Page 3 of 9 FirstFirst 1234567 ... LastLast
Results 61 to 90 of 249
Thread: Shitty ebay spec VN IP Racer.
    8,590
    Have you weighed the wheels yet?
    Apr 2003
    Roleystone
    3,382
    Not yet checked weight, Tomorrow maybe?
    Calipers arrived.
    Looks like it will stay VN, Can't use the 6speed with LRA in a VS.
Name:	Front Caliper.jpg
    GURU ENGINEERING PTY LTD
    Apr 2010
    93
    Could you log book it as a GTS didn't they come out with a 6 speed. I don't know how many we're made though or just lock sixth gear out like others do (from what I've heard)
    Apr 2003
    Roleystone
    3,382
    Quote Originally Posted by ova400 View Post
    They were IRS, i want to run live rear end.
    Rims are 10.5kg
    Apr 2003
    Roleystone
    3,382
    Clutch is finished, Next is Fit up the NASCAR 9" along with a Momus Watts kit.
    Body and Cage are about a week from finished also.
Name:	Old v New.jpg
ID:	67350   Click image for larger version.
Name:	VN clutch1.jpg
ID:	67351   Click image for larger version.
Name:	VN Clutch ready.jpg
    Aug 2011
    ohio, ca
    10
    I usually dont buy from net because of that reason! Usually I find the quality of things bought from net very cheap..
    Apr 2003
    Roleystone
    3,382
    Ive been very luck with ebay, Everything turned up as described. Ebay has made it possible to keep this car way under 20k Possibly as little as 15k but still has a lot of very good parts.
    The whole clutch and flywheel came in a little under $450 total with only the black cover and flexplate 2nd hand. Only the outer section of the flexplate remain.
    Registered User Chisholm's Avatar
    Apr 2007
    671
    Good stuff, keep the updates coming please.
    Everytime I see this thread I chuckle that your idea of a "shitty IP racer" includes dry sump, built motor and 6-pot Alcons
    It's amazing how cost-effective you are being with ebay parts and own workshop/mad skillzzz.
    Apr 2003
    Roleystone
    3,382
    I found a Holinger for the right money but my son decided to save that for the 240Z Sportsedan so this car is staying with the TKO600. I strayed from ebay with the TKO, That came from Gumtree but they are related company's.
    Front Rotors and Hats are still needed for the Alcons.
    The Diffs are working out very well,ended up with 2 as the second was $125 brand new with axles and floating ends, Can't believe how light they are, Just need to send some coin to Momus for his Commodore Watts link kit. Not ebay but his a guy known to know what he is doing and its cheap enough to make it not worth making myself.
    Ill take pics of the Diff as it comes together, It just looks so cool with those big Alcons hanging off it. Carrier and Pinion support are due tomorrow, Also not ebay, Summit worked out best value for those but the Spool,gears and bearing kit was ebay
    Anyway, All the big step stuff is happening, The whole drive train will be in by mid Aug after Paint and cage update.
    7,829
    nice progress.
    who shrunk the clutch though?
    Apr 2003
    Roleystone
    3,382
    I don't want to make much power as LS engines are not as strong as people want to believe and a light clutch helps. It is triple plate tho.
    Apr 2003
    Roleystone
    3,382
    Measuring the 2 diffs to workout what way Im going, The 1 with brakes on is -1.68R-1.68L the new one is -1.7R +1.7L but is about to be -2.5 -2.5.
    I had Pins and hub sent to give me options as they are so cheap.
    Used diff and brakes are like new.
ID:	67359   Click image for larger version.
Name:	Spare diff2.jpg
ID:	67360   Click image for larger version.
Name:	Spare diff3.jpg
ID:	67361   Click image for larger version.
    Apr 2003
    Roleystone
    3,382
    I have 1 new ACT multi puk clutch and ultra light Flywheel $1000
    1 Lightly used NPC Twin plate Clutch, Flywheel and Tilton Bearing $1500.
    Not open to offers at this time as the prices are fair.
    26 spline LS Holden/Chev inc T56, TKO, Holinger and most other GM Box's.
ID:	67377   Click image for larger version.
Name:	LS ATC Flywheel.jpg
ID:	67378   Click image for larger version.
Name:	LS ATC ID.jpg
ID:	67379   Click image for larger version.
ID:	67380   Click image for larger version.
    Apr 2003
    Roleystone
    3,382
    Sold the twin plate.
    TKO600 is here now so motor and box can go in in the next week or so.
    Now I'm trying to workout the best front bar for IP?
    1,609
    A few of the VN's at the sandown IP meet ran a VN group A style bar and then added a splitter to the bottom of it to get it to the maximum of the regulations . Regarding rear guard mods , one of the VN's had some decent flaring of the rear guards going on .
    Acads
    Sandown 1.23.31
    Calder 1.05.76
    Phillip Island 1.47.95
    Winton 1.33.30
    Bathurst 2.47.49
    Apr 2003
    Roleystone
    3,382
    Yeh Ive seen some dodgy Flare on VN IP cars, Mine was a bit flared but I took them back to factory.
    Custom front bar worries me, Id like something fast and easy to change if I have any problem with the "Push 2 pass" system.
    1,609
    Wasn't it going to have a Holinger?
    Claimed horsepower sceptic.
    1,609
    They aren't really custom steve , just he splitter is added . Eziglass in melbourne stock the VN GRP A mould andif they are like my Walky front bar you use the the bumper reo to locate the bar then weld a nut to the reo and bolt through the front . Sides are located by the same method but using the lower part of the front 1/4 panel , 10 minute removal and replacement .
    Acads
    Sandown 1.23.31
    Calder 1.05.76
    Winton 1.33.30
    Bathurst 2.47.49
    Apr 2003
    Roleystone
    3,382
    Quote Originally Posted by Momus View Post
    Was but now saving Holinger for the 240Z Sportsedan build.
    VNs kind of a secondary project.
    Apr 2003
    Roleystone
    3,382
    This is now forsale as unfinished project. Huge amount of parts with very little needed to finish.
    Sticking with Karting now. 20k the lot as is, No splitting no offers,Been offered 1/2 this for the engine.
    Registered User full_noise's Avatar
    perth
    100
    Interested - can you email details???
    Apr 2003
    Roleystone
    3,382
    Its would be easier for you to have a look, Im only in Roleystone. It would be hard to list all the parts.
    Apr 2003
    Roleystone
    3,382
    Basic list of Parts.
    L98 long motor.
    Lunati Conrods, CompCams Valve train from Chain and gears, Cam, Lifters, Pushrods,Shaft mount Roller Rockers, Springs, Collet 2sets retainers,and locks.
    Tall Valve covers, ATI Balancer, LS7 Drysump, QuarterMaster 7.25 Clutch and Flywheel,ARP head studs Pistons are used but Hi Comp Forged.All balanced, Can Finish the Engine for an extra cost. M48 Motec and Ignition expander. Alloy Radiator and Hand made $5000 Headers and full Exhaust.
    L98 intake with new large Throttle body.
    TKO600 Gearbox,Bellhousing and Quartermaster thrust bearing with full L/H Starter motor kit.
    After market Cambered 9' floater as seen in this thread with huge Alcon brakes all 100% complete inc pipe work., Correct width for VN, New Nodular Iron center, new Daytona Pinion support,New 31 spline full Spool and used Polished Premium 3.62 gears, New race Pinion with V belt drive for the included dual stage Diff and Gearbox Cooler pump,DJR type, Full Diff build kit inc all shims, bearings and ARP bolts etc etc,Diff can be built at extra cost.
    Alcon 6 spot front Calipers,Not used for a while so seal kit would be a good idea.
    Much Ive forgotten but can show genuine interested people.
    Logbooked IP VN with basic Suspension and cage ( I was going to upgrade cage)with Fuel system using factory base tank but good pumps and surge tanks and rear mounted reg to suit LS engine. The car last raced as an LS so all mounts and assorted hardware is there. Paint needed on L/H rear 1/4 and L/H front guard, rest will polish up ok.Theres no seat but everythig else as last raced is still there. Has new 18x9 rims as per Pic's in this thread. SV5000 body kit. Momus has the right Watts link kit for this car at a good price. Been offered near 20K just for Engine and Diff but will not split.
    8,590
    You might want clarify above, it says you spent $5k on headers.
    Would be a good buy for someone.
    Apr 2003
    Roleystone
    3,382
    The headers and exhaust did cost about that. Shelf items are not much good.
    Exhaust was paid for by first owner.
    8,590
    Holy fark! Thought it was a typo!
    Apr 2003
    Roleystone
    3,382
    Barney had Quotes around that just for the Headers on the Fox Mustang he is building.
    Apr 2003
    Roleystone
    3,382
    Ok, Its back on track, Body is now ready for paint. No longer for IP, IP's Fucked, I'm running Streetcar, Basically Floorpan Sportsedan with R'comps and limited body modd's. Will be left IP eligible but with better Aero and no lead.
    Apr 2003
    Roleystone
    3,382
    Ok, Theres only a few weeks left to finish this car. I'm over it but Ashly is going to run it.
    Got a free Watts link for it this weekend.
Name:	Ash Watts.jpg
    Nov 2007
    303
    Who's that good looking bloke?
