Results 1 to 7 of 7
Thread: 2009 Husabeg FE450
    Registered User Gats's Avatar
    7,488
    2009 Husabeg FE450
    MY2009 Husaberg FE450
    48.5 hrs
    1585 km
    Fitted with the following:
    Dirt tricks cam chain tensioner
    Force radiator guards
    Force aluminium bash plate
    Radiator thermo fan
    Carbon fibre exhaust heat shield
    MPE suspension- slightly lowered
    Barkbusters
    Frame guards
    LED tailights
    Bad points:
    Slight weep from front sprocket seal
    Plastics are marked from use
    Needs resistor to get LED indicators to flash correctly
    This has been rarely ridden in the last couple of years. Only 4-5 times a year unfortunately. However due to the EFI, it fires up perfectly every time, even after months of no use. This has been perfectly reliable, would never own a carby bike again.
    Currently registered, have all the gear like rear guard and mirrors to make it all legal. Also includes a second sproket and chain for road gearing. Can sort out RWC for QLD buyer.
    $5200 for a non dickhead buyer.
ID:	72095   Click image for larger version.
ID:	72096   Click image for larger version.
ID:	72097   Click image for larger version.
    7,488
    So 4 years later this is still taking up shed space.
    It has had a little use, up to 1970km and 55 hours now.
    Still registered, have fixed the led flasher, but still weeps oil. Will need a new air filter.
    Starts great, run regularly. Will be selling without rego unless the buyer wants to make arrangements.
    $3200
    Registered User CA18escort's Avatar
    Back in the nation's capital
    1,391
    Very neat looking bike. If this was in Canberra I would be all over this.
    Registered User piss98's Avatar
    PF Brisbane Cuntarm
    17,610
    Weeping oil = counter shaft seal = cheap and easy fix.
    whaddayatalkinabeet brasher's Avatar
    Feb 2006
    4,894
    Very tempting. Dad has the 570 version and itís been fantastic.
    7,488
    Took a deposit on it this morning. Will update if it falls through.
    Canberra Nth
    3,227
    Super cool bike.
    Some cunt buy my crf so I can go and undercut old mate lol
    BF XR6 Turbo - 2L Turbo TE - 75 TX Coupe - Atlas SS
    - PSN: rotacoupe
