Page 10 of 11 FirstFirst ... 67891011 LastLast
Results 271 to 300 of 306
Thread: 13/04/1300 Mazda 626 Turbo
  1. #271
    . crack's Avatar
    BNE
    2,430
    Turns out I broke a rib prior to last time out at the drags, hence the going home in pain after only a couple of runs. Anyhow, it healed a while ago but motivation didn't return until very recently when I realized that there are only 2wks until rego runs out. I don't intend to re-register so I've got to get this thing back to the strip asap. That means fixing the torque steer issue.
    Step 1 - Manual steering rack
    Turns out factory manual steering racks are extremely rare. The local wreckers didn't have any so I decided to retrofit a manual rack from another car. Pretty much first car I looked at walking into the local wreckers was a Hyundai Excel with a manual rack. The rack looked similar in shape and size (albeit a bit smaller) and had an extra turn lock to lock. After half an hour looking at other cars the Excel rack still looked like the best option, so I ran with it.
    Fitting was reasonably straight forward:
    Hyundai Excel manual rack adapter brackets
    Adapter bracket assembly (green plates represent firewall)
    Cutting
    Tacking
    Welding
    Adapter sleeve on steering shaft (fillet & plug welded)
  2. #272
    9,034
    you're a nut job. I might need your skillz sometime soon dude...
  3. #273
    . crack's Avatar
    BNE
    2,430
    yeah bloke, whenever.
    anybody keen to buy this thing when i'm done with it? i'm thinking 12s for $1200. excluded from that price would be drag radials, wideband, tuning laptop and boost gauge. could chuck them in for a good price as well. spent literally 100s of hours on this thing and don't want to really see it get wrecked. I can reuse a lot of parts out of it (ecu, turbo, injectors, 3 bar map, etc.), so it aint so bad if it doesn't sell. can never be road registered again obviously - 300kg weight reduction made sure of that.
  4. #274
    1,762
    wow, mind blown....
    now with extra gearbox'y goodness
  5. #275
    . crack's Avatar
    BNE
    2,430
    thanks rx23q
    just found enough bits laying around for a DIY dual stage boost controller (2 off needle valve, 1 off 2 pos/3 way vac solenoid, 1 off relay w/ integral fuse). looking at one of my data logs i don't stay on boost when changing into 2nd but i still experience bad torque steer. i think boost might be ramping up too quickly in 2nd gear causing the torque steer? with the dual stage boost controller installed i'll run 12psi until I've changed into second and straightened the car up and then 25+psi for the rest of the track.
    also, tomorrow hopefully i'll have some 15x7 inch steelies (for the drag radials on the front) with a much better offset (+35mm versus +5mm).
    i'm hoping with the manual rack, less scrub radius & dual stage boost control i'll be able to tame this wild beast
  6. #276
    . crack's Avatar
    BNE
    2,430
    final bit of fab for the project
    dual stage boost controller - fab'd where possible to remove the need for expensive brass fittings
    uses 2 Festo needle valves (1 $20 new & 1 $7 2nd hand), generic relay & fuse, carby CC Lancer 3 port solenoid valve ($5 from wreckers)
  7. #277
    Melb
    832
    Tricky stuff
    Nice one.
  8. #278
    Aug 2008
    2,019
    great work
  9. #279
    Jul 2007
    841
    so going to have it ready for this saturday? ill call you tomorrow mate
  10. #280
    . crack's Avatar
    BNE
    2,430
    yeah, keen as for Sat. talk tomorrow then.
  11. #281
    . crack's Avatar
    BNE
    2,430
    moar pics (shitty iphone quality)
    forever alone clutch bleed (bung cable tied over master cylinder reservoir and 10psi fed into it). make sure the bung is on very firmly, if it pops off under pressure it creates a brake fluid bomb in the engine bay. skme owino
    diy toe measurer
    toe measurer in service
    now please excuse me, I must pray to the old gods and the new for a 12sec pass
  12. #282
    8,254
    Great stuff mate, might come out sat for a look.
    DJ's don't need sigs
  13. #283
    Aug 2010
    South brisbane
    185
    This thing is kick arse. Well done on the 13.0 last night. God it looks like a handful with the locker..
  14. #284
    . crack's Avatar
    BNE
    2,430
    cheers, you got a great time from your Magna unmod'd
    didn't have the best night. lots of mid 13s with a best of 13.0 @ 107. that's only 0.1s & 1mph better than without the welded diff, 5psi less, 4deg timing less. something is restricting power (head, cam?). my biggest issue of the night was not being able to get the thing into second under load. last 5 runs in a row couldn't get the gear change right.
    didn't end up using the dual stage boost control because with the manual rack and better offset tyres steering went from impossible to tolerable. if I go out again i'll actually use the dual stage boost controller but it will be so I can actually get it into second gear by making things a bit less exciting during that point of the run.
    actually really happy with the car except for the second gear issue (which may just be my shitty driving style). will prob take it out this Saturday for its final runs.
  15. #285
    . crack's Avatar
    BNE
    2,430
    Another day at the drags, another 13.1, bunch of 13.2s and some 13.3s, 13.4s & 13.5s. All at about 110mph. Safe to say it's a low 13sec car but never got into the 12s. Had good fun. Learnt shitloads. Hope others keep on doing the challenge (or derivatives of it) in the years to come. The car will be stripped and scrapped. New challenges await.
  16. #286
    Joel WildZero's Avatar
    769
    It's been a fantastic read, looking forward to your next projects!
  17. #287
    8,254
    This.
    Shame we can't group buy this as a long term pf mobile.
    Quote Originally Posted by WildZero View Post
  18. #288
    Registered User E-Z's Avatar
    3,777
    These things have horrible heads and cams
    This is about the limit even with alot more work into them, fe3 twin cam engine is the next step
    caprice nugget.
  19. #289
    . crack's Avatar
    BNE
    2,430
    goodnight sweet prince...
  20. #290
    [DIRTY31] lysdexia's Avatar
    Apr 2005
    Bunbury
    2,410
    awww
  21. #291
    Registered User INFLYT's Avatar
    N.S.W, Sydney
    457
    WTF!
    Why dude?
  22. #292
    . crack's Avatar
    BNE
    2,430
    I actually feel a bit sad. Had to happen. Wasn't worth much to anyone but me. All safety features (except brakes) were compromised. Wouldn't feel right selling it and the buyer/others getting injured because of it
    edit: ran out of rego and didn't want to renew it as already pay rego on enough cars. don't have a trailer to take it to the drags so it would be stuck at my place unable to be used
  23. #293
    あなたの母親の肛門 Shifty's Avatar
    10,750
    Gearchange thing would be engine/box mounts IMO
    well done regardless, very much in the spirit of this thing
  24. #294
    Registered User wasas's Avatar
    84
    Ok, So I just read this thread from start to finish at work. Was worth it.
    First up congrats on a great project and thanks for sharing it with us! well done for the 13.0, sucks the 12 was never there but for a street reg'd car (hehehe) a flat 13 is mighty impressive! would knock alot of supras off their high horse.
    I'm amazed are your fab kills crack, I've seriously jealous of them and hate you a little... if you're in the inner west and want some cash let me know.
    All the best with the next project, I'll be keeping my eye out for it.
    why do fish sticks smell like chicken?
  25. #295
    . crack's Avatar
    BNE
    2,430
    Cheers. I was way too much of a pussy to drive this thing on the road (fear of getting defected). The only street driving it did was to and from the drag strip. The last drag day I did was with a Supra and Skyline club and I certainly surprised a few of them (they were on street tyres and I was on drag radials but).
    Next project will be a Mirage MR350, which is basically going to be a 1997-2002 Mirage with a 3.5L manual Magna drivetrain in the back of it. Won't be able to start that for a few months yet though. Interestingly it won't be an ICV but a 'modified production vehicle'.
    I don't mind doing a few cashies after hours. Can the job come to my shed or do I have to come to the job?
    This arrived in the mail today:
    Straight to the pool room for it.
  26. #296
    Aug 2010
    South brisbane
    185
    oh so sad to see its finished.. I cut 200 kg out of my 100% stock magna it now does a 14.5 @95mph. I race kids on the street in it too. beating SS's and XR8's in a stock magna is the best $300 ive ever spent
  27. #297
    Aug 2010
    South brisbane
    185
    PS you probably don't wanna hear this now but I could get you a RWC for the 626
  28. #298
    6,923
    Look forward to this..
    this thread was awesome so the next will no doubt be much betterer
  29. #299
    22,979
    You need to use your (considerable) skills and time on something more worthwhile than 13 for 13 projects.
  30. #300
    657
    Great thread, great read, nicely done...!!!
