Page 3 of 7 FirstFirst 1234567 LastLast
Results 61 to 90 of 193
Thread: Rally Rolla.
    Adelaide, port syieed
    2,496
    Dash has been test fitted and aligned.
    Will now flock it.
    Have started on welding up small holes and plating around area's the cage comes through.
    Paint stripping, kevlar underbody and sundry item making has also commenced.
    ECU being monitored.
    Now to figure out the electric power steering conundrum.
    How to make a toyota corolla electric power steering system operate without an ECU.
    Registered User MWP's Avatar
    1,689
    Quote Originally Posted by smee View Post
    The only way to do it is feed the EPS controller with valid canbus messages. Youll need a black-box of some description to do that, and AFAIK no one makes them.
    There is no easy work-around like can be done with the non-canbus EPS controllers.
    I very much doubt youll be able to use a non-canbus EPS controller from a different car (ie, non-ABS equipped Yaris) with the column either.
    The column torsion bar, position sensors and motor will be matched to the EPS controller.
    Death is for pussies... 6000SUX's Avatar
    Aug 2006
    3,008
    There's lots of threads around on various forums on EPAS conversions but most of them seem to use an Opel Corsa or Holden Barina EPAS. they are especially popular on Gt40 kit cars.
    There's a company in Brisbane called Ultimate Power Steering that does Motorsport EPAS kits and they have a signal generating controller for their units. Maybe it can be adapted to yours? You may be lucky if the motors are both Bosch for example.
    http://www.ultimatepowersteering.com...d-wiring-loom/
    Can I wear the Scream mask? The mask from Scream... when I do you from behind...
    2,496
    Quote Originally Posted by 6000SUX View Post
    Spoke with a company in Ireland that makes a lot of kits for rally cars over there.
    They are currently doing something with a Toyota Yaris system I believe, so have sent them pictures of my column and motor.
    Will wait and see what comes of it.
    Gearbox paid for and in a box soon I hope.
    Murrayflex modifications are next on the agenda.
    1,689
    If you haven't seen this yet Smee, here is a write up of using the non-ABS Yaris EPS:
    http://www.toymods.org.au/forums/eng...-steering.html
    2,496
    Rallywiz is the group I have been speaking with.
    They seem to think because it is so tied in to the canbus it may not be possible to utilise it.
    The Prius and Yaris system seems to be unit of choice now.
    Have also spoken with the guys from QLD.
    May be that I have to change out the Corolla's system and put a generic system in.
    1,689
    How long have i been telling you this for?
    Never even considered looking at the Prius system. Thought it would run on higher than 12V and use canbus.
    Im looking into the RAV4 system at the moment.
    As its built for a heavier car, its should have a larger torsion bar in the column meaning it'll have better steering feel when assistance is turned down.
    2,496
    Don at Rallywiz has been very good.
    If nothing in the next week, or the Yaris system is too expensive considering electrical requirements, then an Ultimate Power Steering unit it is.
    Update,
    Don has bought a steering column from an Auris (UK Corolla) and is working on it.
    Might take him a week or so, but it offers another item in their store if it can be done.
    2,496
    Motec M400 with loom sourced.
    Hopefully no scamming this time.
    2,496
    Gearbox is in the building.
    8,251
    awesome
    DJ's don't need sigs
    2,496
    Floor mounts and false floor setup.
    Amazing the use you can get from an empty slab carton.
    Mock up of seating and pedal setup.
    2,496
    More stuff going in.
    Seat and wheel setup looks ok.
    False floor done, Navs footrest and fire extinguisher mount
    Footrest has the ability to move up to about 20cm's
    2,496
    Some more stuff.
    Coming together.
    Mar 2011
    Quindanning WA
    436
    Looking pretty damn good.
    I've been building a cage and whenever i've got stuck i've been using your photos for guidance and inspirations... Thanks.
    2,496
    Quote Originally Posted by kneelo View Post
    Hey Kneelo, thanks.
    Every picture I have taken of strip down and build up is located here.
    Has a shed load more photos.
    Rally Rolla Photo Library
    2,496
    Currently doing this.
    Recalcitrant Swill's Avatar
    1,090
    Needs moar throttle bodies
    Looking for 86 GSXR bits. PM me
    2,496
    Quote Originally Posted by Swill View Post
    What !!!! do you think I am made of bricks /Sydney Snot
    1,090
    Sell a push bike
    2,496
    Sell a push bike
    I should do that.
    I have 2 I have not ridden in a while. Both Carbon.
    2,496
    So, things are progressing.
    2,496
    Sand blasted, primed and ready for paint.
    2,496
    So, did a bit of work over this long weekend.
    Seam sealing, hole plugging and topped it off with a bit of paint.
    2,496
    A roll through CAD image showing the structure of the roll cage fitted to McMRallysports new Corolla Rally car. #RallyRolla
    Thanks to my navigators nopics for the design and image.
    Dec 2012
    103
    Rally car builds are so wild, keen to see the progress of this!
    2,496
    So, have done a little bit more work on sundry items.
    Underbody protection.
    Heat shield along the exhaust tunnel
    Seats, firebomb, fuel tank protection.
    2,496
    The fuel system installation has commenced.
    Swirl pot and pumps.
    Fuel tank and guard.
    Fire bomb and lines.
    1,689
    How can a surge tank work in that orientation?
    Surely it reduces its effectiveness?
    2,496
    I still have a return line to fit to the tank.
    Bottom 2 lines feed pumps.
    Top line is return to tank, and next to that is the return line from the fuel rail.
    Slightly lower is input from tank..
    Fuel pumps will feed line to fuel rail.
    Tank is only 1 litre in size.
    Seems to have been working fine for competition Lotus vehicles, so thought I would try my luck.
