Page 10 of 10 FirstFirst ... 678910
Results 271 to 295 of 295
Thread: Evo 8 racecar
  1. #271
    1,579
    Well done Andy on 3rd in Qualy, on a few tenths from pole. You will be 1st after 100m with the usual great start.
    Adam
    Sandown 1.23.31
    Calder 1.05.76
    Phillip Island 1.47.95
    Winton 1.33.30
    Bathurst 2.47.49
  2. #272
    Sep 2005
    778
    But then second lap DNF in the first race? Hoping an update is on its way soon.....
  3. #273
    Jan 2006
    australia
    550
    fuel pump wiring issue I believe.
    fixed now .
    little bit of panel damage Friday.
    today I recon top two finish.
    Originally Posted by Tut
  4. #274
    Aug 2013
    gawler
    1,656
    I was expecting to see Hislop well out in front...NO...Browny for the solid win!!
    " I didn't have $$$$$, so I thought I'd build a car instead" : Ron Tauranac
  5. #275
    248
    Was an interesting weekend, every little thing that could go wrong did, but when the car was working properly it was as good as it's ever been.
    Practice
    Went out on old tyres to work out where the track went again and started building up to having a crack at a decent lap when the brake pedal went to the floor coming into turn 11. Drove it back to the pit lane expecting to have burst a brake line but all the fluid was still in the system so it appeared to be boiling brake fluid. Weird, because I ran the same brakes last year and they were fine. Put it down to the pads not being bedded in properly and went back out once it cooled off a little.
    Qualifying
    Bled the brakes up, put the old pads from last year back because we figured these worked fine so they must be ok again, and put some new rubber. Went out scrubbed the tyres and had a crack. Ended up .1 off Browny in second spot for most of the session until Hislop banked a good time right at the end and put me back to 3rd, .05 quicker than my time. Was hoping to be on the front row for the start, as I'd need all the help I could get to keep away from those two for the duration of a race.
    Race 1
    Plan was to get the best start I've ever done and go for it to see what sort of a gap I could pull.
    On the warm up lap I started getting fuel pressure warnings off the dash and the car would momentarily cut out coming out of right hand corners. Not ideal but not much I can do about it at that point.
    Got a wicked start and the other two held each other up on turn 1, even better. Managed to pull a decent gap until I got to turn 8 where the car shut off until halfway to 9. Still in front but no more lead. Hung on with it cutting in and out until the next lap where it shut off all together and I parked it.
    Haven't had a chance to find the actual wiring fault because we just bypassed it, but there was something that's come loose inside the factory fuse board which was switching the relay off when you rattled the fuse box. I'm guessing it didn't like kerbs very much.
    Race 2
    Started from the back row and got to 8th, then the brake fluid boiled again and I dropped back to 10th driving around pumping up the brake pedal.
    Got a post race drive through penalty for contact passing someone on the first lap. I braked, thought he'd seen me but he hadn't and shut the door.
    I hit his back wheel spinning him round. Penalty put me back to 17th for race 3... time to fit brake ducts, move the intercooler sprayers to the rotors and try again.
    Race 3
    Got held up a fair bit for the first 3 laps with a few guys having a massive battle.
    Joined in for a while and managed to pick them off one by one, finishing 8th.
    Race 4
    Needed another good start and to get to Browny and Hislop at the front if I was going to have any shot at staying with them. Had a rough plan of where to go at the start and guessed correctly with a nice big spot opening up for me to fit into, got to turn 4 and was battling for 2nd. Avoided a couple of divebombs on the first lap and started to chase down Peter Ingram's RX7.
    Unfortunately there was a big shunt in turn 8 and the race finished under safety car. Disappointing finish but still happy with 3rd spot after a fairly trying weekend.
    Time to get some decent brakes for it and prepare for the IP nationals later in the year.
  6. #276
    8,413
    Cracking job Andy. Your start in race 1 had me cheering at the screen. Fark it got off the line well.
    Sonova Beach
    6,240
    Watched all 4 races last night.
    Spewing you couldn't string a decent weekend together. I don't think many did anyway. The thing was a jet.
  8. #278
    canberra
    3,635
    Bloody hell some of your opposition were being a tad 'brave' under brakes not that it was paying off. Some unexpected power out there too?
    GT8
    1UZ Celica
    1.07 flat Wakefield Park
  9. #279
    248
    Data was interesting, 3.8 to the 100km/h with 2 gear changes and driving around a blue sprinter, not too bad for fat LMT.
    Yeah few divebombs to avoid... I was happy to run side by side with Hislop, even if it was only for about 3 corners
  10. #280
    248
    Uploaded the first lap and a bit from race 1
    Need to look at options for front brake replacements as well.
    Problem I have is that the pads in the alcon/AP offerings which will fit under my 17" wheels are only 18mm thick.
    I'm not convinced that they will really be up to the task as the car gets quicker, obviously the slightly bigger disc and better calipers would help as well but am I wasting my time and should I be saving my pennies to go to 18's to fit something I'll never have to worry about?
  11. #281
    558
    Quote Originally Posted by Andy San View Post
    Do you know what peak temperature the existing setup is getting to? IE are they getting over the maximum for the range of the pads, and staying over for an extended period? If the heat is not dissipating, thicker pads and bigger rotors will just delay the inevitable. Are you getting enough airflow through the existing setup?
    Answers to these questions will help answer your question.
  12. #282
    248
    The issue isn't so much that the pads are getting over temperature, they actually work really well. The brake fluid was boiling after about 6 laps at clipsal due to it not being able to disperse the heat well enough.
    I'm using SRF which is about the highest temp fluid available, but the standard calipers and rotors seem to retain a lot of residual heat which is just cooking everything after an extended period of time.
    We put brake ducting on, but there isn't a lot of room with the factory caliper size to fit a decent diameter tube into the rotor, so it basically did nothing. Moving the intercooler sprayers onto the rotors helped, until it ran out of water and cooked everything anyway.
    My thoughts were that the only reason you run the larger pads and rotors is to give you more time before it cooks everything, and with the better quality rotor construction and less material in the AP calipers the heat buildup will be reduced a lot. Question is, how large do I need to go if I'm only just having issues now on what's probably the worst circuit in the country for brake temps?
  13. #283
    558
    Assuming your brake fluid was new prior to the weekend, do you have your brake ducting set up as in the above drawing, in particular with the ducting sealed to the inside of the rotor? I've drawn it with two small ducts, acknowledging your packaging issue with the calipers. This setup makes a difference to how well the rotors cool and therefore the heat transmitted in to the fluid. Just pointing the ducting at the rotor does not get the same airflow through the rotor vanes.
    If you have this setup already, the only other thing I can think of is a bigger reservoir for the redirected intercooler sprayers. How are you travelling relative to minimum weight?
    Trying to rule out all the cheap options before you go to the expense of new tyres, wheels and brakes.....
  14. #284
    Aug 2013
    gawler
    1,656
    I've recently come to the same conclusion with regards to brakes and cooling, the mass of the components can only do so much, after that it is all about cooling them effectively. Managing the airflow to maximise the flow where required. I do love some of the skeletal titanium brake calipers available these days....
  15. #285
    248
    This is what the back of the hub looks like with someone's premade brake duct fitted, not a whole lot of space to fit a backing disc in
  16. #286
    558
    Unless I'm mistaken, it may already have a blanking plate in there, the part circled below looks like the remains of the stone guard cut down to suit this purpose. The blanking plate would normally mount where the stock stone guard mounts.
    As you say, there's not much space to work with. One thing a bigger rotor would do is give you more room for ducting. Could you just get bigger rotors and make up an adaptor to suit those calipers?
  17. #287
    Jun 2007
    732
    I'm assuming that the stock Evo Brembo's run an aluminium piston? Does anyone make a replacement castellated piston in Stainless or Ti (lol)? This will go a long way to slowing down the rate at which the heat from the pads is transferred into the fluid. Some allege that placing Ti shims between the pads and pistons will help but I've never used them, they are quite cheap through Girodisc in the states.
    **edit**
    Racing brake sell pistons - good guys to deal with.
    https://www.racingbrake.com/EVO-Fron...s-p/bm-41p.htm
  18. #288
    1,222
    Have you had someone press the brake pedal and see if the calipers are any good still? Someone up here ran evo brembos on their car, got them very hot in a race and they were spreading so badly, no dial indicator was needed to see they were cactus.
    Another guy up here with 4 or 5 race evos installed Alcons on all of them straight up, after going through this with earlier VII and VIII versions.....and they're slower than IP spec. AP has some good info on ducting too, that tapering inlet wouldn't be too flash, but not much room to play with I guess.
  19. #289
    8,413
    Yep, have certainly heard of the Evo Brembos going soft.
    1,579
    Andy, what tyre size are you running on the 17's?, 245/45x17 ?.
    I'm just upgrading my brakes to 343x32 with 4 pot caliper which fits under my 17's.
    Adam
    Sandown 1.23.31
    Calder 1.05.76
    Winton 1.33.30
    Bathurst 2.47.49
  21. #291
    248
    Quote Originally Posted by adamRSLC View Post
    Adam
    I'm running a 255/40/17. AP and alcon both do a 343x32 6 piston kit, but I'm more worried about heat removal from the caliper than the overall diameter of the rotor, as I think that the 340mm rotors are more than big enough.
  22. #292
    1,579
    I didnt realise you could get the 255/40x17 for IP in the Yokie. I was told 245/45x17 would be the better choice. Cheers.
    Sandown 1.23.31
    Calder 1.05.76
    Winton 1.33.30
    Bathurst 2.47.49
  23. #293
    248
    Went up to the bend yesterday for a bit of a test session to try some new gearing changes for the longer track.
    Gearing worked well, but found out that astra power steering pumps don't like lots of laps on long radius corners. Will need to look at adding a cooler to the power steering return line somewhere.
    Had a limited number of laps because we spent the day chasing a missfire but eventually got down to a 2:06. Lost a fair bit of time running wide mid lap as well so I think a 2:04 should be on the cards with a bit more seat time.
    Unfortunately the motor is pushing coolant under boost so it'll have to come out for a freshen up before the end of the year... which means no nationals for me.
  24. #294
    1,957
    Would something like this be better than the astra power steering pump???
    https://www.ultimatepowersteering.co...ring-pump-kit/
    I have one for my S14 prod sports. Not fitted yet, but talking to the owner of the power steering shop was the better option for my application. Plus Warwick has a very nice hillclimb open wheeler that is stupidly fast.
  25. #295
    248
    I think just putting a cooling loop in the return line should help a fair bit, plus it's a cheaper alternative to try first. Worst comes to worst I can just put the original evo pump and lines back on.
