Page 24 of 27 FirstFirst ... 142021222324252627 LastLast
Results 691 to 720 of 802
Thread: Hq ls1
  1. #691
    Jun 2009
    1,139
    Found the sheet from the dyno.
  2. #692
    Caught in the ACT
    17,082
    Did they convert you to islam while you were there?
  3. #693
    Nov 2008
    bm
    4,537
    Mabrookislyf
  4. #694
    Jun 2009
    1,139
    Quote Originally Posted by GSRman View Post
    Haha nah they are pretty good actually. Adam is a cluey guy
  5. #695
    Jun 2009
    1,139
    Looking at the next round of improvements
    Whats people views, experiences with Water to Air intercoolers with and without an ice box
  6. #696
    Caught in the ACT
    17,082
    They are very good - met them at the snowy 1000, then there was a highway blocking accident - they were low on fuel so told them to follow us down this shitty dirt track in his R34.. tunes Mathew's R32 which is a fucking weapon... (321km/h in the km).
    My W:A has been awesome - when i change it, it will be for a bigger one... I run ~20L tank, with a little heat exchanger under the tray with some thermo fans running at half-speed, on the street its awesome (as you can only give it a few stabs every now and again anyway)... for the KM's i dump ~5-7kg of ice in it before the run.. by the time I get back to the pits it's only just off cold.. 22 sec WOT 32psi boost making ~ 500hp intake temps stay around ambient - like 25-30.
    if you are planning to run ice regularly - put a drain valve in it - not that siphoning it is that bad.... but put a larger hole in the top - i printed a funnel for mine, but would be easier if it was larger - smashing ice etc - don't bother insulating it - but do put something (like a towel?) around it to catch the condensation - Phil with the white whale just put one in his car - if you are wondering how it worked in a drag challenge car.
  7. #697
    23,661
    I reckon a good a2a is fine unless you're running 7's
  8. #698
    Caught in the ACT
    17,082
    probably totally fine - it's just about how much mass you have to disperse the heat into - no amount of airflow into the core is going to remove the heat you are putting in (in most cases) so your intake temp will rise by the end of the run i'd recon.
  9. #699
    Registered User Junga2365's Avatar
    Sep 2017
    Qld
    169
    Has this thing been back to the track to run a low 10 yet?
    Sent from my SM-G935F using Tapatalk
  10. #700
    Jun 2009
    1,139
    Quote Originally Posted by Junga2365 View Post
    Nope, track is shut till new year.
    Im fine with intake temps rising and understand that its something mechanical that is just par for the course. However I would like to keep out of the 60-70 degree range. If I could keep intake temps 40 and below that would help make it a little safer and a little more power.
    So it looks like a barrel cooler, a condenser and a ice tank in the boot might be the go
  11. #701
    Sep 2017
    Qld
    169
    Heading back to the track soon mate ? Did you get a cooler setup ?
  12. #702
    Jun 2009
    1,139
    Ill head to Summernats first and then to the track when it cools down a bit. Maybe feb lol
    No cooler setup yet, just enjoying it for the moment
  13. #703
    Jun 2009
    1,139
    This shit box survived Summernats again.
    With the new turbo setup I decided against the burnout comp due to IAT's. However I though ill use the services of the dyno. Strapped it on with the same tune from Sydney (JEM) and it made 446rwhp which was about on par with what everybody was seeing - dropped between 60-100rwhp from Sydney to Canberra.
    Though about it for a little while over a couple of beverages and decided to up the boost a little, take out a degree of timing and put some fuel in up top and see what it would do.
    Result - 466rwhp with the afr's in the top at 10.2-10.5. It only went up 2psi as well. So looking at the log ill take some fuel out up top to lean it up to 11.0 afr's.
    Looking at hitting the drags on Wednesday to see what it will do. The weather looks good for it as well. Hoping that the extra grunt will transfer back in Sydney meaning it should be up around the 530rwhp.
    Can't say enough positive things about Adam Rogash from MPW. The guy is a fucking champion, went out of his way to give me some tips about the starting issue and where to look for more power when I start hitting the wall.
    As for the commentator he was a twat, cause it was turbo LS it must be making a million powers. Told him that its a little 5.3 with pump 98 so nothing special, cunt goes on to say a couple of times that its funny that its not making power and it should be looking for about 650rwhp.
    All in all this little package is great, 13psi, 11 degrees of timing and 10.5 AFR's means that its still safe and has more power to make.
  14. #704
    23,661
    Might be busy on Wednesday as the motive/1320 guys will be out there. I might be there in the Wrangler
  15. #705
    1,939
    If weather is ok I'll probably go for a look almost tempted to race shitbox vp ute.
    1320 probably be busy with maatouk ulehs
  16. #706
    Sep 2017
    Qld
    169
    Shit yeah man, do you have a transbreak ? My guess is 10.40 @ 132mph with a high 1.50 60ft
  17. #707
    Jun 2009
    1,139
    No transbreak, like my suspension pick up point to much lol
    I would be happy with a 10.40 however
  18. #708
    Jan 2009
    5,014
    It was fuckin' rad to see this thing run on the dyno. We really should feature it in LSX Tuner if you're interested, mate - it's an epic budget build.
  19. #709
    Sep 2017
    Qld
    169
    Keep us all updated tonight mate, good luck
  20. #710
    Sep 2017
    Qld
    169
    How did she go mate
  21. #711
    Jun 2009
    1,139
    Melted again
  22. #712
    Sep 2017
    Qld
    169
    Melted again
    Fuck mate, fuel system problem?
  23. #713
    Jun 2009
    1,139
    AFRs at 10.8, 9 degrees of timing, it showed knock and dropped down to 3 degrees of timing and knocked again.
    Seriously scratching my head, NFI what is going on.
    Who wants to buy a HQ turbo setup lol
  24. #714
    24,304
    Dude. Fuck. Fuel surge?
  25. #715
    Struggletown
    6,580
    Sounds like a knock issue not lean. Hopefully pistons will tell the story
    Hold it flat cunt
  26. #716
    17,902
    so your using a factory LS1 pcm and knock sensors on a Iron block and trying to tune it by them?
  27. #717
    Struggletown
    6,580
    What are the potential issues with doing that?
    Hold it flat cunt
  28. #718
    17,902
    like maybe give false readings... the factory LS1 sensors are shit house at the best of times and cant be trusted on a stock alloy block motor..
  29. #719
    Struggletown
    6,580
    Makes sense. I would think any kind of knock in something like this is gunna kill it straight away with a stock piston. It's not like a low power NA thing where you can let the knock sensors pull it back until you figure the tune out.
    The last one had signs of detonation with busted ring lands and shit so it's hard to say if it's just throwing false readings
    Hold it flat cunt
  30. #720
    Sep 2017
    Qld
    169
    Post up your time cars man, get any early increments?
