Page 29 of 32 FirstFirst ... 192526272829303132 LastLast
Results 841 to 870 of 937
Thread: Holden Ute
  1. #841
    Defective Faux Forg's Avatar
    Sydney Traffic
    1,765
  2. #842
    5,197
    Send tk money for built engine. Fit stocker and fix all other car related fuckups while you wait.
    Or, put a chev in it cunt
  3. #843
    Nay sayer Mr Ed's Avatar
    15,093
    Quote Originally Posted by limehj View Post
    Send tk money for built long weight.
    Fixed for reality
  4. #844
    7,255
    No engine is Nicol proof.
    "1uz is bullter proof" - The internet
    2 Nicols, 2 broken 1uz's.
  5. #845
    12,751
    The exceptions that prove the rule
  6. #846
    Feb 2005
    TEXAS, QLD
    9,636
    Technically Dale blew mine up, but we were drinking and it was fun at the time.
    Then I bashed it together in 2 hours in the garden shed at 1am and it lasted 20 minutes at powerplay before doing the same thing.
    All mine needs is put old 1uz in industrial bin, bolt in another 1uz (already sitting on the bench beside it) and press pgdn on dale's tune and it will run for years.
  7. #847
    Aug 2014
    New Zealand
    660
    I do not condone experimental tuning on my $20k of V12.
    So low boost it will be for me until things are run in and look stable.
    Do it all again cracka, do it all again because you can. slap another motor in and either be kind to it or build one fit for the task.
  8. #848
    Meh
    Jan 1970
    26,940
    How about you just ask Justen, CelicaV8 bloke, as he knows very accurately as to what they can and can't take. No need to guess, ask an expert.
  9. #849
    7,255
    or the fella with the capri
  10. #850
    Jun 2010
    1,542
    Built motors will always last longer than a junkyard motor. Putting a turbo on a junkyard motor is awesome! Just don't be greedy with power. I don't see logic in putting 3k ecu, 3k turbo etc on a 500 dollar engine.
  11. #851
    Feb 2005
    TEXAS, QLD
    9,636
    you can, you just have to be prepared to swap out $500 motors until you find the good one.
  12. #852
    Jun 2010
    1,542
    BTW stick with it cracka. Like I said early in this thread. Make a plan and stick to it. And have realistic goals. It's a cool ute
  13. #853
    Jun 2010
    1,542
    I'm too lazy to swap motors out all the time haha. Build it, then just fill with fuel and turn the key.....
  14. #854
    Wrong.
    7,157
    What makes people think the tune is wrong? It's conservative as shit to be honest, and was wound right down even still because exhaust valve springs. Made identical power on 13psi as it did with 19. It isn't rocket science, very basic agricultural engine.
  15. #855
    Maudsland, Gold Coast
    6,583
    It was that conservative it still pushed the head gaskets out.
  16. #856
    Wrong.
    7,157
    It's like putting 12 psi in a stock ls1 sure it will last for a while but it will fuck up sooner or later
    100% it wore out exhaust valve springs first, then played silly buggers with head gasket. Block looked fuckin mint so I figured rebuild heads, tidy block surface up, slap together with big valve springs etc, keep it turned down and it would be right.
    lesson learnt. When I can afford I'll do it better/right. In the meantime sell the excess shit and start again. The fact it's such a fucking cunt to work on with the current manifold/turbo setup just means every job takes 10hrs more than it should. it breaks my spirits spending 4 hours to undo two turbo bolts. Or removing entire brake and suspension on one side to pull a head. If it were reasonably accessible like on a chev block it would be a joke.
    i like the 1uz, bulletproof truck motor if the right bits are in the right spot. I just can't afford to have someone change those bits for me and I can't weld for shit to do it myself.
  17. #857
    Dreamer millsi's Avatar
    Jul 2006
    Logan Bogan
    3,122
    Dude I feel your frustrations, my shit box requires the engine to come out to remove the heads, let alone the Dick around of removing the manifolds.
    It's been sitting under the house undriven and gathering dust for 18 months. Whilst it wouldn't take much to get back on the road I just don't have the time or money to sort it.
    One day I dream of being a cheque book racer!
  18. #858
    2,498
    Mine also has been shed bound for coming on a year now because my built motor lasted 3000km. Going for a stock bottom end with studs and mls gaskets, and I'll cry if it can only hold 14psi!
  19. #859
    Jul 2006
    Logan Bogan
    3,122
    wrong thread derrr
    Nope
  20. #860
    Registered User bloodbath's Avatar
    Hell
    58
    Quote Originally Posted by SR20 KE30 View Post
    Wait wat.
    Twin turbo will only add complexity not take it away.
    Elite is only better than ps2000 if you have need of its additional functions.
    Any and all wiring issues could be fixed with one day spent under the dash.
    Bhg just needs a head skim and some studs and that will be the last you see of it.
    Dont overthink it, just fix it.
    straight up!!! too many people over complicate shit with stuff they dont need! no need to reinvent the wheel! even larry larson said that...! frying tyres and blasting away other cars ... you forget about the shit you dont need real quick!!!
  21. #861
    1,250
    2j the living shit out of it.
  22. #862
    Jul 2006
    Logan Bogan
    3,122
    Is the ps2000 for sale yet?
  23. #863
    7,255
    yep. $9K.
    comes with free turbo ute
  24. #864
    Wrong.
    7,157
    ^ what he said.
    I reckon I could make 10k parting it out and sell sell a perfect functioning near spotless ute for 8-10k after throwing a 308/traumatic/10 bolt/stock brakes/suspension in. Or engine rebuild with all the current kit.
    Interestingly I have a good look at some of GoMac's 1uzs I could find online. Every single one of them has the rear water bridge blocked and a single line forward, some with a temp sender there. Mine has a giant fucking loop of heater hose. Could be cause of some mad air lock in that area (which happens to be the cylinder injesting water now. Has always been a complete fucking cunt to burp air out and never once has it not had air still in there somewhere.
  25. #865
    Albuquerque
    529
    I'm not having a dig here or trying to be a smart ass .. what exactly is now wrong with it? just going by what you've posted up, it seems like you do actually enjoy it at times but then as a result of problems, you get put off? then want to sell? While nowhere the amount of work you've put in to yours, it's still a thought I get about certain past cars where I'm like, hmm I should've kept it >.< .. but yeah if that thought is genuinely not there any more and it's causing only grief, then you gotta do what you gotta do. GL
  26. #866
    7,255
    reality is that it has done a head gasket on one head.
    and this is the 2nd time it's done it.
    another reality is that a replacement motor is pretty much $500 at full price.
    What it needs is a weekend, 2 engine stands, 1 engine crane, some beer, some bbq, some tools and some friends.
  27. #867
    Aug 2014
    New Zealand
    660
    ^this plus some kindly soul to help correct the terrible turbo manifolds so old mate can keep his toys in the cot when he is working on it.
  28. #868
    ACT Now!
    27,470
    Quote Originally Posted by JZX V12 View Post
  29. #869
    8,333
    Im still trying to get my head around 70k going into this?
  30. #870
    18,321
    Ls1 do the same thing when you block the coolant passage.. Creates hot spots and causes the same problems your having
