Page 2 of 7 FirstFirst 123456 ... LastLast
Results 31 to 60 of 201
Thread: Rally Rolla.
    SELLING TOOLS TRAV-KE55's Avatar
    in the shed...........again
    650
    Smee,
    What are you doing with the 1zz you are removing, I'm looking for a cheap one to build for my early corolla for circuit racing.
    Trav
    VALLEY TRADE SUPPLIES
    WORKSHOP & TRADE TOOLS
    PF DEALS WELCOME
    0418 552 413
    Registered tax offender SuperDave's Avatar
    Apr 2010
    West Philly
    2,724
    Quote Originally Posted by TRAV-KE55 View Post
    Smee,
    Trav
    ZRE chassis didn't come with the 1zz engine. You'll have to look for a 2002-2006 ZZE122, or ZZW30 MR-S (they have a slightly better head).
    My car
    Corolla
    I'd have no qualm about punting a kid into the fresh produce section if it meant the difference between getting a set of night vision goggles or not.
    Adelaide, port syieed
    2,532
    Quote Originally Posted by SuperDave View Post
    2ZR-FE is what is currently in there.
    Do not currently need it, but need to see what sensors etc I have to pull off it to fit to the new motor 2ZZ.
    2,532
    So, a heap of stuff taken out.
    A trailer load in fact.
    No hanging panels or bolt-ons attached.
    Had a couple of seized bolts I have had to weld some nuts to so as to get them undone.
    Was considering an Acid dip to get everything out of the car, but think I may be able to get away with a light soda blast which would give enough rough surface for the primer to stick too.
    Petrol tank has a number of crevices in it where stagnant water has been sitting. Think I will be plugging those before it gets put back.
    Will need to do a lot of plating and reinforcing of front sub-frame areas so it does not bend when we hit the first rock.
    A quick measure up will probably see about 40 metres of cage material stuck in.
    About 135kg of interior material taken out so far. Have not weighed wiring loom, exhaust or aircon and heater box stuff.
    16,064
    Don't soda, light sand blast, paint sticks way better!
    2,532
    New motor and a few other bits picked up in a whistle stop trip to Canberra over the weekend.
    Biggest pick up was the new Neil Trama ZZ engine.
    Mar 2013
    Darwin NT Oz (up top down under)
    630
    oooooh that'll go alright
    2,532
    Some update photo's of the shell underside on the spit.
    A shed load of weight 200kg taken out so far.
    1,340
    Can you please give us a bit of an explanation of what you've done so far, type of paint used etc.?
    2,532
    OK.
    Yestreday it left for the cage builders, so it has progressed a little.
    Gustimates are at around 330kg for the chassis. Alas, no access to a set of scales before it left.
    And with that, some pictures.
    2,532
    Quote Originally Posted by mondo2000 View Post
    So far, just taken everything out of it.
    Most bracing has gone, all sound and silly putty.
    Cage will replace bracing in places.
    Interior, engine bay and undercar will be painted in Amaron lusterthane 2pac. Resilient to chemicals and brake fluids etc. Handles rock damage well also.
    Exterior probably in 2 pac enamel similar to my other cars.
    External colour will be a general solid colour, so easy for anyone to mix a match.
    Windscreen is heated, so no need for heater box etc.
    Seat rails incorporated into the cage. Moved internal and back next to B pillar. Also angled in slightly to move head away from roof and roll cage.
    Wiring loom stripped and basic.
    Battery in rear. Switch box to be placed on transmission tunnel.
    2,532
    Some shonkey phone photo's.
    Some cage work progress.
    14,816
    whats all the red marks underneath for ?
    Registered User agentcrm's Avatar
    Jan 2013
    Adelaide, South Australia
    919
    At a guess, they're holes that need welding up to minimise places where dust can get into the car.
    2,532
    Quote Originally Posted by agentcrm View Post
    Car has a shed load of threaded rod sticking out from various places that held on sound deadening, fuel rails, wiring looms etc.
    Also had a lot of bracing for seats or seat belt mounts and interior fittings which have all gone.
    Not needed in the rally car so we take them off and spraying them in red when stuff was removed saved me from removing stuff I did need to keep.
    Underside will have carbon kevlar protection to keep it all nice and shiny and have captive nust placed inside the shell to hold it on.
    Aiming to do the same as I did for my other car.
    5,305
    That 2zz box is manual btw incase u havent had a look.
    2,532
    Did see it.
    Got some stuff off it on the weekend.
    Might go back for a bit more if still there.
    If they scrapped it because it was running rough, then they should have looked in the throttle body. Was blocked closed by green oil paper. Looked like it had been in there for ages.
    Ignitors had gone, and probably first things to go.
    2,532
    More cage photo's
    2,532
    Seat test fitting.
    2 Bricks and a 5mm steel plate is about the required height.
    12,455
    Looking good man.
    Good choice on the floor paint
    Feb 2009
    Gawler SA
    3,334
    Needs one more brace joining the foot of the front bar & underneath the bottom door bar level with the Saintz bar.
    2,532
    A little sideways action.
    Still a couple of bars to go in.
    Downward bar from the A pillar curve to the top of the strut, as well as a bar from the top intrusion bar to the fire wall.
    Behind the firewall where this bar meets is another bar between the front rails. Through this will run the front sway bar. and will also be used to run the rear engine mount off.
    White interior shot is Neal Bates S2000 caged car.
    2,532
    We have seats.
    Almost back in my shed.
    Feb 2009
    Gawler SA
    3,334
    Camsmanual... Schedule J... Section 17...Drawing J 58 & J 59
    2,532
    Quote Originally Posted by Dave75 View Post
    I can't see anything wrong.
    All measurements are correct
    Feb 2009
    Gawler SA
    3,334
    More in reference to Drawing J 58...the shadow line drawing.
    The 70mm recomendation between the "A" pillar & the Saintz Bar.
    [I realize photo's do lie]
    Saintz Bar "should" be straight in side view/bent in front view.
    2,532
    Cage is finished.
    Hopefully truck turns up tomorrow afternoon to help me get it back.
    2,532
    Quote Originally Posted by smee View Post
    Cage is finished.
    Truck turned up.
    Delivered it home for me.
    Nice that it is a long weekend and I can start on it.
    Pictures soon.
    Quaife responded to my email, so gearbox invoice being raised.
    9,231
    Speaking of Bates, I was there today and got a chance to drool over the 1995 ARC Havoline ST205 which he's bought back and is now restoring. Amusingly it's in a similar state to how it was when I did work experience there in '95! There was an S2000 Corolla hiding in the corner of the workshop partially stripped as well, among other tasty treats.
    2,532
    Speaking of Bates, I was there today, There was an S2000 Corolla hiding in the corner of the workshop partially stripped.
    It's still there.
    I might need to get some more photos of the front end setup around the radiator and engine mounts.
