Page 3 of 11 FirstFirst 1234567 ... LastLast
Results 61 to 90 of 301
Thread: Evo 8 racecar
    909
    Looked good out there mate, the car is a credit to you
    257
    Quote Originally Posted by charged View Post
    Thanks mate, was good to see you all out there on the weekend... now hurry up and get your thing back out there!
    Registered User COS61AE86RACER's Avatar
    Jan 2006
    170
    Nice work mate
    Chris O
    257
    Some incar from the other week, and a few photos
    Going to have a look at cams and some adjustable cam gears to try and get a bit more top end power from it.
    257
    Final race for the weekend, finally starting to get the suspension setup a bit better.
    Apr 2009
    sydney australia
    299
    Hey Andy, great looking car...production race cars had problems with the eccentrics on the rear control arms coming loose and the rear camber and toe being affected. I made some laser cut spacer shims in half mm incaments to replace the eccentric bolts and it stoped the rear end moving out of alignment. If you want the files so you can get some laser cut your self , send me you email address.
    257
    Quote Originally Posted by gerry View Post
    That would be great, cheers, PM sent.
    257
    So after the first couple of outings in the car it was clear that the standard sump wasn't up to the task of keeping the oil somewhere near the pickup during cornering. I tried to fix this by overfilling the oil a little and welding in a baffle around the pickup similar to the Burschur racing sumps, which helped to fix some of the oil surge, but still didn't really help with the lack of oil volume. Only way to fix that was going to be to increase the overall capacity. Got a mate of mine to knock me up a larger capacity winged sump with a much improved baffle around the oil pickup, hopefully this will fix it for good. I also fitted a Tomei oil thermostat delete so the oil cooler will now be working full time.
    Seeing as the motor was out of the car, I decided to fit some Tomei vernier pulleys and some slightly larger cams, which will hopefully give it a little bit more top end power, as it was dropping off just a little bit too early with the standard stuff.
    Finished mounting my new oil cooler, hopefully it will work a little more efficiently than the oem unit.
    Went back to the dyno yesterday to see if the changes to the motor had made any sort of difference.
    Was fairly happy with the results, although the wastegate actuator on the new turbo I'd fitted would only let us make 20psi, so I'll have to change that over and see if a bit more boost will net any more power.
    Regardless of this problem the motor still made more grunt than it had before, with a much more usable rev range and far better oil temps with the larger oil cooler, so I'm looking forward to seeing how it will go next week at Mallala.
    I also fitted up the knockback springs to the rear brake calipers, along with lock wiring the pins that hold the pads in, which will definitely stop them being pushed out of the caliper.
    GTR Wanker MR 1JZ's Avatar
    May 2005
    Rademalaide
    3,322
    how many tokens was the sump?
    257
    Think Dan's doing them for about $750ish
    257
    Been a little while since the last update... Finally managed to make up a sump on this thing that doesn't get oil surge, which is good because now I can concentrate on making it handle rather than worrying about whether or not it's going to chuck a rod.
    Went out for the final state round of the year a couple of weekends ago, managed to qualify 2nd behind the always quick Sprinter of Chris Brown, and stayed there for race 1, lowering my pb to a 1:14.8, so heading in the right direction times wise.
    Got the jump off the line in race 2 but definitely felt like there was something weird about the car heading into turn 1. Quickly worked out the rear brakes had jammed on, due to me over adjusting the hydraulic handbrake pushrod and blocking off the return port on the cylinder... doh! At least an easy fix, but still annoying and the first DNF for the car.
    Rain came literally as we were rolling around to start race 3, so that made coming back through the field a lot easier, so I managed to win that race, along with the last one as well in the dark. All in all a pretty good weekend!
    Plans are to now get everything tidied up and sorted over Christmas as IP will be running at the Clipsal 500 next year so I'd like to make sure everything can be as sorted and reliable as possible. Can't wait to send it through the chicane!
    Here's a video from the first lap of race 3.
    8,582
    Great work Andy!
    At work :(
    18,265
    Is that rubber lip factory? Thanks!
    (TM - AVENGE)
    9,031
    looks awesome. great setup
    257
    It's just a cheap fibreglass one off ebay from memory, same design as the ralliart lip.
    257
    Competed at the Willunga Hillclimb over the weekend. Managed to go a lot better than I thought I would, Picking up 3rd for the event!
    Was nice to use the car for something other than circuit racing, and the lack of power suited the twisty stuff at the top of the hill pretty well... although a bit more grunt would have been nice.
    Here's a video of my fastest run for the day
    May 2005
    Rademalaide
    3,322
    needs more widebody
    257
    Quote Originally Posted by MR 1JZ View Post
    needs more widebody
    I'll make sure I leave the original guards underneath
    At work :(
    18,265
    Pretty fast open road for the first half of the hillclimb.
    (TM - AVENGE)
    257
    It's a great bit of road, I normally don't get too excited by hillclimbs, but this one is definitely worth doing!
    257
    Picked the car up yesterday from the signwriter after getting it's Clipsal livery applied... Super happy with the end result, should stand out pretty well on track!
    Couple more stickers and a wheel alignment left and it'll be ready to go next week!
    8,582
    Looks good!
    Aug 2011
    255
    Any pictures of what you did to the sump to prevent oil starvation on rights?
    257
    Speak to Dan at Tuff Customs, he can build you a sump that works.
    Aug 2011
    255
    Quote Originally Posted by Andy San View Post
    Ah, yes I saw that on facebook. Looks almost identical to the racefab one (wonder if its just as expensive?).
    257
    The only difference is this one actually works like it's intended When you compare them there are a lot of differences internally.
    Aug 2011
    255
    Ah ok, yeh they didnt show any pictures of the baffling. Was curious about it cause I would weld one up myself instead if I know how to baffle it correctly. Thanks for the info anyways. Is the car set for the next event?
    257
    Simple enough to work out with a bit of time, effort and logging. That's all we did.
    The Tuff Customs ones can also be pulled apart for cleaning which is a big plus.
    Just about ready to go, few small jobs this weekend left to do and see what happens next week.
    6,200
    Car looks awesome, nice one.
    Sneakers prompted the erection. Engine stand made me do something with it
    257
    Well Clipsal was an awesome experience. I managed to run close to the front all weekend, 2nd in practice, 4th in qualifying and a couple of 3rds and a 4th in the races meant I finished on the podium for the weekend, which was an added bonus.
    Car went really well with no major issues, although I did have problems with the rear diff open wheeling out of the tighter corners in the last race, which made me lose a bit of time against the guys I'd been beating all weekend.
    Going to have to look at changing the turbo over though as I do need to get a bit more power out of it now, I'm getting smashed in a straight line against some of the more powerful turbo cars.
    Few good photos from the weekend -
    In car from race 1:
