Page 3 of 7 FirstFirst 1234567 LastLast
Results 61 to 90 of 197
Thread: R zeddys fabrication corner, want something done?
    Registered User Rz's Avatar
    5,268
    job 6.
    replace aluminium pivot pins with removable s/s versions on camper trailer.
    had to rebore the hinge segments to alleviate some binding.
    also new hydraulic lines fitted.
ID:	80106   Click image for larger version.
ID:	80107   Click image for larger version.
ID:	80108   Click image for larger version.
    5,268
    job 7.
    water temp t-piece for kris.
    12,564
    Awesome dude.
    V4 Goodness Kris's Avatar
    Earth
    1,849
    Quote Originally Posted by Rz View Post
    job 7.
    Damn! Looks the biz - hit me up with the details Rz, ill get you some $ and shipping details.
    5,268
    job 8.
    fuel tank leak under mounting bracket. chop off, clean up, tig back on.
ID:	80151   Click image for larger version.
    Aug 2010
    show bobs
    2,619
    Pete, need this knocked up ASAP!
    Just mild steel tho pls
    Meh
    Jan 1970
    26,940
    Gonna need a bigger shed.
    And a runway.
    1,065
    ...Runway optional, although the option is one-time-use.
    9,031
    Gold, you are going to need some of that too
    5,268
    haha, back tomorrow to start on some shit.
    5,268
    actually.. probably be completely fucked from big week in sydney but whatevs.
    Toowoomba
    1,874
    Woah the bracket on that tank really was shagged! I filled it with water and there's no leaks, came up really nice. Thanks again!
ID:	80595Click image for larger version.
    Then there's this cluster fuck. That void I'm the top of the tank was full of sand hence rusted to buggery. Pipe broke at the mere threat of being bent. None available at the wreckers and Toyota want $600.
    Any chance you can do something with it?
    5,268
    yip.
    Aug 2010
    show bobs
    2,619
    How much you recon to make a set of block hugging headers for a 1UZ in a Hilux?
    How long is piece of strang?
    Off the shelf options:
    Hurricane $695
    Castle Hill $660
    廉價的中國垃圾 $3-400
    May 2004
    5,120
    Able to weld some uni's into a tailshaft for me? factory ones are staked and no fucker in aus wants to bother touching them. Can get replacement uni's in the right size overseas. Thinking a washer/spacer on each side, then weld the washer in place to hold the uni's where they should be. As above, original ones are staked in and there is no groove for a snap ring, so need something to locate them and stop them moving.
    5,268
    5ORTED i tend to shy on quoting manifolds as they take fucking ages to make, for my skills anyway. but yeh won't even be ballpark price of those, use off the shelf if you can!
    madhatter, ill give it go sure.
    Aug 2010
    show bobs
    2,619
    Thanks mate is understandable!
    Jul 2002
    Brisbane Aust
    1,721
    What ever you do don't buy castle hill. That guy is a cunt!
    "And I know that arseholes grow on trees but I'm here to trim the leaves" Peeping Tom, Mike Patton
    May 2004
    5,120
    Something sort of like this. I could do this though with a mig. Someone with a bit more heat control could actually do a good job of welding them in place. Id get the shafts sorted, work out the spacers and install and mark the unis for you. All you would need to do is check the unis line up with the marks, then weld them up on each side.
    5,268
    yeh too easy.
    so atm schedule is:
    mylib if you still want that hiace tank made? i have you marked down as next in que, will pm anyway.
    guido
    tim (mx5)
    mark (mk3)
    im dj, still haven't got around to CAD'ing that under tray so i can get some run off, will fit in between above jobs.
    9,031
    Thanks rz
    Registered User PaulExo's Avatar
    Mar 2014
    139
    This is leaking, a couple of shops have had a crack at it, looks better every time, leaks worse. Any chance its fixable or fab a new one?
    18,143
    Quote Originally Posted by pH@tTm@N View Post
    they are castle auto electrics or some shit we dont make them, never have.. get fucking 40 cunts a week call up for shit that those guys make lol
    Sidetracked BMWTurbo's Avatar
    Aug 2004
    3,433
    Quote Originally Posted by MilkJuice View Post
    Other suggestions for fixing this before Downshift Saturday??
    9,429
    JB weld, no italacs.
    5,268
    yep i got it
    bring it.
    5,268
    if i get it after the jbweld lots of cunt-punches will ensue.
    Mar 2014
    139
    backing away from jb weld...
    5,268
    all good now?
    9,031
    Other thread says it was flawless
