Page 31 of 37 FirstFirst ... 21272829303132333435 ... LastLast
Results 901 to 930 of 1081
Thread: Porsche 944 turbo road to racecar.
  1. #901
    Feb 2012
    1,012
    I reckon the EFR is the biggest win moving forward. Far greater boost recovery/transient response due to the lighter turbine wheel will 'almost' negate the requirement for a dog dox.
    Granted, I have a PPG dog box in my car, and the difference is noticeable, not only in strength, but straight line performance.
    Mallala Motorsport Park - 1:11.71 - https://www.youtube.com/watch?v=tY85CK31if8
    Wakefield Park Raceway - 1:05.31 - http://www.youtube.com/watch?v=PREI-jK4L98
    Mt. Alma Mile Hill Climb - 41.67 - https://www.youtube.com/watch?v=kTmaG8jn3Tw
  2. #902
    8,649
    Quote Originally Posted by 333pg333 View Post
    As we're probably sticking with the stock box (which has given us no problems so far) I'm wondering if we shouldn't open it up and get the innards shot peened / Cryo'd etc ???
    Which box is it Pat? The 968 or 944 t or are they the same? While I'm at it and in one post is the 968 and the 944 vs the 944t at all similar to the 924 or 924t gearboxes?
  3. #903
    2,260
    Ours is the 968 6 speed which is a version of an Audi O1E box. The stock gearbox was a 5 speed. I actually much preferred my old 5 speed for shifting. No, the 924 box was actually a 915 box flipped around. Hence 1st gear is down and to the left.
  4. #904
    2,260
    So the turbo turned up last week. Having made the new headers up with new custom flanges and the double bungs for EGTs and Lambda, plus coating them...they're now useless without ever having firing up the motor yet. Problem is that with the twin scroll we need cylinders 1-4 and 2-3 to be tied in together to then run off to the turbo as twin X-overs. Currently, the new headers have those cylinders joining into the collector diagonally and therefore it won't work. Fucken...
  5. #905
    5,864
    can you swap two primaries?
  6. #906
    2,260
    I doubt it. Car was up on hoist when we thought to look the other day. If it's possible we'll do it but I highly doubt it. Nui$ance.
  7. #907
    Aug 2013
    gawler
    1,443
    John Kuhn and co. have got their 928 S4 back on the dyno after optmising the entire system and a fresh motor with a little flow work, early days but they are at 10 psi for 540 wheel hp on a super conservative tune with 93 octane....talking about going to 30 psi on race fuel!!!
  8. #908
    2,260
    That's super impressive for 10psi...they are US horses though. Smaller, but more of them. ;-)
  9. #909
    Jun 2006
    Ararat
    3,937
    Dynojet wheel hp =~ flywheel hp
    Sent from my GT-I9305T using Tapatalk
  10. #910
    Aug 2013
    gawler
    1,443
    They are on some sort of hub dyno that they bought for the purpose.
    Knowing John, even the numbers will be conservative...
  11. #911
    2,260
    From what I gather hub dynos read a bit more like crank hp. But nevertheless...540 anythings at 10psi is really impressive! Do you know what capacity that motor is Roy?
  12. #912
    Aug 2013
    gawler
    1,443
    I understand it is still 5 litre.
    Hub dyno, no issues with wheelspin...it is just a passing number anyway. The old configuration pulled 711, the question is, What will be the next limiting factor? the turbos were all in @ 711. Now they have fitted physically the biggest turbos they could, into the space available (and upsized all the plumbing and cast exhaust manifolds and moulded silicon hoses etc etc) and are thinking they may run into a restriction in the stock inlet manifold or a pulse issue in the exhaust manifold?
    John is rather anal, they have sensors on everything, even crankcase ventilation flow....
    He believes he is delivering a product of Porsche quality to compliment the existing machine...I wouldn't dissagree.
  13. #913
    2,260
    Sounds comprehensive. 540hp at such low boost would be tempting not to push it too much more on a regular basis just to get that 'factory' like longevity. I'd be happy with that at 20psi. Happier if it was 15-18psi but that only seems to happen on overseas cars.
  14. #914
    8,649
    I reckon you'll be surprised with your new setup Pat. Fingers crossed.
  15. #915
    Aug 2013
    gawler
    1,443
    My sentiments exactly
  16. #916
    2,260
    Man, you and me both!! I think I deserve a little luck but as they say, there's plenty of luck, just that most of it's bad!
  17. #917
    2,260
    Bit of slow going but the water pump is mounted and the nice unused 4-1 headers have had to be removed to make way for yet another set but this time 2x 2-1 to allow us to run twin X-overs. We just couldn't make the 4-1's work. So they will be coated with the X-overs and then onto the turbo back exhaust. Was thinking side exit to save on weight but have concerns over db limits and if this could pose a problem at some tracks. Also side might allow us a bit more scope should we make a diffuser one day. The one good thing about having to redesign new headers is a lot more clearance between them and the steering shaft. Before we actually used to rub the shaft on the headers and had to massage the whole motor across a little.
    The new turbo is quite a bit bigger than the Garret. Luckily we have removed the balance shafts from this motor so we could carve out a bit extra room. Means it's going to be real tight for the new intake though. More of that to come once it's delivered. Once we have the intake it won't be too much more work before dyno time. We are looking at dbw and therefore doing a bit of investigation about T/bodies. First thought was a 'vette one which are cheap and easy to get a hold of / parts etc...but they're bloody big at 90+mm so we might look for something a bit smaller that we can also use it's actuators from. Open to ideas?
Name:	New Headers i.JPG
ID:	98189   Click image for larger version.
Name:	2-1 16v iii.JPG
ID:	98190   Click image for larger version.
ID:	98191   Click image for larger version.
Name:	2-1 16v ii.JPG
ID:	98192   Click image for larger version.
  18. #918
    2,260
    Bit of progress.
Name:	Headers n dump.jpg
ID:	98373   Click image for larger version.
ID:	98374   Click image for larger version.
Name:	Xovers n Dump.jpg
  19. #919
    8,649
    Oh my
  20. #920
    1,404
    nice pat
  21. #921
    Jun 2006
    Ararat
    3,937
    looks like Scooter has been waving his magic tig wand again, everything he makes is like a piece of art... Merlin on here uses BMW throttle bodies for DBW on rotaries etc, maybe shoot him a message?
  22. #922
    2,260
    Yes indeed. Final dress rehearsal before off to the coaters.
Name:	Box o pipes.jpg
ID:	98400   Click image for larger version.
Name:	Final pipes i.JPG
ID:	98401   Click image for larger version.
Name:	Final pipes ii.JPG
  23. #923
    Sep 2012
    Maryborough, Qld.
    58
    Too purty!
  24. #924
    Jun 2006
    Ararat
    3,937
    Lovely work
  25. #925
    Registered User my limp penis's Avatar
    725
    Shoot me a pm re: sequential transaxles
  26. #926
    2,260
    Should be back from coating next week. Need to make a few more changes with a new radiator and see if we can squeeze in larger IC pipes. Then wait for the intake which is about 3-4 weeks away. Finish the wiring for the new ECU and off to the dyno.
    Knowing that there will be hurdles is daunting. Just hope they're not catastrophic.
  27. #927
    Registered User ENGINR's Avatar
    256
    Kudos for your commitment mate. The new manifold setup looks freaking amazing.
  28. #928
    2,260
    Quote Originally Posted by XtaC View Post
    Too purty!
    Thanks.
    Lovely work
    Thankyou.
    Quote Originally Posted by my limp penis View Post
    Done.
    Quote Originally Posted by ENGINR View Post
    Thanks. Hopefully it works as good as it looks!
  29. #929
    1,189
    Who are you using for the ecu wiring...needing someone there soonish to clean up a total mess!
  30. #930
    2,260
    Robbo. Mark Robertson He runs a small team in the Dunlop series too.
    Rsport Race Engineering
    19/280 Newline Rd Dural NSW 2158
    Phone +61-419205515 Fax +61-2-96346529
