Results 61 to 90 of 158
Thread: Electric turbo?
    16,340
    Meh
    Jan 1970
    26,940
    Early 90's pommy classic car mag, will dig it out and scan if I remember on Sunday.
    Taaaaaaaaaaaaaa.............
    Feb 2005
    TEXAS, QLD
    9,555
    I still don't know why you wouldn't smash a big electric motor onto the front of the crank and hook speed controller up to throttle.
    16,340
    Meh
    Jan 1970
    26,940
    They built what was basically a tiny Bentley motor (complete with the crank/rod drive for the cam) to run it, but didn't finish it, and from memory they used an Austin seven motor to drive the blower instead... Had full boost available at idle...
    Righto.
    Whilst it's nice to have full boost available at low revs you can't actually use it though, the engine will often ping itself to death. But for sure it'd be nice to be able to get a bit more air flowing at low revs.
    14,988
    Only advantage of a electric turbo using current technology i see is, using one to build boost on a drag car on a compound type of set up
    11,230
    Because you would make more power by using the electric motor to create boost. I think it would be better to use a FWD hot hatch, then join the electric motor to the back wheels rather than join it to the crank. Something like that would be pretty cool. But the costs would be huge for an motor worth installing.
    10.83 @ 125
    10,741
    Mylib, I reckon you're onto something. Perhaps a regenerative motor charging a battery pack that can then be used as an additional power source to redrive that motor.
    Maybe call Toyota and see if they're keen for this in the Camry. Could call it KERS or something.
    Sep 2006
    adelaide australia
    80
    11,230
    Great so it works!
    Cliffs, T3 compressor with 50,000 rpm brushless motor, using 2 x small motorbike batteries drawing 150A gave 4.5psi down low tapering off to 2.5 psi for 30% more torque and 25% more power on a VW golf.
    This is a very worthwhile gain with only 150A draw. Its unclear if the batteries were in series or parallel, so its hard to gauge power draw. It is either 1.8 or 3.6kw. If it was a 12 volt system that gain is VERY impressive for only 1.8kw of power consumed. They noted there was no tendency for the batteries to run flat.
    With a bigger motor and turbo impressive gains are to be made. I assume larger compressors need less RPM, so might be better suited to the speeds we can get from electric motors.
    10.83 @ 125
    Meh
    Jan 1970
    26,940
    Good find!
    Quite a clever idea there, I like it. I like it better than any of the other ideas here in fact.
    11,230
    Like putting a high RPM dc brushless motor onto the compressor side of the turbo? Missing italics?
    10.83 @ 125
    Meh
    Jan 1970
    26,940
    No italics - as I mentioned earlier if you put an electric motor on the front of a turbo you still have to have a decoupling the motor from the turbo when it spins up. And also keep the air clean with all the mechanical bits sitting in the compressor inlet.
    11,230
    Bill this guy has done EXACTLY what I have been talking about. If you had something else in mind, it may have been due a bad description on my part
    Edit, read the first post again. Its pretty clear I thought?
    10.83 @ 125
    Meh
    Jan 1970
    26,940
    Bill this guy has done EXACTLY what I have been talking about. If you had something else in mind, it may have been due a bad description on my part.
    Oh okay sorry, I may well have miss-read what you wrote.
    I thought you meant spinning-up the turbo that's already sitting on the engine.
    Anyway, good idea matey!
    (Just looking at electric motors now .....)
    11,230
    OK, I will find my old RC-groups log in. If anyone knows about these motors it will be there....
    10.83 @ 125
    Meh
    Jan 1970
    26,940
    Good idea.
    FWIW this one - http://www.hobbyking.com/hobbyking/s...ner_Motor.html should do about 22,000 rpm with no load.
    You can calculate the rpm by looking at the revs/v, which in this case is 500rpm/v in the specs. They state a 12s battery so that's twelve 3.7 volt cells or 44.4 volts.
    20,000 rpm odd is starting to get useful I reckon.
    Meh
    Jan 1970
    26,940
    This one does 57,000 rpm but I doubt it'd have the grunt to spin a turbo compressor fast enough.
    11,230
    Yeah bill that seems to be the prob, the faster units lack the power.
    Just made a thread in the section about custom motor design: http://www.rcgroups.com/forums/showt...5#post25087044
    You think 20,000 will be enough? I asked about 50,000 plus. Lets start getting technical with compressor maps etc. That's not my area of expertise. (not that I have one )
    Here is a GT3071. Seems not much is happening below 59,000 rpm, which is where the map starts. Smaller turbos need even more RPM. Now I guess someone will be able to use the chart to calculate the power required by using efficiency, air flow and pressure ratios etc. I assume there are laws which govern how much energy it takes to compress X amount of air...
    10.83 @ 125
    Meh
    Jan 1970
    26,940
    I don't think you'll find a single model aircraft electric motor that can do what you want, but maybe if you join two or three end to end ...? Make the electrics complicated though.
    I pictured more of a system that made the main turbo on the engine wake-up a lot earlier and so you could get by with a relatively small unit and a single motor.
    11,230
    There is always gearing, but I want to explore all avenues with different motors first. The forum I asked on is the custom motor section, so if its possible I think I will get an answer there.
    10.83 @ 125
    Useful cunt littlefireyone's Avatar
    North QLD
    1,182
    Dark orange touched on Variable Vane Turbos before, and honestly that is perhaps the more logical method of using boost pressure quicker. Not sure they offer those in big turbos though. My quick ponder is to retro fit the flange with a nozzleing system to increase exhaust gas velocity to the exhaust vanves at low rpm ,essentially a moving version of what twin scroll flanges do quite well now. The downside I forsee is getting a moving part to work properly and reliably in that heat.
    Edit: Had another though, the nozzles have to be as simple as possible, so perhaps they can be on isolated large springs that will move them under the right amount of boost.
    4,872
    in a similiar vein - but aeronautical
    early ' jet'
    1940 camproni :
    piston engine drove compressor which put air into a combustion chamber and fuel added
    hey presto a quasi jet engine.- with all the weight and ineficiencies of a piston
    engine and not harvesting the exhasut energy to dtrive the compressor.
    but it did fly
    http://en.wikipedia.org/wiki/Caproni_Campini_N.1
    As designed by Campini, the aircraft did not have a jet engine in the sense that we know them today. Rather, a conventional 900 hp (670 kW) Isotta Fraschini L.121 RC.40 12-cylinder liquid-cooled piston engine was used to drive a compressor, which forced air into a combustion chamber where it was mixed with fuel and ignited.[2] The exhaust produced by this combustion was to drive the aircraft forward. Campini called this configuration a "thermojet," but the term "motorjet" is in common usage today for this arrangement since thermojet is now used to refer to a particular type of pulsejet (an unrelated form of jet engine). It has also been described as a ducted fan.[3]
    4,872
    and thinking the other way - have a turbine in the exhasut (ie normal turbo hotside) and via a gearbox connect it to an alternator - trim the turbine wheels so it only extracts 10kw(or whatever the alternator needs)
    hey presto
    drive your 250 amp alternator off waste exhasut gasses , with no engine performance loss and charge the batteries -to drive the electric compressor .
    11,230
    Getting there. 60,000rpm but only 2.2kw with 4.5kw surge, at only 26V
    http://www.neumotors.com/Site/1500_series.html
    10.83 @ 125
    14,988
    Cuntberra
    6,094
    I will find you a motor i'll have to find the link again iirc it will do 80,000 takes 48v and outputs 5kw.
    Opens AxGT's Avatar
    Brisso
    1,957
    Not sure if its been mentioned, but the 205 T16s apparently had a motor on the turbo charger to stop it from slowing down when not being actively driven by exhaust gas.
    There is also this entry on wiki:
    http://en.wikipedia.org/wiki/Hybrid_turbocharger
    The guys doing it there have a 26kw motor though
    Dirty Subaru owner
    11,230
    Cheers guys.
    Here is a calculator used to figure out how much power it takes to compress air. I'm just guessing figures here.
    NA 2 liter engine will draw a max of around 210cfm? 2L X 6000 rpm / 2 (because of 4 stroke) = 6000lpm. Convert to CFM = 210 cfm @ 100VE.
    This engine will consume 315cfm at half a bar boost. (210cfm X 1.5 absolute pressure)
    So if I enter 315cfm and an absolute pressure of 22psi (roughly the absolute pressue at sea level plus half a bar of boost). It comes up with 9.2hp required when using an adiabatic expansion coefficient of 1.41. Not that know what the expansion coefficient should be.
    Maths check anyone?
    http://www.engineeringtoolbox.com/ho...ir-d_1363.html
    Anyone care to guess how much HP a theoretical 2L engine with a 100% VE will make @ 6000rpm with 0.5 bar of boost? If this calculation is even remotely correct it shows that the amount of HP the turbo will require is very small compared to the total output of the boosted engine.
    10.83 @ 125
    Feb 2005
    TEXAS, QLD
    9,555
    Have you attached the electric motor to your crankshaft yet?
