Page 26 of 26 FirstFirst ... 162223242526
Results 751 to 777 of 777
Thread: Project Car: 1968 Plymouth Roadrunner build thread!
  1. #751
    Grumble bum 68RNR's Avatar
    Feb 2012
    Blackwater, QLD
    1,177
    H-Pipes get da bitches mate. Everyone knows that.
    I had convo pro's on it originally, but I decided I didnt like them anymore so I flogged them off and shoved some random steelies on for now. I am contemplating either putting black street pro's on (17" probably) or else going the tried and tested torque thrust route. Probably a 17x10 rear and a 17x6 or 17x8 front?
  2. #752
    PF Brisbane Cuntarm
    17,175
    Nah Torque Thrusts are too common I reckon, leave em to the Mustang and Camaro crowd.
    Tough drag style wheels as mentioned or something "pro tourer" looking maybe?
    I like these as they fit the "pro tourer" look of something that's more than just a cool old jigger but has some performance. Not sure if they'd suit on such a big car or look to modern and racey? But I like em!
    8,413
    Yep, above choice is spot on. Looks Hallibrand influenced.
    Torque thrusts are like the Seppo version of Simmons FRs, they're farking everywhere.
    Would also look pretty good with these: https://www.weldwheels.com/product/s71/
    Feb 2012
    Blackwater, QLD
    1,177
    Point taken. Piss98 wtf are those called?? I rekon they would loom good in 17s.
    The weld s71s are fucking tits. That was actually another wheel I was considering...
    I also thought of running black steel circle track wheels too... be kinda cool.
  5. #755
    10,303
    Thong slapping H pipe goodness.
    Looking good mate, those wheels and tyres will be fine for skid testing first.
    What? You'd get thong slap without the H pipe like a dirty old 308.
  6. #756
    PF Brisbane Cuntarm
    17,175
    Quote Originally Posted by 68RNR View Post
    They're US Mags Rambler U111 - https://www.summitracing.com/int/par...6152/overview/
    That's what I mean, H pipe = thong slap. Mine had an H pipe when it came from the US, the change in sound when Scott made me an X pipe was bigger than I expected (although on a pissy little 8 like mine it sounds more like an inline 6 at high revs but still plenty of womp-womp at normal speeds.)
    Feb 2012
    Blackwater, QLD
    1,177
    Yo lads! I've been pretty fucking slack with updating this thread... however there has been progress!!! Decided to stop being a tired cunt and get this on the road. I really need a v8 in my life again, so the push is on to try and get this running and on a dyno before xmas.
    Anyway, so what's been happening I hear you ask??
    As with all engine conversions - all the fiddly fuckaround bits are causing the most expense and frustration. I've been ordering a lot of bits, like gaskets and aeroflow fittings (urg!).
    So engine was in, and I just sat the intake manifold in place (need to get a wiring loom in there before I get carried away):
    First issue that presented was that the fucking alternator wont fit. Didnt see any info on this on the net, so it caught me by suprise.
    The edge of the frame rail has a bit of an overlap on it that hangs out:
    So quick easy option - chop the overhang off with a grinder and then weld the seam up:
    While I was at it, I had to put in a remote oil filter. The factory setup has the filter down next to the alternator, which fouls on the k-frame on the roadrunner. Fortunately, Mah Mopar has two ports above the filter that are blanked off with plugs, so you can run a remote setup if you want. I got a blanking plate from TTI for the filter itself and then stuck in an earls remote filter kit. It's plumbed up with 8an hose, which I am hoping will be plenty. There was some heated discussion on the net about what is sufficient, but I couldnt really fit anything bigger as the ports on the block are really close together.
    Anyway so here's how we look now. I have installed a new fuel pressure regulator as well, as obviously the old setup was carb. The in-tank pump is an aeromotive stealth, so it can provide the pressure I need already. I just went a bypass style efi regulator, which was a piece of piss. Still have to tidy up the return line though!
    The factory throttle bodies are drive by wire, which is a pain in the ring. I went with a BBK cable setup instead that bolts straight up to the manifold. I considered making an adaptor and running an LS throttle body, but fuck that.
    Next issue now is trying to make a cable bracket for it. BBK dont seem to sell anything to suit (that I can see...) so ill probably have to weld something up. Should be a royal pain in the ass.
    Other than that I had some new doorcards made, because the fake woodgrain vinyl ones were bloody horrendous. New ones look nice!
    So thats about it for now. I pretty much have everything to get it fully plumbed up, so its time to sort out the engine management!
    Still not sure which way to go. Options are:
    - Haltech Elite 2500, then get some poor bastard to make a custom loom to hook it all up. About $2500 for the haltech, then probably $1200+ for someone to make the loom and fit it all up? No idea really.... It's not something I want to try and do myself...
    - Holley Dominator efi - comes with plug in loom and a base tune to get it running, pretty much plug and play. Going to be about $3800 for all the shit I need from the USA, but I wont have to fork out loads of coin for auto elec work.
    - Megasquirt - they make a plug in box and loom, but apparently the setup is a bit limited with the VVT on these engines.... Setup is cheap though - be under $2000 for the box and loom.
    - Mopar crate hemi engine management - about as much as the holley and a pain in the ass so not going that way.
    Decisions decisions!!
  8. #758
    4,293
    Thatís a prick about the alternator! Iíve never even heard of that with the A-body.
    BBK throttle body looks good, Iíll be making the same decision regarding the cable bracket soon.
    Iím going Haltech 2500 with my 6.1 - so in a couple of months there will be a resident auto-elec whoís just recently done a custom loom for one if heís keen!
    Good to see progress!
  9. #759
    Feb 2012
    Blackwater, QLD
    1,177
    Very interesting!! If you have someone lined up to do yours I would be interested to see how it goes. Could definately be a goer if he wants to do my 6.4 as well! The looms will be literally identical. Maybe he can just make 2? We should talk.....
  10. #760
    PF Brisbane Cuntarm
    17,175
    About time there was some progress! Git er done! Slowly learning from experience here, spend the money on the better ECU so you don't spent it twice.
    PS - can not un-see mismatched blue/red and black fittings.
    Jul 2007
    Blackwater, QLD
    1,613
    looks like some good progress. with the throttle cable, it looks like motorbike clutch cable. the bike shop will have a variety of solder on ends to suit. I'm not sure what's on the pedal end, but a suitable barrel end for the throttle body will likely be easy. probably silver solder will be strongest, but I've done a few clutch cables with soft solder and minimal dramas.
  12. #762
    Feb 2012
    Blackwater, QLD
    1,177
    Yeah that bit kinda does my OCD over as well :P It's just an interim thing though, ill stick some black ones on when i'm feeling motivated. Buying fucking aeroflow fittings locally is like passing a kidney stone though. Might be time for a visit to summitracing.com again....
    That bit is easy man, I just bought a little cable end clevis thingy off ebay. Ill grab a photo when I get a sec. Wait heres the ebay link:
    https://www.ebay.com/itm/10Pcs-14-x-...72.m2749.l2649
    The pedal end is sweet too as I already was running the same style Lokar cable with the big block. The fiddly / gay / shit part is trying to make a bracket that can hold the cable on the throttle body if you catch my meaning. Have to bust out ye olde' welder.
  13. #763
    Jul 2007
    Blackwater, QLD
    1,613
    oh righto. those ends look heaps easier. hopefully the bracket doesn't give you too much static. was it just the extra wiring/setup hassles which turned you away from dbw?
  14. #764
    7,603
    Cool progress.
    Thought about a EFI quad tb on a single or dual plane manifold?
  15. #765
    Feb 2012
    Blackwater, QLD
    1,177
    To be honest it was less about the wiring issues and more about the delay / lack of response of the dwb setup.
    Cool progress.
    That is exactly the eventual plan. Run a setup like that with a circular aircleaner so it looks vaguely oldschool again. There are some good options for aftermarket manifolds for these motors now too. Only thing that stops me at the moment is just the extra expense. By the time I get the manifold, tb and a set of fuel rails ill be in the hole around 2k??
  16. #766
    7,603
    There is no delay in fwb and if there is can be tuned out
    It will look cool though. Its only money
  17. #767
    PF Brisbane Cuntarm
    17,175
    Do it. Click image for larger version.
Name:	Nova LS1 Engine 1.jpg
    4,293
    I thought the idea of going to a modern hemi was driveability and proper fuel injection?
    If you're going to pour fuel into it with a bucket you might as well go all the way - Edelbrock do a dual quad intake for these now:
    Two quad EFI TBs. Cost about twice as much as a proper ECU, use twice as much fuel and probably make less power. Though agree it would be cool!
  19. #769
    Jun 2007
    Approaching Uranus
    522
    You've done a very stealth job hiding the twin turbo's
  20. #770
    Feb 2012
    Blackwater, QLD
    1,177
    Nein, you are missing the point here. The aim is to maintain multi point fuel injection, just using a single plane style manifold and a quad throttle body. So the same setup as the current intake but with the throttle body on top with a circular aircleaner for more stealths and oldschoolness.
  21. #771
    Feb 2012
    Blackwater, QLD
    1,177
    I.e not throttle body injection as that is shit and depletes the purpose of having a fancy haltech.
  22. #772
    Feb 2012
    Blackwater, QLD
    1,177
    Quote Originally Posted by richzx View Post
    Soon.... gonna get it running first, then decide on blower vs turbos.... blower is so easy though.
  23. #773
    Jul 2007
    Blackwater, QLD
    1,613
    isn't that able to be tuned out with your fancy computer? dbw can do idle and even cruise control if you're keen.
  24. #774
    PF Brisbane Cuntarm
    17,175
    Oi!! Although my Haltech isnít the fanciest they make.
    Feb 2012
    Blackwater, QLD
    1,177
    Good points. I spose I sacrificed all that so I could keep my stock throttle pedal setup. Oh well, that might be an ulgrade for later. Cruise would be a plus...
  26. #776
    Feb 2012
    Blackwater, QLD
    1,177
    Lol! I should re-phrase...
    Multi-point efi > throttle body injection > carb
    *for this particular application and not a general rule. Please see your engine builder to discuss what is best for your application*
  27. #777
    PF Brisbane Cuntarm
    17,175
    Lol nope too late youíre a cunt. Mine is to keep the look and doesnít need max power just be better than a carb on a 283.....letís face it thatís not a big challenge!
