Page 5 of 6 FirstFirst 123456 LastLast
Results 121 to 150 of 158
Thread: Electric turbo?
  1. #121
    canberra
    3,648
    Turbos take a decent amount of power to run...nothing is free. But, and it's a big but, combustion engines are horribly inefficient so there is heaps of left over energy in the exhaust gases (in the form of heat) to drive the turbo....that's why turbo power is essentially free and SC have a high parasitic load, but both shift the same amount of air. Simplistic explanation but that's the guts of it.
    GT8
    1UZ Celica
    1.07 flat Wakefield Park
  2. #122
    11,230
    The power to turn a turbo with exhaust gas is not free, but harnessing the exhaust pressure is far more efficient than a direct drive (or electric). Since intercoolers work pretty well at negating the effect of the inefficiencies of the compressor side (heat) , the only explanation to why big turbos make more power because they have less parasitic loss (less back pressure).
    10.83 @ 125
  3. #123
    Cuntberra
    6,094
    I think all the ideas talked about in this thread are outweighed by the idea of using a turbine to put power back to the flywheel.
    This system will give a 13l 6cyl 500hp engine a 50hp boost the efficiency is far greater than any other idea that 50hp could be used to drive a supercharger but all this will do is effectively reduce weight.
  4. #124
    4,872
    i remember seeing a calc/note by rolls royce - on a merlin engine - centrifugal supercharger . for 2000hp engine output supercharger drive was consuming 300hp
  5. #125
    4,872
    Quote Originally Posted by dynoryder View Post
    i reckon thats a great idea - drives a compressor and a secondary turbine one for power to shaft.
    sort of a twin spool turbo prop
    wright turbo compound radial engine had a 3 turbines that extracted energy out of the exhaust and via small quill shafts and some fancy hydraulic gearbox put 450 hp back into te crankshaft .
    suppossedly got te best BSFC (specific fuel consumption) of any big 50's piston engines at cruise conditions
    only problem was a mechanical night mare :
    Following the war, to better serve the civilian market, the Turbo-Compound[3] system was developed to deliver better fuel efficiency and thus economy. In these versions, three power recovery turbines (PRT) were inserted into the exhaust piping of each group of six cylinders and geared to the engine crankshaft by fluid couplings to deliver more power. The PRTs recovered about 20 percent of the exhaust energy (around 450 hp) that would have otherwise been wasted, but reduced engine reliability. The fuel burn for the PRT equipped aircraft was nearly the same as the older Pratt and Whitney R-2800, while producing more horsepower.[4] Many aircraft mechanics of the day, nicknamed them "Parts Recovery Turbines" (and worse).[
  6. #126
    Feb 2005
    TEXAS, QLD
    9,554
    Probably better off putting an electric motor straight onto the crankshaft or some shit.
  7. #127
    10,738
    Maybe you could also put an auxiliary electric motor onto the crankshaft.
  8. #128
    Registered User EnFlaMEd's Avatar
    Jan 2011
    302
    maybe you could collect rain and funnel it through a mini hydroelectric turbine which powers and h20 separator which pumps hydrogen into a small 4 stroke engine powering an electric motor that is coupled to the crankshaft.
  9. #129
    Cuntberra
    6,094
    Quote Originally Posted by EnFlaMEd View Post
    Too much conversion losses in that system.
  10. #130
    Jan 2011
    302
    Ill never be a scientist
  11. #131
    11,230
    10.83 @ 125
  12. #132
    Meh
    Jan 1970
    26,940
    Yep, it's why when the Boeing 707 with its jet engines came along the world was transformed in short order.
    No vibration, able to fly above all the weather, and most of all .... reliable. In the Good Old Days with Lockheed Constellations, etc, to go from the UK to here it'd take a few days and it wasn't uncommon to have to change an engine or two on the way.
    These days it's more common for an airline pilot to go through their career without having any engine failures.
    Bigger engine, light flywheel, the right turbo.
  13. #133
    canberra
    3,648
    thank fark
    Boring.......but sensible option
    GT8
    1UZ Celica
  14. #134
    Cuntberra
    6,094
    But like I said a jet engine works well on a plane or boat but a car needs pistons or rotors to work well. Yes there has been jet powered cars but they lack engine braking and I bet the jet engine would not be too happy changing revs so fast as a car demands leading to premature engine failure.
  15. #135
    12,894
    how about a jet powered hybrid? jet engine only used to charge batteries?
  16. #136
    Meh
    Jan 1970
    26,940
    The turbine-powered cars that Chrysler built in the 60's all had effective engine braking systems so they'd drive like normal automatic gearbox type cars. (variable blades on the engine exhaust into the drive turbine section)
    A premature failure for a modern turbine would be roughly the equivalent of doing about half a million kilometres or so with a piston engine. They're very tough and long-lived these days.
  17. #137
    Cuntberra
    6,094
    You mean similar to a jet powered ship only difference is the motors don't use batteries. It works like this jet engine>generator>motor>prop I am not 100% but I believe the jet engine runs at it's most efficient setting 99% of the time while the motors can be variable.
  18. #138
    Meh
    Jan 1970
    26,940
    Jets aren't very efficient at small sizes. Certainly not compared to something like a small diesel engine optimised to run at a specific rpm.
    The big jets, like the Rolls Royce Trents used on the Boeing 777 are pretty darn good though; they're more efficient than any internal combustion engine.
    It's the scaling effect thing with air - Like I mentioned in the 2v4v thread.
  19. #139
    11,230
    This looks like the same one that was tested in a link this thread. Results are even better than I expected with a fairly low power motor.
    http://www.wildweasel.ca/HowTo/Auto/eturboTest.aspx
    Also there is a thread on MCM. The OP came to similar power requirements as the ones I posted.
    http://forums.mightycarmods.com/show...gers-The-truth
    10.83 @ 125
  20. #140
    Cuntberra
    6,094
    It appears the blowers start to become a restriction I would like to see these on a engine that revs to 8k. This is where direct drive electric to the crank would be more efficient also a crank driven turbine would potentially work the best if say exhaust pressure was kept at a vacuum. The heat energy would still work on the turbine but if vacuum was maintained in the exhaust then the cylinders would not receive any power robbing draw back.
  21. #141
    10,738
    So maybe put a electric diaphragm pump in the exhaust to make a vacuum.
  22. #142
    Cuntberra
    6,094
    No but wonder what the effect of not only using a electric compressor but also have the other half of the turbo the turbine side pulling exhaust through the engine. It would probably just make more of a restriction but also speaking of direct to crank drive bill's previous idea of having a whole turbo driven buy a motor would be cool too.
  23. #143
    11,230
    The electric blower they made can only have a tiny motor since its powered by 2 electric leaf blower sized 12v batteries, yet it can still produce almost 3psi on a 2.4L engine at redline and close to 5psi down low. This is not a restriction, its a total success. Clearly the concept works, and with a more powerful motor boost would be much higher. It only became a restriction because they also tested it on a compound setup with the electric turbo feeding a 8psi supercharger on a 2.4L engine.
    Too bad the car they had was fitted with a supercharger rather than a turbo. That would have been an awesome combination of no lag with real turbo top end.
    10.83 @ 125
  24. #144
    11,230
    The guy is on the money. His kit only makes low boost, which means many cars will not need a tune. Low boost means power draw is low and the kit can be cheap. His product only operates on the very bottom of the compressor map. Haters have got hate, but the results speak for themselves.
    Here is the guys website with dyno proof. http://www.phantomsuperchargers.com/dyno-results.html The kits cost $1400, and gains are pretty much unbeatable for the money. Over 30% torque and 25% power for $1400. Install could be done by anyone that has enough skill to install a stereo and fit a CAI.
    10.83 @ 125
  25. #145
    11,230
    Audi has already done close to what I describe to eliminate turbo lag!
    The Audi setup is interesting. Similar to what I proposed, but they by pass it, rather than keep it running. If it is kept running it wont be a restriction provided it is sized to be able to produce boost at redline on its own. Their solution is very complicated but it does allow the electric turbo to be switched off once the real turbo spools up to save power. This maters on a diesel as they are always on boost. On a high power modified turbo car which does not see boost often, the power draw of having it running would not be a concern.
    When people think of doing turbo upgrades, one thing they always think of is lag. So they need to compromise between the top end power they want, and a decent usable rev range. If you compound it with an electric turbo, you can have the turbo you wanted for top end power, and still have less lag than your stock turbo.
    10.83 @ 125
  26. #146
    Cuntberra
    6,094
    For $1400 I may try one of these but I am building another engine so I might have trouble with money.
  27. #147
    loves the Cressy
    Jul 2005
    Gympie Australia
    2,453
    Mate has just mentioned that during WW2 the B29 Super Fortress bombers used electric powered compressors to boost the engines for take off. Similar in effect to how they use JATO units today. ie just to get them off the ground.
    Cheers, Richard
    - Long Term Jobs
  28. #148
    Meh
    Jan 1970
    26,940
    Quote Originally Posted by jzx83 View Post
    No, they didn't.
    The B-29 used the Wright R-3350 in WW2 and after WW2 they swapped to the Pratt & Whitney R-4360 Wasp Major. Neither had electric supercharged, both with mechanically driven by the engine.
  29. #149
  30. #150
    Qld
    1,371
    This electric turbo thing will never work! wait, wat?
