Page 1 of 4 1234 LastLast
Results 1 to 30 of 91
Thread: TTR635 Project
    Aug 2008
    2,113
    TTR635 Project
    Rescued this little fella from gumtree for a bit of a project. It's a 1999 Yamaha TTR600 Belgrada, Italian manufactured with 46mm Paoli fork, Ohlins shock and Brembo brakes . It wouldn't start for the previous owner so I picked it up for next to nothing. It came with new tyres, Pro Taper bars, barkbusters, single seat mod plate and recent chain and sprockets. I got it home and bumped it over compression by hand and heard a pushhhhhttt from between the carb and the cylinder head. Both inlet manifolds had broken away from the aluminium.
    I've always liked this series of engine but never owned one before. Plan is for a general tidy up, Wiseco 635cc piston, basic porting, 3 angle valve job and squish clearance set.
    Everything has a stained on layer of red dirt
    Broken inlet manifolds
    A quick peek inside looks better than I expected, not burnt on sludge
    Registered User Gats's Avatar
    7,168
    Looks pretty decent apart from the inlet manifolds.
    Aug 2008
    2,113
    First job: Carb
    Yamaha Dual Intake System (YDIS) setup. Photos also for reference in case I need to look at them to put it back together...
    Broken diaphram
    Jun 2005
    Sunshine Coast
    376
    always wondered what these are like compared to an xr600. good project
    get lead like a leader
    Aug 2008
    2,113
    Thanks
    Aug 2010
    show bobs
    2,587
    Awesomes! Italian manufacture?
    You gonna fit a towbar? :P Should have some pull when finished
    Aug 2008
    2,113
    Yep, Euro Yammie
    Ordered a few parts. Surprisingly Amazon.com was the cheapest for the piston kit at $140ish.
    1,340
    These were teh shit back in the day, when plastic fork protectors were used on RWU forks
    Nice bike.
    Aug 2008
    2,113
    Thanks mate
    Carbs complete
    Penrith
    1,625
    Motard that shit son!
    Aug 2008
    2,113
    Hmm that looks pretty tidy, but I alread have a motard TE.
    Aug 2008
    2,113
    4,768
    wow -no messing about !
    i allways worry when i pull them apart -takes years to get back together
    Aug 2010
    show bobs
    2,587
    I recon he'll have it back together by the next post!
    15,636
    Aug 2008
    2,113
    Yeah things got a bit out of hand today, I didn't really intend to go that far...
    Gammaboy- correct
    It is 0.5mm oversize with a genuine Yamaha piston. The piston would have probably measured up ok, the rings wouldn't have. I was worried it was going to turn out to be a chrome bore model and I would have to sleeve it, luckily iron. New 98mm piston is advertised as 10:1 comp ratio up from 8.5 or so standard.
    The cam, plain bearings, rockers and cam chain sliders look to be in great condition. The crank feels good so I don't think I'll split the cases.
    After a fair bit of research boats.net come out the cheapest for OEM parts at about 1/3 of the quotes I got in Oz.
    Ohlins got back to me about the oil and nitrogen pressure for the shock so I hope to have a crack at servicing that soon.
    Found parts fisch here: http://www.megazip.ru/ru/bike/yamaha...7/16167/200157
    Found Factory service manual here: http://service.tanga-moteurs.ro/
    Aug 2008
    2,113
    15,636
    Aug 2008
    2,113
    Would be interested to hear the oil/pressure spec, I've got an old ohlins I need to put a longer reservoir hose on...
    10w and 140psi
    15,636
    Aug 2008
    2,113
    A schrader valve if that's what you mean by needle valve?
    15,636
    Aug 2008
    2,113
    Nek day:
    Aug 2008
    2,113
    Cheers, they're a needle type inflator aren't they?
    14bar, I remembered incorrectly.
    Aug 2010
    show bobs
    2,587
    Porting is bulk sexytimes!
    Aug 2008
    2,113
    Parts starting to come in. Forged 98mm piston.
    4,768
    ^^^^its up side down - send it back
    Registered User Mini_Me's Avatar
    2,295
    This bike is v cool! Nice project
    Aug 2008
    2,113
    I started on the forks but struck a few problems. Seals are the wrong size, bushes worn, base valve wont come out of one fork leg without a special tool. The leg that the base valve won't come out of is barely compressable, I have no idea what could cause that, it's like someone has put a massive spacer on the spring to preload it.
    Base valve disassembled for cleaning.
    Full break down, pretty simple.
    Aug 2008
    2,113
    I got bored while I was waiting for parts and this happened:
    Then the parts turned up, mostly bearings and seals for wheels/linkages/swingarm/shock
    Not sure what to do with the forks yet, bushes need doing and it's worth about $400 in parts. Thinking of doing a mx USD fork conversion.
