Page 1 of 6 12345 ... LastLast
Results 1 to 30 of 179
Thread: 2003 Elise to honda conversion
    Aug 2011
    247
    Lotus Elise to honda conversion
    Well i think its about time i finally got this thing up on the forum. Been working on it for a while now and had a bunch of set backs but slowly getting there. Not sure if it really belongs on this site, but I need motivation to keep things rolling.
    Wanted a car which was pretty direct to its purpose, I came from an evo 8 because i just always enjoyed the RWD and mid engine style of driving (previous to the evo I had an SW20 turbo mr2). Basic purpose of the car is weekend drives and track days, or so i plan.
    As is, it came with 14k kms and a fairly worked engine (for 1.8l rover lol). To my knowledge and experience so far;
    -Rover 1.8 rebuilt
    -Ported head
    -Forged pistons
    -piper cams (285 i think)
    -ITG carbon fibre intake which is loud
    -Janspeed exhaust
    -Motec M800
    -MOCAL laminova oil/water cooler
    Has a lot more punch than the few other rover elises ive driven. Engine is almost as all out as a rover can go.
    Going to forge the engine with moderate comp so its good NA for a bit until i get good enough and driving and go to a rotrex.
    -Weisco pistons and Manley rods
    -Upgrade the valvetrain (springs/keepers/guides etc) and it will be pretty solid
    -Wavetrac LSD but leave the rest of the box stock
    -TTS engine mounts and shifter setup using the later model TOYOTA shifter system which is apparently heaps better than the junk rover gear.
    Got the K20a2 head off and ready to disassemble for the new valvetrain parts.
    K24 block ready to strip and get some machine work done.
    Aug 2011
    247
    RBC inlet manifold and ARP head studs:
    IMG_1483
    RDX injectors:
    IMG_1487
    K-Tuned fuel rail and a few fittings
    IMG_1485
    New carbon fibre gloss finish air ducts
    IMG_1479
    Aug 2011
    247
    More bits and pieces, ready to bore the block now and fit the new guides:
    IMG_1530
    IMG_1531
    IMG_1536
    IMG_1537
    Aug 2011
    247
    Progress is basically just parts atm:
    IMG_5291
    IMG_5296
    Aug 2011
    247
    Aug 2011
    247
    Removed the subframe for best access
    Engine out, pretty straight forward. Not much in the way really.
    Registered User Justengt4's Avatar
    canberra
    3,515
    Subscribed. Will do something similar myself one day to tick this off the bucket list
    GT8
    1UZ Celica
    1.07 flat Wakefield Park
    Aug 2011
    247
    Stock bilsteins are pretty clean and can stay for now, but i hear theyre very sub-par
    Im using an arduino to convert the water temperature signal to a signal the stock dash can accept (it displays temp in a digital readout which is cool), and also to convert the speed signal for the dash. Figured when I was bored one night id write up some code to display some oil temp/pressure and fuel pressure signals too which would be neat. Need somewhere to mount the LCD tho (its backlit the same colour as the dash orange).
    Aug 2011
    247
    This is the stock shifter base, ill get a pic of the toyota one sometime soon, key difference actually is the actuation design but i dont have the shifter in this picture. This one uses below pivot point mountings, the toyota one is made by teleflex-morse and uses a completely different setup:
    Rover:
    Toyota (not mine, but the design is the same):
    Aug 2011
    247
    Then the problems started....
    Basically if you can see in this picture (pretty easy to see) the block surfacing was horrible. The idiot that did the deck job either ran the feed speed too high or had a fuckin shit bit on his machine. I super pissed when this happened, and couldnt get my money back or anything for it either. Lucky I found a pretty decent guy who fixed it up for $50, just took on another thou to make it true.
    Ill leave things here for now, I have a lot more work completed so far but ill put it up slowly cause im a lazy dickhead and looking at this picture of the block pisses me off.
    Registered User 50RTD's Avatar
    Aug 2010
    Queenland
    2,546
    Un fucking real.
    What a machine this will be!
    Registered User Banzai's Avatar
    Jul 2002
    1,359
    Did a Honda conversion on my Elise exactly 5 years ago and haven't regretted a minute of it. I used a brand new K20A from a late JDM Civic Type-R. Good factory LSD but the 5.1:1 gearing can be a bit much on the freeway. First gear is a bit useless but it gets off the line like a scalded cat though.
    The factory Bilsteins are shit and Lotus seems to expect everyone to change them sooner or later. In the first 5 years of ownership (100,000km) I had 2 of them leak. Go for Nitrons or Quantums. I went with the latter.
    Can't the Motec do the temp and speed conversions for the stock dash?
    BTW, that isn't a 2003 model. More like a 2001 model with that long tail soft top.
    If you dig a hole and it is in the wrong place, digging it deeper isn't going to help.
    Police warn that blow-up dolls are not recognised floatation devices.
    Aug 2011
    247
    Its first registered 2003. The last rover was 2004 i think which they went to short roofs but still the rover engine. 2001-2002/3 still had long tails. I sold the motec (which of course can do said conversions) and went with the hondata for now because I got a good deal, but also because the M1 series was coming out soon. M1 series seems much better value than the M800 and I would have had to spend a few hundred just so I could get the M800 running the k series engine (cam phasing, logging, add traction control for kicks?).
    Anyway, hondata is a piece of crap but with such a simple engine for now its a good option i think.
    Going to get some quantums possible, guy from the lotus community has a set of them available with very low kms. But focus currently is the get the damn thing running.
    This box as the 4.7 final drive, still too high i think. Would prefer the 4.3 honestly, but I cant exactly speak from experience
    Jul 2002
    1,359
    With the 2.4 block you will have plenty of torque for an 800 kg Elise. You could get away with a 4.1 diff from an Accord.
    Last Rover cars were 2005. Mine is a mid-2004 build but co-incided with the first of the Toyota-powered cars.
    For ECU I run the DC5-specific version of the Haltech Platinum Pro. Haltech also makes an engine loom to suit. Ran the standard dash just fine without having to keep the factory ECU. I now have a Haltech Data-Logging Dash so no need for OBD anymore. Only complaint with the dash is the ODO only has 5 figures.
    Trust me, the MY2003 cars had short tails softtops. Pretty sure the MY2002 cars did too. The cars came in as low volume imports and it wasn't unusual for some of them to sit in the showroom for a couple of years. You should have a compliance plate riveted under the front passenger side inspection cover near the fusebox.
    Make sure those Quantums are for a Rover car. Toyota cars have longer rear shocks. Spring rates should be up around 450 to 500lb front and 550lb rear. The track only cars use more like 650f/700r.
    Also a heavier front sway bar and better/stronger rear toe-links. The originals have a well deserved reputation for breaking when you start using R-comp tyres.
    Aug 2011
    247
    yeh the quantums are from a rover. Im not really fussed what year mine is i guess lol, if you have a spare parts for a short tail conversion let me know, wouldnt mind a hardtop and the long tail hard tops are hard to find.
    I have an SSC rear toe link brace which i picked up for the reasons you just mentioned.
    Ill definitely look into the haltech later on, did you end up having your car engineered? I think i can get away with the hondata for engineering, already been discussing it with sanjay (VACC engineer) and just kept a bit of it hush hush about the engine insides. As long as the charcoal canister is hooked up and everything is externally stock on the engine etc. Cat is similar distance from the exhaust ports as well in my exhaust.
    Jul 2002
    1,359
    Got mine fully engineered including emissions certified. The tuner (Hitman) had to lock the ECU for that but it has since been unlocked. It runs great so I have no desire to screw with the tune.
    Aug 2011
    247
    ill do my best to convince the engineer that it doesnt need an emissions certification because of the "stock engine setup etc" but see what happens. He already agreed to the rest of the car. What did you engineer say about the mounts you used? Most mounts you have to drill a few holes in the rear and subframe and the ally crossmember on the other side of the engine (for each of the torque mounts). I actually reinforced mine with some chromoly plates on the rear subframe because i dont like it much but I guess TTS are running 600hp with no issues at all with that.
    Are you using the link up style mounts?
    1,140
    Always loved the little Elise and exige. Will watch with interest as I always wrote off the rover engined cars as not worth looking at. With an engine conversion that could make a cheap good package.
    Aug 2011
    247
    thanks mate,
    i got the car for low 30s with shipping from perth. rover engine is guttless but they are light and make the car pretty fun still. Ive been in a honda car and its a different world, the engine suits the car so well.
    Registered User spiller's Avatar
    3,228
    Subscribed and good luck with it, will be an animal when it's done and obviously saving a mint in doing it yourself (not to mention the added personal reward).
    Registered User Gats's Avatar
    7,101
    One of these will be my next car.
    Did you drive it much with the modified river motor? Or rip it out straight away?
    Aug 2011
    247
    drove it for a year with the rover engine. Good fun still but really lacks punch. Engine started to eat coolant too which is pretty common. Basically i couldnt wait to get the rover out still haha.
    These are the mounts im using:
    Registered User fantapants's Avatar
    Apr 2009
    Devonport, Tasmania Australia
    2,168
    Holy shit I love this.....
    06/07/2011
    Jul 2002
    1,359
    Quote Originally Posted by nuk1ear View Post
    Mine is a link-up conversion. Straight forward, I don't remember any drilling and the extractors are a work of art.
    The extra height of the K24 block might give you grief if you are using off-the-shelf extractors.
    Get the best quality grease you can for the tripods. A few have overheated, spat out grease and failed.
    I liked the basic performance of the original Rover with minor mods, it suited the car well and sounded pretty good. The K20 is the Rover on steroids and sounds fantastic when VTEC kicks in.
    Married but celibate toddy's Avatar
    In the bushes
    239
    This car makes me turgid.
    Love the simplicity of the cabin and the driveway workshop.
    Mook
    Registered User lonewolf's Avatar
    Mar 2005
    perth
    3,564
    sweet, k20's are good for easy reliable n/a power.
    Should be able to offload the old rover to another elise owner if not too badly flogged?
    Team Chapman Racing TCR's Avatar
    2,474
    Great project, definitely keep us posted.
    I'll be putting the Cossie up for sale in the new year with the proceeds going towards an S2 Elise.
    2015 Skoda Octavia RS162TSI
    2004 MX5 SE Turbo
    2016 Toyota 86 GTS (No Pics)
    Aug 2011
    247
    Quote Originally Posted by toddy View Post
    yup, offloaded to a mechanic friend for a MGF customer of his.
    Aug 2011
    247
    Rebuilt the laminova cooler. Decided to keep it since theyre pretty decent and have been proven to be fairly good on the k20 engines in lotus/mid engine setups. It had -8 oil lines but i wanted to use -10 so got a rebuild kit and -10 ports:
    Some debris remaining in the core on the oil parthway
    After a good clean up with solvent
    New seals/orings/gaskets/bolts and -10 oil lines isntead of the -8 the rover had with it.
    TJzone TJ's Avatar
    Mar 2003
    24,630
    Should make for a good fun toy
    #teamtremolo
    Quote Originally Posted by brasher
    Quote Originally Posted by Fatboy View Post
    And i'd still fuck Betty....
