Page 2 of 23 FirstFirst 12345612 ... LastLast
Results 31 to 60 of 661
Thread: Post a pic up of your best welds
    Aug 2004
    SE Burbs, Vic, Aus
    146
    nice welds in here...
    I should take some photos of the work the CASA welder bloke does at work..
    Always wanted to try my hand at welding, among the list of other things I wish I could do in a home workshop! Need to make custom cooler piping/cooler to fit the active front spoiler/FMIC combo in the supra.
    bdsgarage
    pine mountain
    75
    Meh
    Jan 1970
    26,940
    I had to weld some castors onto a steel tube to go onto the bottom of a work table.
    I haven't touched the TIG for a while, was happy with the result.
    bdsgarage
    pine mountain
    75
    Ive just done 25 trolleys,i but welded them all tho as the boss put a wager on that they would fall apart.......He doesnt like but
    welding.
    Registered User Suscunt's Avatar
    Jul 2010
    Lycralandya
    1,265
    Not mine but i found them impressive
    Quote Originally Posted by cheapracer View Post
    Sperm are clever little fuckers that got us where we are today. You've never heard of pre-cum by the way?
    Quote Originally Posted by Nugs View Post
    That's why I punch myself in the nuts before sex, get them disorientated.
    Apr 2010
    Bogan City
    823
    some pics of my 1j manifold that's under construction:
    Registered User ISL33P's Avatar
    Jan 2006
    Wollongong, NSW
    93
    Im impressed Commotion....very nice work.
    Here is some of mine. I thought I would put a few up, steel and aluminium, the more the merrier I 'spose.
    Cheers,
    Ariel
ID:	57441   Click image for larger version.
ID:	57442   Click image for larger version.
ID:	57443   Click image for larger version.
ID:	57444   Click image for larger version.
ID:	57446   Click image for larger version.
ID:	57447   Click image for larger version.
ID:	57448   Click image for larger version.
ID:	57449   Click image for larger version.
ID:	57451   Click image for larger version.
ID:	57452   Click image for larger version.
ID:	57453   Click image for larger version.
ID:	57454   Click image for larger version.
    Apr 2010
    Bogan City
    823
    Thanks bud! I got to see one of your plenums up close recently, Very tidy indeed.
    I use to do a fair bit of ally welding years ago. I welded some off cuts together on the weekend to make sure i could still do it as i have to build a custom inlet manifold soon and dont want to mess it up. I got a mate who tig welds aluminium for a living and considered just getting him to do it but then i wouldnt get the satisfaction of completing it myself.
    Do you do any prep work to weld the cast? I have struggled in the past welding to cast with porosity.
    Jan 2006
    Wollongong, NSW
    93
    Cheers. Post up some pics of the manifold when its done...it's always interesting to see what people do.
    As for the prep work, nothing really, just clean it well and away you go. Might also clean the inside if its possible, but I don't and they still turn out pretty well.
    Engine bolt ons like manifolds which are cast are easy to weld, its just engine casings which can be the killer because of the massive amount of oil they retain.
    Apr 2010
    Bogan City
    823
    Ah that's good to know. I guess most of the cast parts i have tried to weld have been sumps and cast radiator pipes.
    I got some more manifold pics but not of the typical Jz or Rb motor.
    Apr 2010
    Bogan City
    823
    I have some updates on the 1j manifold. I got another set of manifolds completed and then went to work on the 1j manifolds and then ran out of oxygen so I could not massage the pipe to suit the ports so I will have to complete that when I have another gas bottle.
    I am still not sure how I am going to run the wastegate/s. The design is a copy of the full race manifolds and they run two gates, one off each collector but I am leaning towards running two gates of the turbine housing. I will have to wait to see how much room i have available before i make a decision.
    Sidetracked BMWTurbo's Avatar
    Aug 2004
    3,393
    Impressive work guys. I'm assuming the skills have been built up by working in the welding/fab area?
    Being able to TIG is up there on my must do list at some stage. Nothing more fullfilling then creating something from scratch yourself.
    Apr 2009
    perth
    55
    2jz equal length runner Twin turbo manifold.
    walking the cup
    Registered User caged's Avatar
    Jan 2011
    christchurch/sunshinecoast
    283
    Are you doing a root pass and then a filler pass on that steam pipe? What filler?
    Apr 2010
    Bogan City
    823
    For pipe, I usually do a single pass on single beveled joins (pipe - Elbow) and root run and capping run on single V (Elbow- Elbow).
    As for filler rod i have used er308L and er309L (stainless filler) primarily because i find it gets less porisity and is easier to weld with. I have had no strength or cracking problems under usual conditions to date.
    I have had a manifold, which i used 308 filler rod, on a car that was envolved in a collision with a pole or tree that inpacted the turbo and wastegate. It pushed the runners closer to the motor and cracked 2cm of weld where the wastegate pipe was welded to the collector. Considering the state of the car i thought the strength of the manifold was quite impressive.
    17,797
    Got a new 3 phase tig at work so thought I would try it out, haven't welded alloy in at least a year, not bad for a hack cunt!
    Dec 2004
    Sydney ,Australia
    806
    What welder did you get dale? and how do you find it ?
    Foot pedal or trigger on torch ?
    17,797
    unitig 315 thingy with foot pedel and water cooled torch etc..
    only a cheap shitter but it will only be used for thicker stuff as the little 220 amp kemppi is still the gun machine for the thinner stuff..
    . crack's Avatar
    BNE
    2,441
    Quote Originally Posted by 34jzgte View Post
    cop opens bonnet but doesn't end up issuing a defect
    (your fabrication is wild by the way)
    Jan 2006
    Wollongong, NSW
    93
    Dale, you just have to stop feeding the rod from the side of the puddle
    And my kemppi can do 10mm easily, single phase 230amps. I have seen you mention helium, its the way to go
    Custom made and replacement (CNC) intake manifold - 4 axis CNC machining - 3d modelling - tig welding
    Custom Plenum Creations facebook page
    Jan 2006
    Wollongong, NSW
    93
    So after having some issues with my new welder, getting a new one sent to me, putting me back about two weeks, it the f'ing chinese pressure regulator was the problem AAARRRGGGGGHHHHHH!!!
    So now I am back into it....and playing around with all the settings to get a result I am happy with. Here are some pics but the machine still needs some adjustments.....
    Mar 2009
    Bendigo, Vic
    1,688
    My second/third time welding so its shit but hey we all have to start out somewhere.
    Stick welder btw.
    PS If its to shitty for the thread just delete my post.
    Mmmmmmmmm beer.
    12,741
    so my welder is ok then?
    fuck theres some awesome welding in this thread. one day...
    Apr 2010
    Bogan City
    823
    Ariel they look nice! I wish I had more time welding, unfortunately its limited to late nights and weekends at this stage but not many aluminium jobs.
    The only recent aluminium job I have pics handy. I designed it on the computer, ran a FEA analysis on it for 20psi and then got all the bits laser cut and folded. Underestimated the shrinkage in the weld which caused massive cracking problems and so had to redesign the lower part to what it is now. I keep telling myself that if I did it every day I would improve but don't think I will ever find out.
    BLING BLING PLAYA's Avatar
    adelaide
    6,044
    Looks good, where did it crack?
    Phone Home Et!'s Avatar
    Feb 2006
    Whistler
    508
    Any one got some pics of mad MIG vertical ups and overheads.
    12,741
    i culd get some pics of mine, but they are far from 'mad'.. just this week i was practising vertical ups and my boss called them 'a bunch of grapes'.. fucking cunt! (amps were right, but too much wire feed, so weld built up too much in the centre of weld)
    Apr 2010
    Bogan City
    823
    PLAYA: The original lower profile was flat between the ports. The welds in the inside around the ports were only a few mm from this horizontal part. when the welds cooled it pulled this horizontal in tension and there was nowhere to relieve the stress so it would crack the welds closest to the horizontal part. I changed it to have the V shape so that when the welds cooled it can try straighten out this new fold and relieve the stress. It will probably weld a small amount with flow.
    ET!: I dont weld very much with MIG at all let alone in those positions. Below is the only pic i have that I'm proud of. I welded a few ripper thine holders onto the leg for my old mans earthmoving rig.
    Oct 2005
    adelaide
    418
    Quote Originally Posted by Et! View Post
    my version of a verticle up.
    and some of my alloy tig welding.
    Aug 2004
    SE Burbs, Vic, Aus
    146
    Owned bitches
