Results 31 to 60 of 91
Thread: TTR635 Project
    Jan 2006
    5,774
    I have always liked these things. Impressive resto mate.
    Aug 2008
    2,100
    Thanks. I've learned that doing an XR would have been MUCH easier tracking down parts (excluding the engine because it shares 99% with XT/TT). Italian Yamaha /= Japanese Yamaha in terms of availability or aftermarket support. There is going to be some bearing shop visits and reverse engineering to be done yet to get it all up to scratch and not cost a bomb.
    Aug 2008
    2,100
    Migaloo's cylinder and valve seats came back
    Bit of a question mark on the valves though. The exhausts had a slight run-out and appeared to have a hard facing that required grinding through to clean up. I'll have to replace these. The inlets are better although I'm not sure whether they are able to be refurbished or need to be replaced to.
    Seats copped a touch and come up nicely on the 1mm margin called for in the factory service manual.
    Dremel will have to come out again to maybe do some valve un-shrouding pending compression ratio check.
    Aug 2008
    2,100
    New valves and springs ordered.
    Also agreed to buy a complete secondhand Husqvarna TC450 front end to adapt. Marzocchi Shiver 45mm USD fork, Brembo brakes, Excel rim.
    Jan 2006
    5,774
    Price when complete
    Aug 2008
    2,100
    Ha, I'm OCD about rescuing poor neglected mechanical things, I would struggle to let something go that I've done too much work on
    Jun 2005
    Sunshine Coast
    375
    nice
    get lead like a leader
    Aug 2008
    2,100
    Bit of history on the 600R model:
    http://www.shag.com.au/dirtbike/historyTT600.php
    Aug 2008
    2,100
    Aug 2008
    2,100
    Forged triple clamps, Excel rim, Brembos, and Marzocchis. Should be a fair whack lighter than the originals while being stiffer, work better and better parts availability. I just have to get cracking on the conversion. New tank arrived to, 20 ish L.
    Aug 2008
    2,100
    I started comparing the triple trees for the conversion and it is looking like there will be minimal work to get it to work. The bearing shells were a pain to get out of the frame as there was almost no lip to apply force on. I also pushed out all the swing arm bearings and seals with a vice and my trusty socket set. A press would have made it a lot easier.
    Aug 2008
    2,100
    It came up 9.8:1 compression ratio with 1.5mm squish clearance.
    Jan 2006
    5,774
    Eta to massive, ag pump sounding wheelies ?
    Aug 2008
    2,100
    Fair bit to do yet, id be surprised if it is going in a months time really with a busy work schedule. I could only get half the linkage bearings and seals mail order so there is some measuring up to do. I'd like to get grease nipples on them all to.
    Aug 2008
    2,100
    Thoughts/advice on 1.5mm squish clearance? I have some scope to reduce this with a thinner or removed base gasket. Big end and mains are rolling element bearings.
    1,330
    I found this photo on the Ohlins website. 2WD TT600:
    1,330
    1.5mm is about 60 thou? which is a lot, but then again it has a big bore and stroke, so check with someone who has experience building thumpers.
    Aug 2008
    2,100
    I feel like making a set of long primary headers after seeing that. I think I like that hydraulic motor type front wheel drive than the super complicated Christini system.
    http://www.christini.com/awd-technol...the-technology
    4,751
    accepted wisdom is generally 40 thou (1mm).
    if me i would see if can reduce.
    maybe mill small 25 thou (or whatever)dish in piston to compensate if comp is going too high.
    crown will be thick enough -as already has valve cutouts
    Aug 2008
    2,100
    I could maybe go thinner on the base gasket?
    Aug 2008
    2,100
    Fail box. RH case is cracked between the gearbox shafts. Also needs a new 3rd gear set. Suprisingly the clutch basket is great, not sure what to do now as the cases are unique to the kick start R model.
    I was pretty pleased with my flywheel puller that I made, worked a charm.
    15,469
    Get it welded and remachined?
    Aug 2008
    2,100
    Got any process tips? It's not really something I have got done before.
    There is a bearing retainer plate thing (part 15) that bridges the cracked area. I might be able to make something beefy for both sides during the welding to limit distortion. I think it would have to be reienforced somehow as due to the reduction of strength in the heat affected zone.
    5,327
    That's twice now I've come here expecting a cool BMW. Shit.
    Quote Originally Posted by piss98
    I wish Kochie would get blown out to sea and never found, in fact most of those dumb cunts standing in the rain telling people not to stand in the rain need to get fucked. Stupid tart on the news last night talking to the weather guy "wow you look totally drenched there whateverthefuckhisnamewas." No shit you vapid bitch he is standing in a fucking cyclone.
    Aug 2008
    2,100
    Just going by photos I think I can increase the thickness of part 15 to at least the height of the adjacent bearing which should add some stiffness to the area.
    15,469
    Yeah, send it to someone who knows what they're doing... I'd use Niccom (Niccom.com.au), but there's probably someone closer to you.
    Aug 2008
    2,100
    Thanks, I'll get in touch with them.
    Aug 2013
    australia
    2
    TTR635 upgrade
    Gday, I have a TTR600 got it in 2004 brand new, Rode it for a few years then decided to modify.
    Long story short it was getting very rattly, discovered counter shaft key way flogged out so save it from destroying itself.
    rebuilt keyway and locktighted in key, its a common problem.
    disconnected black and red wire on CDI this cuts out rev limiter.
    Top end rebuild cleaned up ports ,valves recut and kibble white racing springs and titanium retainers fitted.
    Bored out for 98mm wiseco piston.
    split the cases replaced all bearings and 4th and 5th gear.
    Fabricated 1 into 2 alloy manifold for 40mm mikuni pumper carb.Name:  TTR600 001.JPG
Size:  145.8 KBName:  TTR600 002.JPG
Size:  147.8 KBName:  TTR600 003.JPG
    Fabricated stainless oil tank for increased capacity 3.5 ltrs and access to carb.Name:  TTR600 004.JPG
Size:  148.8 KBName:  TTR600 005.JPG
    Fabricated alloy airbox access from top using XR600 filter standard airbox useless offroad dust ingress all the time.Name:  TTR600 012.JPG
Size:  141.7 KBName:  TTR600 013.JPG
    Hope this helps with some idea's, The Paioli forks are a good unit if tuned correctly they are a copy of the Kayaba so all bushes and seals fit.
    Post any questions as have tinkered with the TTR600 for years and might be able to help out,Cheers.
    Aug 2013
    australia
    2
    TTR635 upgrade
Size:  154.1 KBName:  TTR600 009.JPG
Size:  149.8 KBName:  TTR600 010.JPG
    Mikuni mounted on manifold ,Mods were done 6 years ago so has stood the test of time ,High revs and long kms.
    Aug 2008
    2,100
    Awesome! thanks for sharing so much info.
    I'll be sure to pay special attention to keys when/if mine gets back together. After much internet trawling I found one person talking about how they had found a Yamaha manual with a ignition vs. revs graph and it had a second curve for the black/red wire disconnected that was 6 degrees further advanced everywhere. Mine was already disconnected when I got it although I haven't had it running yet to test the theory.
    I opted for new valves because the machine shop said that they were initially hard to grind then once through the outer layer got softer. If I had have known about the Ti retainers I think I would have bought a set. Are they Kibble White as well? I might have to look into it.
    That's interesting about the Paoli fork. I might have stuck with them if I had have known about alternative bushes. The parts I priced up locally came to about $400 including seals. That's what gave me incentive to look for something else.
    I was looking at my air box and was wondering how it would go. There is nothing positive to compress the outer edges of the filter on to the air box. There is also a joint line between the cover an main box that would have to have a small unsealed area. I like your compressed down style air filter better.
    Have you heard of any other TT600Rs cracking the cases like mine? If it is common it might influence my next move. I was thinking it might be better to buy another good tidy bike and swap my good bits into it but I'm worried it will have cracked cases to.
