Looks like it's sorted. Best news is so far no leaks or mechanical issues. Positive results on soft tune and only 10lb gate spring pressure.
    Not going to go crazy and risk any headlift. Probably stop at 15-16psi for now. Still pretty potent thus far and way more than the 8v motors at similar boost.
  15. #1005
    canberra
    3,438
    Nice.....fingers and all the rest crossed for you mate. Really want to see this at WTA
    GT8
    1UZ Celica
  16. #1006
    canberra
    3,438
    GT8
    1UZ Celica
  17. #1007
    1,302
    Yep, good luck fella, you deserve decent sized serve of it
  18. #1008
    Down with ma homies Greg Rust's Avatar
    Perf
    10,284
    Good stuff
    xw Falcon 393 full race cam, NGK spark plugs.
  19. #1009
    2,251
    After chasing the signal noise and filtering it out we saw some decent numbers for a tractor motor. 505whp @ 10psi 550whp @ 13psi and 620whp @ 16psi. Didn't play with the cams and kept the rpms to 7500 even though this head has been built for 8800 apparently. Slow and steady and keep it all together. That should see us out for now. Should push a bit more drag down the straights. Pretty stoked all things considered. Thanks for all the good wishes too guys. Much appreciated!
  20. #1010
    1,363
    congrats pat, great to see mate
  21. #1011
    canberra
    3,438
    Solid numbers and torquey too by the sounds!
    GT8
    1UZ Celica
  22. #1012
    Smoke em if you got em! LINCOLN's Avatar
    723
    Woohoo. All the best.
  23. #1013
    Jun 2007
    690
    Well done mate, you can now seal the deal as the global brand ambassador for JB Weld!
    Seriously though, they are good numbers for such low boost.
  24. #1014
    GTR Wanker MR 1JZ's Avatar
    May 2005
    Rademalaide
    3,240
    Excited to see this on the live stream cutting some laps!
  25. #1015
    Nov 2008
    bm
    4,212
    Fuck yea now ouch out a lap and win that wtac shit
  26. #1016
    7,852
    That's some cracking power on low boost!
    My Sports Sedan
  27. #1017
    5,523
    Congrats, will be following on the live stream and look forward to seeing this cut some laps
    If in doubt power out
  28. #1018
    Jan 2012
    Beach-ville
    8,254
    Fuck yeah pat, boom!
  29. #1019
    7,852
    Quote Originally Posted by Guido View Post
    Hrmm...this was an unintended bad pun.
    My Sports Sedan
  30. #1020
    Chairbourn ranger! Mike Lowrrryyy's Avatar
    May 2007
    10,401
    Good luck Pat.
