Results 1 to 30 of 53
Thread: 1972 Toyota Crown MS 65 2JZ-GTE Conversion
    Registered User bignatesmith's Avatar
    tweed heads
    14
    hey guys long time reader new poster, my names nathan and doing an apprenticeship as a heavy duty diesel fitter at the council in murwilumbah, ive bought a 1972 Toyota crown ms65 a few weeks ago for $500 (has minor rust, engine runs) and decided that a 2jz would look better in the engine bay, so ive bought a Toyota aristo half cut in brisbane ($3100) im trying to keep all chassis work original so if i ever want to re-sell it as a classic, will appreciate any feedback n idea's.
ID:	66711   Click image for larger version.
ID:	66712   Click image for larger version.
ID:	66713   Click image for larger version.
    tweed heads
    14
ID:	66715Click image for larger version.
    boat hand pump doesnt seem to work as good so i had to buy a walbro (planning on running 2)
ID:	66717Click image for larger version.
    1 engine out 1 to go
    11,230
    Are you going to keep the stock twins? They actually work really well.
    10.83 @ 125
    あなたの母親の肛門 Shifty's Avatar
    10,812
    In addition to the standard sump issue in older M-cars, I am almost certain the stock twins foul on the steering box - even moreso being a PS box.
    That said I'm a fan of the twins also as long as you don't have to work on them! IMO best to replace while it's all being done - which along with a sump is one of those things that makes a JZ conversion a lot more expensive than it looks.
    100% agree with Shifty
    TRD-RT81
    Guest
    if your going to drive it and own it for some time put a rack in it and never look back, otherwise put a big single on and it steering like a rubber dog turd will be someone else's problem later
    9,118
    ^ I'm with all three of these blokes.
    Also brake upgrade...
    tweed heads
    14
    yeh ive bought a supra (rear mid) sump to go in place of the front sump as it fouls on the front crossmember (the rear sump will be modified for it to fit cause the steering is in the road), and yeh the twins foul on the steering box ive come to decide on whether to go highmount straight up and put up with the shite steering or go the rack but i cannot find any info on what type of rack to use but i have heard that if you do use a rack it does come under chassis modification and its harder to get blueplated. (brakes will be upgraded if i can find a ms112 rear end although eb falcon disk fit straight on apparently but a caliper bracket has to be made.
    Was going to add more photos b4 but computer crashed so here they come =)
    tweed heads
    14
    4M Motor goneskies onto a tyre in a new tarp house
    2JZ Engine test fit
    Turbo's fouling steering box
    Sump hits front crossmember
    tweed heads
    14
    The new Supra sump $120, would have liked a true mid sump but there's better luck winning the lottery then finding one of them let alone it doesn't have a oil return
    Harmonic balancer, Turbo set-up and air-con compressor all removed
    we didn't have any suitable spirit levels so i downloaded an app that is surprisingly quite accurate and it gives x and y in degree's
    TRD-RT81
    Guest
    auto or manual?
    tweed heads
    14
    This is the Dilemma we have reached today, the engine is still to high at the front and the gearbox cannot go any higher at all.. the only options i can see working is the do what JZK25 did to his 68 and cut the rust spot out (cannot be seen in photo due to lighting) and shape the plate to "by chance" fit the harmonic balancer in with the 10mm requirement or to buy an after market racing harmonic balancer that are alot smaller in diameter and will allow me to lower the front of the engine but for around $400 i think its pretty steep but in saying that i dont want to modify the chassis "cut the rust spot out"
    This clearance is also worrying me, thinking that i should go with the uni set-up if i cant get this fitted nicely
    tweed heads
    14
    auto or manual?
    Its an Automatic mate
    ACT Now!
    27,477
    nice one!
    I'd have thought you'd go a crazy big dirty turbo diesel
    tweed heads
    14
    nice one!
    Haha If i could get my hands on the turbo diesel engines they used in robbers cars from the Fast 6 movie i would have along with the electromagnetic suspension
    ill start saving for one of them i might be able to afford it when im 80
    mmmm Pre-schoolers 60TJZ's Avatar
    Jan 2008
    885
    lol.. welcome to my world of making a 2j fit into something like this... looking good mate...
    Quote Originally Posted by psssi98 View Post
    It is also a concern that they are selling this to get a family car - meaning they have already bred.
    tweed heads
    14
    Quote Originally Posted by 60TJZ View Post
    cheers man btw ur corona looks boss
    the backwater
    10,012
    Quote Originally Posted by bignatesmith View Post
    Speak to Sean (supercrown) his first brake upgrade was off the shelf shit from falcons and holdens from memory.
    Public Service Reminder
    tweed heads
    14
    Quote Originally Posted by Cplus View Post
    will do man cheers for that ay ill jump over to his thread and have another good look at what he's done
    10,812
    i used peugeot rotors (604? can't remember offhand) and landcruiser 4pot calipers on my corona, which should be essentially the same. needs minor bit of metal taken off for clearance, but all that fit under a stock set of rt104 rims.
    ps. steering is its own mod plate (if you are in qld) but nsw i have no idea re engineering.
    TRD-RT81
    Guest
    i did this (commodore CV)
    Jun 2010
    1,542
    Hahahaha, downloaded spirit level app. Awesome!! Get an aftermarket balancer
    Jun 2005
    Sunshine Coast
    395
    Don't worry about cutting the car up. If anyone was collecting these they would have done it already. cut and shut till it fits
    get lead like a leader
    2,485
    Just be aware that if it has an AMI (australian motor industries) badge on the front quarter panels, behind the wheel arches, then it is fitted with an australian made 'banjo' diff. As it is 72 there is a good chance it is one of the australian assembled ones. The banjo diff is quite possibly the weakest differential in the known universe - axles, crownwheel, spider gears are all ultra weak.
    Any of the solid axle rear ends bolt straight up, and the jap rear ends are stronger and have discs as you already know.
    There isn't any budget lsd for the jap diffs, but the borg warner 78 from the r31 skylines is the right width, has 28 spline axles and can be stuffed with an lsd centre easily.
    Or just weld the centre up.
    Front brakes off a ms123 are 255mm ventilated - you just swap the whole stub axle over - and whilst you're at it swap the steering box and whole drag link assembly as the 123 bits will be fresher.
    Alternatively, swap over a camira or daewoo rack - they will work best with the front end geometry.
    Pedders do lowered springs for them, and adding a second sway bar to the front and one to the rear make them handle much better.
    Great project !
    Adjustable cam gears for 1FZ-FE now ready for sale - 10 degrees advance/10 degrees retard. Suitable for all variants of 1FZ-FE.
    (adjustable scissor gear for changing separation angle between the intake and exhaust cams coming soon)
    International sales welcome - PM me for pricing.
    the backwater
    10,012
    just imagine if you went down this route Seano - bit of a tidy up, a sensible, modern engine conversion and then some brake upgrades
    2,485
    Shut up.
    loves the Cressy
    Jul 2005
    Gympie Australia
    2,460
    So Sean, Camira OR Daewoo? Because same thing carried through?
    Cheers, Richard
    - Long Term Jobs
    2,485
    Yeah - effectively the same manufacturer. They have the steering arms attached in the centre of the rack which works with the stock suspension and steering geometry.
    I used a 323 rack which is a conventional unit, but am yet to drive it. It may be ok, but if not ill swap it over.
    TRD-RT81
    Guest
    calibra also has same type of rack
    tweed heads
    14
    cheers for the info ay ill have to look into that idea if it doesnt fit
    Quote Originally Posted by Supercrown View Post
    Great project !
    alot of great info, what do think ill have to change for the (r31) borg warner diff to fit because that sounds like the way to go?
    2,485
    It's not a bolt in or anything, but it's not that difficult.
    You need to swap the crown lower control arm mounts onto the bw - just make a basic jig.
    The crown only has a single upper link, and it is nearly over the centre of the diff. As the bw has a cast centre housing you can't easily weld the crown mount on there.
    Make up two new upper links and weld New mounts to the diff housing and chassis. ( I have the adjustable upper links left over from mine you can have for $50 if you want)
    You'll then need a custom tailshaft too obviously.
    You can leave the axles as 4 stud, or change them to 5 stud to match the front.
