Results 1 to 30 of 38
Thread: solid state relays
    Registered User caged's Avatar
    Jan 2011
    christchurch/sunshinecoast
    283
    solid state relays
    Im going to set up fuel pump running off a solid state relay and pwm controlled by the ecu. I cant seem to find the haltech ones any more and iv been looking at the jaycar 100amp. Is there any problems running a 25amp fuel pump on the 100amp solid state relay with a big heat sink?
    http://m.jaycar.com.au/m_productView.asp?ID=SY4086
    97 Express van 4G63 compound Turbo Tdo5/HX40 @ 34.7234psi.
    Gone--
    93 GSR 1.8L 406whp 11.6@126mph
    Brisbane, North side
    1,775
    25amp? Are you sure it is not 25watt?
    25amp is fine on a 100amp relay. Those relays are not intended for automotive use. Dont know if that will be an issue. Also that one is very expensive. Put something like dc ssr into ebay. Should be around $10 with heat sink
    Sep 2007
    5,362
    I used this exact relay to drive an 044 and a Walbro, just mounted to an interior metal panel with a bit of heatsink paste in between, works great
    3x1UZ+1x2UR...
    Maximus Pontus Imperator EfiOz's Avatar
    Jul 2006
    Melbourne, Australia
    1,105
    I've used these in jet boats before. If they can deal with that shit they can deal with anything.
    Competition Systems
    Winning Edge Electronics
    Magneti Marelli, Jenvey Induction, Souriau Autosport, BF1 Systems, Cat Cams, ORECA, Variohm and Texense Sensors
    www.compsystems.com.au
    Jan 2011
    283
    Im not paying for it and need it tomorrow so it wont get a ching chong one this time. Sweet ill run the 100amp one.
    Quote Originally Posted by perthdrivers.txt View Post
    Nice. What frequency Hz are you running it at? How have you wired it up? Still got a normal relay switched off ign for the power feed to the pump and ssr? Cheers mate.
    Gone--
    Sunshine Coast, Qld.
    7,749
    There is a fair bit of info including wiring setup in this thread. http://performanceforums.com/forums/...r+pump+control
    Next time I do one I will use a Subaru fuel pump controller for water pump or fuel pump. They are cheap and easily controlled and come with proper automotive connector.
    Jan 2011
    283
    Cheers Al just what I was after. How much current can those subi ones take? I remember changing a couple of dead ones from GD8's that had o44's. Could of just been a coincident.
    Gone--
    Sep 2007
    5,362
    Quote Originally Posted by caged View Post
    I forget how I wired it up but i think it is powered by the Adaptronic fuel pump output (so the usual safety cutouts) and a adustable PWM output is the signal to modulate the pump speed. At idle you can have the pump running at like 20-30% duty cycle, *much* quieter and youre not needlessly cycling loads of fuel around. I also have another SS relay to run the water/meth injection pump
    3x1UZ+1x2UR...
    7,749
    Never had a problem with a subaru pump controller. The wiring in them is huge though, probable 5mm2. 044's only draw 14A too(advertised in Bosch catalogue).
    You can use the DI function on the controller to return to a Link/Vipec too so the pump duty is displayed in the software. Jaycar SSr's don't have this.
    TRD-RT81
    Guest
    Hella also do a solid state relay that fits a normal relay base and has a MUCH better switching time than the jaycar ones
    7,749
    Part number?
    TRD-RT81
    Guest
    18,143
    30a only tho.. You will melt that with a good fan or fuel pump..
    7,749
    Probs OK for an EWP though yeah?
    18,143
    Probably.. Next time I fire up my smart wire ill tell you how much exactly a dedenbear pulls
    7,749
    Baller.
    Jul 2009
    Inner Westside/Sydney
    1,332
    Just checked the datasheet for the SY-4086 from another supplier as the jaycar datasheet link is buggered.
    Switching time for turn on 1ms, off 0.5ms, that is SFA for driving pumps, even secondary/ auxiliary injectors isn't too much of a drama.
    Think I'll be buying one of these and the matching heat sink for my water pump at least, maybe fuel pump as well.
    TRD-RT81
    Guest
    they are rated to 80a on startup, I use one to run a pair of AU falcon thermo fans without any soft start, no issues at all 12 months on and the relay is cold to touch with the fans running.
    TRD-RT81
    Guest
    in practice they are shit for any kind of fine pump control!
    7,749
    I have used them a few times on ewp's and they work fine.
    18,143
    yeh because you need fine control for water pump or fuel pump..
    TRD-RT81
    Guest
    ahh yes for water injection or if your doing fuel pressure control with a motec.
    18,143
    Ok..
    Funny how 1400hp rotarys can run perfectly fine off a m800 or ps2000 and a jaycar solid state controlling 12 of its injectors.. If there were that slow there would be apex seals everywhere...
    Perth Cunt
    3,570
    Ok..
    ... If they were that slow there would be apex seals everywhere...
    They're not?
    Sent from my e1108_v73_jbaol1g18flash8p4 using Tapatalk 2
    Originally Posted by Stang:
    TRD-RT81
    Guest
    Ok..
    and how many of these 12 injectors running off the solid state relays operate at idle? where I'm sure a 1400hp rotary required fine injector control...
    test it for yourself... log the relay output with an ecu and compare it with the ecu output....
    6,547
    Fine control my knob. I have used the SY-4086 on lots of cars and a meth injection.
    The system had 3 nozzles, pressure sensor [b]AND PID PRESSURE CONTROL[b]. The pressure was converted to flow rates for each nozzle and then to perfectly calculate the fuel to water ratio.
    They control just fine!
    Jan 2011
    283
    I ended up using the 100amp jaycar ssr, rookie question but what is the correct way to choose what frequency to run it at? Iv got it set at 100HZ at the moment and it runs great off a 2d table of rpm vs boost on the vipec.
    Gone--
    6,547
    100hz seems fine, given the figures thrown around for its poor switching.
    18,143
    Yep 100hz is fine, remember that they are shit and switch too slow to be useful tho
    australia
    1,401
    So what relay would be the go to run 2 aeromotive stealth 340s or should I run 2 separate relays.
    Looking at running a pwm signal from my haltech
