Page 5 of 41 FirstFirst 12345678915 ... LastLast
Results 121 to 150 of 1228
Thread: Open Wheeler Toy
  1. #121
    Nay sayer Mr Ed's Avatar
    15,038
    Looks like so much fun... now put the twin turbo V6 in it!
  2. #122
    Aug 2013
    gawler
    1,748
    I took it out today for a shakedown, just the little Kart and Drift track at Pt Gawler. What a laugh, straight out of the box it just seemed to do everything right, a little adjustment of the brake bias and there was more confidence in the stopping ability. As I did more laps and got more accustomed to it I discovered that I would break first, the padded tub is no substitute for a racing seat ! And my back and neck started to ache from trying to hold myself in place as it hurtled around the track, the little 185/60-14s doing there best to hold on. It is biddable, you can squeeze the throttle for a little more oversteer or lean on the front for a little more understeer, but isn't simply intent on pitching you of the circuit.
  3. #123
    16,301
    Been meaning to ask about the pullrod springing on the rear - Bellvilles?
  4. #124
    Bentleigh Victoria
    3,558
    If you used smaller profile tyres on 13" rims, would you then be able to wind up the suspension creating a better angle for the c.v joints?
  5. #125
    Aug 2013
    gawler
    1,748
    Yes, they are sold as disc springs, front and rear, fronts are hidden in the shockers.
    No Fucks given about driveshaft angles. Apparently it will consume a little power to turn them at the current angle, no shortage of power, no problem.
    Current line of thinking for the next one is an Eaton supercharged Duratec 3.0 V6 for 300 hp/ 500kg......600hp/Tonne ?
  6. #126
    Aug 2013
    gawler
    1,748
    I managed to source a suitable fitting Kart seat yesterday, Thank You Gavin, and am well into fitting it. I intend to finish that this morning and take it out for another run at Pt. Gawler.
  7. #127
    Aug 2013
    gawler
    1,748
    Oh, and design of fabricated front hubs is well under way, I struck a deal with Andre, who is embarking on a Midlana build that if he did the CAD work on the replacements he could have the old Mazda hubs.
    Of course that will mean new wishbones and mounts on the chassis, but it is all just mild steel so no problem to cut off and replace.
    after that of course will be the rear hubs....
  8. #128
    Aug 2013
    gawler
    1,748
Name:	2015-05-04 20_52_02-SolidWorks Premium 2014 x64 Edition - [Upright Assembly _].png
    An early image of the upright.
    It uses the rear Echo hub which simply bolts on, over that will go the Echo front disc and some caliper I found round the back of the shed, that is lighter than the Echo front caliper. Might be a Magna rear ?
    When you are trying to stop only a 350 kg car it's not so critical.
  9. #129
    Aug 2013
    gawler
    1,748
Name:	gavins seat 001.JPG
    What a difference a seat makes, pity about the weather, it was clear when I got to Pt. Gawler but it came in as I unloaded the car. A fine misty rain, enough to make everything wet, and slippery. I tried to get the brake balance right but ran out of adjustment, couldn't get enough pressure to the rears. I'll have to change one of the master cylinders, probably go up to 7/8 for the front as I've got one of them kicking around somewhere.
    I need to shorten the upper arms on the front to get me a bit more negative camber adjustment. I'll probably do that over the weekend and be ready for another test drive on Monday.
  10. #130
    Registered User stb's Avatar
    Oct 2007
    330
    Sounds like a hoot, congrats on getting it going.
  11. #131
    9,010
    So cool congrats
  12. #132
    Aug 2013
    gawler
    1,748
    Thanks for the kind messages, the car is thanks enough in itself.
    It is such a hoot to drive, an effort well worth going through and I haven't even driven it up a hill yet ! I think I'll be looking at the 26th or 27th for its hillclimb debut.
    I changed the brake cylinder this morning and modified the top arms, I'm in the midst of creating new upper mounts for the front spring/shock assembly to put them on an even lower angle to soften them a little, see if I get a little more weight transfer to the front...
    I've discovered that the Akerman angle of the Mazda uprights doesn't quite suit the current chassis and I'm not getting toe out on turns which will leave me with understeer no matter what I do elsewhere. As I've promised the uprights to Andre I will not bend the steering arms to rectify this, but will wait till I've a new fabricated set and get it right on them.
  13. #133
    12,530
    Onya mate, vids of it running/ driving?
  14. #134
    Aug 2013
    gawler
    1,748
    I'm not really one of those people, if I had the money for a Go Pro or such, I'd probably spend it on a set of harnesses, and I can't video myself whilst driving it.
    When I finally get to a hillclimb I'm sure one of my acquaintances can video my efforts.
  15. #135
    Registered User Backmarker's Avatar
    Jan 2013
    197
    So you started the build in November, and you're driving it around in May. Is this a PF record? Amazing work.
  16. #136
    12,872
    Definately a PF record. Especially for something scratch built. Great work roy, you have some mad skills!
  17. #137
    6,127
    Awesome built, looks like a heap of fun.
    I'd like to hear more about this line of thinking.
  18. #138
    Registered User Bren's Avatar
    Lockyer Valley, Qld
    2,358
    Good one mate, glad to hear it's going well! I really love the idea of a car like this.
  19. #139
    Aug 2013
    gawler
    1,748
    Thanks for the kind words
    Yeh, it has come along alright, I sent off the DXF files today for the front uprights to be cut.
    I got the top spring/shock at the front moved on sunday and that is all good and workable. The simplicity of a mild steel tubular chassis shone through, simply cut things off and fit different things on, no balls busted.
    Kart seat, why didn't I just go with that to start with???
    The Speedway Quick Steer, damn good idea, coupled to the shortened rack it is working just sweetly, a quarter turn either way is as much as one needs and is a very handy fitment for the steering wheel !
  20. #140
    Aug 2013
    gawler
    1,748
    Well, I spent an hour yesterday, in 3 twenty minute sessions, thrashing this thing around the Pt. Gawler track.
    I'm very pleased with it, the alterations over the weekend all delivered what was hoped of them.
    I could only do twenty minutes at a time, my right elbow is weak and would start to ache, and my back would also ache. It is amazing how physical it is to drive, I wouldn't believe that a 175/65-road tyre could generate such lateral forces. Today I notice I've got a bruise on my back from one of the seat bolts, can't feel that bolt when sitting in the car ?
    I consider the car an absolute success and am already firming in my mind the makeup of the next one....
  21. #141
    Aug 2013
    gawler
    1,748
    I will go back to Dirt Circuit with the next one, having decided on the 3.0 duratec, I've changed my mind, they are not common enough. Evey week in the damaged car auctions there are however camrys with the 1MZ 3 litre. Much more common, slightly less powerfull but equally capable of having a commodore supercharger fitted.
    Coupled to a Subaru gearbox or transmission?
    So a very similar car but with larger output and Dirt Circuit cagework, which is why it needs more output...
  22. #142
    Malakia Industries
    Κάλυμνος
    2,293
    Howabout a Subaru motor and box? Would save having to mess around with adapters, keep weight low in the chassis too.
  23. #143
    Aug 2013
    gawler
    1,748
    Building a chassis around a Subaru engine would be a pain, they make crap power, and are not that low either, the exhausts exit on the bottom of the heads.
    I'd rather adapt the trans to something nicer.
    I suspect that the Echo engine is a surprisingly good choice, Toyota designed it to be light and torquey, in all reality I'd probably be smarter to add a turbo to it to raise the Hp/Kg ratio. But for Dirt Circuit the chassis will have to be heavier so I'll start with a heavier, larger capacity, engine with much more torque.
    I really should be dry sumping the engine and inverting the transmission, but that costs real money.
  24. #144
    Meh
    Jan 1970
    26,940
    Well done!
    Chuck some 2nd-hand Formula Ford tyres onto it, it'll greatly increase the cornering power - You might think you're going fast but you're not.
  25. #145
    Aug 2013
    gawler
    1,748
    I'm sure you are right.
    The ethos of the car was to do it cheap, lets see how it goes at the hillclimb before I start spending more on it. I have a target time at the hillclimb that I'd like to see, lets see how close I get.
  26. #146
    12,872
    you have played with the mitsubishi engines a bit it seems.. what about a turbo 3.8 mitsu V6? might be a tad heavy
  27. #147
    Feb 2009
    Gawler SA
    3,334
    Open wheeler track record is approx 27.5 seconds .[1500 Hayabusa ]
    for "old style" Open Wheelers approx 35 to 40 ++seconds.
    Even Blue "Avatar Mini"<<< can do it in 41.
  28. #148
    Aug 2013
    gawler
    1,748
    Yes Cameron ( Bueller)I have the experience with 6G74 but they are heavy, time to move on to something lighter. The bloody LS series of V8s are a very good thing but I believe pushrods belong in the suspension not the engine.
    Yes I'm hoping to fall into the 36-38 sec area ? I really have no idea, the last thing I drove up there was a turbocharged Moke and it was around 40 sec.
    My initial enthusiasm has waned, with the determination to go back to Dirt Circuit. There is something about the brutal short track racing that has some sort of masochistic attraction, or maybe it is just that when you beat the knuckle dragging ignorant fools in their "600hp" small blocks with a turbo magna motor, feels so good.
  29. #149
    sartorial elegance ahabthearab's Avatar
    Nov 2008
    Glenreagh NSW
    2,612
    Bike engine is the go.
    Quote Originally Posted by doctorpat View Post
    Japanese performance cars are like japanese schoolgirls. By the time they are 15 years old they've all been molested so your only option is to choose one where the previous owner had similar perversions to yourself.
  30. #150
    Aug 2013
    gawler
    1,748
    Yeh , to be serious, a bike engine is the go, in a full aero car weighting less than a light breeze on a spring morning...
    I see Willem Toet is using a bike engine in his new creation.
    No, the intention of this car is simply to have some cheap fun, hence the Echo engine, wheels/tyres, fuel pump etc
