Page 4 of 43 FirstFirst 1234567814 ... LastLast
Results 91 to 120 of 1275
Thread: Open Wheeler Toy
    Registered User Brad88's Avatar
    Oct 2008
    348
    nice work, smashing it through it.
    '93 6SPD T04Z 1UZ JZA80 Supra
    '93 Auto T04Z JZA80 Supra
    Venom Automotive - Billet Components to suit a variety of Automotive Applications including JZ, UZ & RB Engines.
    Aug 2013
    gawler
    1,909
    I managed to get further with the exhaust tonight, I couldn't find a 2" Vband clamp so used a 1 1/2" plumbing joint instead ! It is a little smaller in inside diameter but I don't expect it will be an issue. I still need to graft the 2 oxygen sensors onto the exhaust somewhere.
    Brake plumbing on the LHR, I didn't feel like shelling out $30 per side for new hoses, so I scrounged around and used the rear hoses from the Echo and a pair of rear hoses from a derelict Magna lying about the place, joined with a short steel section.
    The top radiator hose and coolant pipe are also visible, I've just got one more join to do before that is complete. Getting closer
    Aug 2013
    gawler
    1,909
    I managed to fit the 2 oxygen sensors this evening and then made the first driveshaft. The driveshaft angles are suboptimal but it is the trade off for putting the gearbox as low as I can ?
    I'd like to get a clear day to have a good run at getting it going, but I've got bills to pay and plenty of work needing done at the moment so I can only get to it in what little spare time I find.
    16,437
    If in the original installation there's a cataclysmic converter between the oxy sensors you might find it throws a code and goes into limp mode without the cat there...
    Aug 2013
    gawler
    1,909
    Ah, an astute observation Gammaboy, but one that I had already canvased with 'my man', for he knows infinitely more than I.
    He expected it may effect the way the ECU goes into a closed loop mode, but little else. There was even thought of deleting the rear one altogether.....
    On my mothers Echo I've knocked a hole through the Cat. and it doesn't seem to have effected anything at all...
    So, not anticipating any issues.
    Aug 2013
    gawler
    1,909
    I got a bit done today before the weather got disgustingly hot and I gave up.
    finished plumbing the brakes and clutch, bled them up, using a broomstick to operate the pedal for the rears and clutch !
    Tidied up the last little earth strap in the wiring and jury rigged an accelerator cable.
    Finished the plumbing for the radiator and filled that.
    I'm actually waiting on 'my man' to finish with the selector end of the g/box and for me to get onto the lathe and create the last driveshaft and then it should be driveable.
    The weather is predicted to be hot, so it will probably be Monday evening till I do anything.
    Getting keen to give it a squirt up the driveway....
    Aug 2013
    gawler
    1,909
    IT LIVES !
    I got the driveshaft sorted, and my man came good with the back of the gearbox early in the evening, just enough time to get it together drop some oil in the box and give it a squirt up the driveway !
    Not perfect, but, very much fun...
    Registered User GTAM's Avatar
    Feb 2006
    Garden of Eden/ aka Hell
    1,584
    Good work! I bet even with a quick squirt up your driveway you can feel the power to weight advantage!
    9,051
    So good Roy, can't wait for vids
    irgendwo
    4,583
    fuck me youre motoring along with this
    makes my little side project look like absolutely utterly not happening!
    Mit freundlichen Gre
    Aug 2013
    gawler
    1,909
    Having not stepped inside the shed, for what seems like an eternity, I finally found a few minutes to do something.
    So much to do, so little funds ! I'd had the alloy for the side panels cut "to size" so I clamped it to a piece of 4" steel tube and wrestled a 90 degree curve along a long edge ( bottom edge) turned out lovely. I just need to trim it to fit neater and sort out mounting it. Sadly I ran out of steam at that point, and determined that I needed some stainless self tappers before I could continue.....
    I did also contemplate the ignition/ starter switch....that also came to little....
    Aug 2013
    gawler
    1,909
    So that is what it looks like with the alloy sides, a little slab sided but considering the tiny amount of work that went into them I'm quite pleased.
    Self tappers, I hate them. So I decided I would just go with rivets ( I don't like them much either ).
    I think once painted and with a white roundel and a number they will look just fine. I suspect the nose cone will be improved with the pink stripe ! and again a roundel and number.
    Aug 2013
    gawler
    1,909
    Great, I managed to find a little time to get down to the shed and do a little.
    I trimmed the alloy sides to size.
    Made a 'key' to operate the original Toyota ignition switch (which has been removed from behind the heavy barrel and column lock assembly) and fitted that to the dash.
    I made a little joining piece to join the Magna throttle cable from the pedal to the Echo throttle cable on the engine.
    I then started on the firewall/seat back which of course ties onto the alloy side, having done that I was a little concerned that the throttle cable could be snagged on harness or overalls so I made a little panel to guard that. Which may also form the side of the seat in a fashion. I got one side ready to be riveted together and decided it was hot enough to call it a day for today.
    Pleased with progress and looking forward to using it in anger.
    Aug 2013
    gawler
    1,909
    Nothing more done, just a couple of photos of where I'm up to.
    Progress is slow at the moment, I've plenty of paying work to be getting on with and that is being slowed down by a lack of a work truck at the moment. Still, nothing to do but keep on keeping on.....
    Aug 2013
    gawler
    1,909
    Way back at post 57 I alluded to 'evil plans afoot'
    In a couple of weeks I'm expecting to take delivery of a Mazda K8 engine.
    That is the worlds smallest capacity production V6. In standard configuration they are limited to 7500rpm but a look at the construction and materials suggests that at least another 1500 rpm should not bother the integrity of the unit.
    You can see where I'm going here, I will probably shy away from messing with the 4 cams if I can avoid it, and just add a couple of turbos to try to keep it breathing to the higher limit. hope.
    I'm sure a later model Subaru box will cope with the resultant, not rampant hp.
    Registered User Bren's Avatar
    Lockyer Valley, Qld
    2,376
    This would be awesome with a little V6!
    Aug 2013
    gawler
    1,909
    Yeh I thought that also, even if it adds a few Kg the Kw will compensate more than enough !
    Should be able to double the Hp/ kg of this car, 400hp per tonne ?
    Lockyer Valley, Qld
    2,376
    That would certainly get it moving
    Aug 2013
    gawler
    1,909
    Still slow/no progress.
    I've procured another truck for work, so it is priority at the moment, getting all of my tools and equipment stowed onboard.
    Meanwhile I've also acquired a hydraulic handbrake, so I'll need to mount and plumb that before I go to much further.
    My Mazda K8, will not be delivered as soon as hoped, but that is of no consequence at this point in time.
    Patience is a virtue, apparently ?
    Aug 2013
    gawler
    1,909
    Finally took some time today to do a few things to the little racer, actually disinterred it from the debris and leaf litter that was threatening to envelope it. Adjusted some things that I wasn't happy with in the front end and gave it a rough wheel alignment, then fitted up the hydraulic handbrake. I'm not sure if I'll retain that, the lever gets in the way when entering or exiting the vehicle. I'll probably wait till I've finalised the battery before making a decision.
    I dropped a battery into the Porsche and kicked it in the guts, after pressure cleaning a heap of dust, crud and clearcoat off, I took it down to the servo and put some fuel in it, on the way back up the hill I opened the taps and let it go. I don't know why, but, it was more lively than usual, hit a double tonne going uphill!
    I had been toying with the idea of replacing it with a 6 series BMW, but it can stay a while longer.....
    Aug 2013
    gawler
    1,909
    I was feeling a little uncertain about progress, so I asked a CAMS scrutineer to come and have a look at what I'd done. He is pleased with progress. So expect to see things move along again soon.
    A sense of relief and vindication, onward and upward.....
    Aug 2013
    gawler
    1,909
    Still slow progress, I've bought 2 Peugeot 306 Diesels in the last few weeks, put the "finishing" touches to my work truck, started cutting the firewood for winter and the racecar I'd given away has found it's way back to me, while the owner is in hospital.....?
    Still, I did manage to get the roll hoop bent up and welded onto the car, I need now to purchase a harness and get that fitted, I've ordered springs for the front end, but still need to organise a seat of sorts....Click image for larger version.
    Aug 2013
    gawler
    1,909
    Oh! and the driveshafts are failing so I'll be needing to sort that out to.
    Malakia Industries
    Κάλυμνος
    2,293
    The CV angle looks pretty big and would only get worse with a driver in it. Could you lift the back of the box or something?
    Aug 2013
    gawler
    1,909
    Yes, driveshaft angles are suboptimal, there was a showdown between Centre Of Gravity and Driveshaft Angle. Driveshaft angle lost. Ultimately I'd turn the gearbox upside down, dry sump the engine and sit everything lower but alas budget says No No No....
    The driveshaft failure is due to MIG welding the shafts together, it will hopefully be sorted by TIG welding, failing that, it will be custom billet shafts. budget says Oh No...
    Aug 2013
    gawler
    1,909
    Woo Hoo...... I picked up the springs for the front end and installed them, that brought me to checking the wheel weights, once I'd got them equalled up I popped the scales under the rear wheels. They came up equal straight up, scary!
    But having done that I had some accumulative weights, and they weren't very big, 130 kg on the front axle and 220 on the rear ! That's a total of 350 kg and with me in it will bring it to 425kg. That is the weight I was hoping to hit without me.
    To say I'm stoked is an understatement.......
    Aug 2013
    gawler
    1,909
    Yay I got to drive the car today, what a difference a lack of weight makes to the way the mundane, standard 1.5 litre Echo engine reacts, wonderfully tractable and potent !
    Feb 2006
    1,584
    Aug 2013
    gawler
    1,909
Name:	nearly there 002.JPG
    Ah yes This would be what you're looking for, sadly it has been raining overnight and the shed has flooded, making an unpleasant mess.
    Aug 2013
    gawler
    1,909
Name:	nearly there 006.JPG
ID:	83549Click image for larger version.
    Of course the Hideous paint job is inspired by the Mini.
