Results 1 to 11 of 11
Thread: BA Falcon, no action when using key.
    in the doghouse
    Feb 2010
    Bendigo, Victoria
    824
    So My BA has been sitting around for the last 12 months or so in the garage. I stopped driving it after the arse end of the ignition barrel fell apart (apparently a common problem).
    I finally got around to getting a new 'arse-end' for the ignition barrel (had to buy a whole steering column to get it)! Installed it and a new battery last night, went to start it and................... nada.
    Central locking works, hazards work, interior light works, headlights work. But that's it. Radio/ICC displays 'code', smartlock symbol is flashing on the dash (normal rate of flashing, not fast). When you turn the key nothing happens, everything stays EXACTLY the same.
    The part of the ignition I replaced is only the wiring, everything else is original. I have checked the wiring and everything is in the same place on the new one, as it was on the old one. I have checked this against my Territory and it all looks as it should.
    The key clicks around to ACCESSORIES, ON, and START as it should - indicating that everything inside the barrel went back together correctly.
    Kinda need to move it, as it's sitting smack bang in the middle of my driveway where the towie dropped it off.
    Anyone have a fix for this? I've googled around, and it seems as though people just replace everything instead of trying to figure out what's broken.
    But by all means drink a litre of rum, double bag the old fella and grunt one up it. If that floats ya boat.
    9,356
    do you have the valet key? (it comes with the car when new and doesn't need the remote to disable the immobiliser first)
    do you have the manual for the car? there is a proceedure in there to reprogram keys to the car
    in the doghouse
    Feb 2010
    Bendigo, Victoria
    824
    I have two keys & fobs, no manual though.
    Aug 2011
    793
    Key/barrel, BEM and PCM all need to be linked. Maybe a trip to Fraud?
    9,356
    normally one of the keys will start the car without the fob, and one needs a fob (i think theres a transponder in one and not the other that needs the fob)
    http://www.fordmods.com/fordmods-tec...te-t67420.html
    in the doghouse
    Feb 2010
    Bendigo, Victoria
    824
    Quote Originally Posted by 67rce View Post
    They are all still the original parts though?! Will try the other key tonight.
    May 2017
    Christchurch
    2
    Quote Originally Posted by neet_wagon View Post
    How did you get on? Have the same issue only one key fixed tumbler after rear piece fell off now nothing when i turn key
    Struggletown
    6,580
    There's a 5 amp ignition fuse that blows sometimes when you fuck with the switch
    Hold it flat cunt
    4,332
    Also if you try to put the ignition on without the transponder it will log it in the computer and need to be cleared with a scan tool.
    May 2017
    Christchurch
    2
    wouldnt smartlock only prevent the motor starting not the entire function of the key? i still have no function at all no acc dshlights etc i replaced switch have checked fuses seem ok
    in the doghouse
    Feb 2010
    Bendigo, Victoria
    824
    Quote Originally Posted by SteadRB View Post
    It ended up being the fuse, from memory
    Sent from my SM-G925I using Tapatalk
