Page 2 of 2 FirstFirst 12
Results 31 to 38 of 38
Thread: solid state relays
    18,168
    1 jaycar would work fine..
    Jul 2007
    Blackwater, QLD
    1,667
    Ok..
    jaycar solid state controlling 12 of its injectors.
    could you elaborate on this? what's involved in wiring auxillary injectors to an ssr? is it give it switched 12v+ then hook it to an injector ground? how do low impedance injectors go without peak and hold control?
    18,168
    works fine, use a generic output, pluse the solenoid, enjoy driving 20 injectors off a single output.
    Jul 2007
    Blackwater, QLD
    1,667
    what about some ghetto extra injectors? just hook it up to the standard injector wiring?
    gold coast
    1,849
    wired in parallel, most ecus should be able to drive 2 injectors.
    depends on the current limit of the driver. peak hold or saturated etc.
    1/inj1 ohms + 1/inj2 ohms = 1/total ohms
    Oo___oO
    Jul 2007
    Blackwater, QLD
    1,667
    it's an aussie r31. they came with low inpedance injectors stock, so peak & hold i reckon. the extra injectors aren't always required, so would switching the power via a hobbs switch, and switching the relay via the standard injector ground work?
    gold coast
    1,849
    I reckon it would, yes.
    but if the hobbs switch fails you're in a bit of trouble so make sure its done properly.
    need to be a bit careful as you won't necessarily get the full pulse of the second injector if the hobs closes 1/2way through an injection event so you'll need it to come in a bit before you need, rather than exactly when you need it. your peak/hold driver may have a bit of a spaz too when you double the eletrical load on it mid pulse.
    Oo___oO
    Jul 2007
    Blackwater, QLD
    1,667
    ok. thanks. hopefully just switching the relay won't fuck shit up too much, injector driver wise?
