Results 31 to 60 of 62
Thread: best cheapest way to cut steel tube/rhs/etc
    Toowoomba
    1,260
    I picked up one of the TradeTools dry metal saws this week, boy it eats through steel. Have found 2 problems so far though:
    1. If you just swivel the guide to 45 degrees it won't cut all the way though, you have to bolt on the supplied spacer
    2. If you're just taking a small amount off (eg 20mm) it can become a serious projectile when it falls back towards the blade. Happened twice when we were testing at 45 degrees and the 40 SHS offcut was flung 15-20m.
    Otherwise it's mint, you can handle the pieces straight away and the finish is good enough to immediately weld.
    Wrong.
    7,134
    Yep I'm loving mine.
    If you set the material right so it's cutting on the front bottom 60 degrees or so it doesn't flick the material to god knows where when doing a tiny edge. I cut some credit card sized bits of 50mm box to show the old man as he didn't believe it could. Need to make a stand for it though so the fucker doesn't live on the floor.
    Metal cuttings tray seems to catch maybe 50% of the swarf. Beats the living fuck out of the dust everywhere from an abrasive.
    1,124
    Anyone have any feedback with something like this?
    http://www.totaltools.com.au/saber-m...b115/i1097207/
    Looking to cut stainless and alum tube.
    Dec 2004
    Sydney ,Australia
    814
    They are ok, pretty flimsy though. If you arent looking for perfect cuts, it will be fine.
    1,124
    Hare and Forbes ones any better? (entry level type)
    https://www.machineryhouse.com.au/Horizontal-Bandsaws
    Mainly for 1.25" to 1.5" stainless, maybe 3" aluminium and possibly also 4" stainless.
    Dec 2004
    Sydney ,Australia
    814
    I had the hard and forbes one. Was ok but i wanted something more sturdy etc and upgraded to a larger machine.
    The small one is slow and the cuts arent always perfect.
    Opens ALLMTR's Avatar
    Newcastlish
    23,490
    I had the bs4a and gave it away. The blade seemed to wander a bit no matter how much I fiddled with it. Give me a cordless angle grinder and a 1mm disc any day
    Aug 2011
    397
    I run a 9 inch grinder blade in a bunnings mitre saw designed for wood. Works a treat, much nicer than the cheapo drop saws.
    6,154
    Quote Originally Posted by mrniceguy View Post
    Was looking at circular saw blades (for wood) at masters the other day, noticed they had blades for cutting ferrous metal, would be worth a try in a mitre/drop saw. Think the size I was looking at was a hundred or so, 10 inch probably. Do you clamp it or just hold it? Plenty of ways to do that I suppose.
    5,505
    I would definitely be clamping it.
    Daily: Honda Civic EK1 Hatch
    Aug 2011
    397
    I clamp it. The wood saws at bunnings for some reason are so much nicer than the metal drop saws. A proper casr aluminium base rather than shitty stamped steel. If you set it at 45deg it actually cuts pretty close to 45deg.
    5,505
    Do the blades bolt straight on?
    Aug 2011
    397
    Nah i had to machine a spacer. 16mm id 20mm od by 2.4mm iirc. But i just used the saw i already had. Others might bolt straight on.
    loves the Cressy
    Jul 2005
    Gympie Australia
    2,453
    Or, you can just buy an arbor adaptor from most decent hardware stores, does what the thing you machined does, for fairly cheap.
    Cheers, Richard
    - Long Term Jobs
    3,609
    Watch the speeds, the wood saws generally run a lot faster than the metal blades like.
    Apr 2009
    Devonport, Tasmania Australia
    2,251
    hey guys. trying to get my head around this one so bear with me
    im getting half decent cuts with my drop saw, but not amazing repeatabilty. So was looking at something like the above. am i right in thinking i can simply replace the blade in my current drop saw and get similar results? i measure all my own angle marks rather than use the stamped ones...
    also can the dry cut blades be used on tube and pipe? only examples i have seen are using rhs?
    cheers and sorry for the dumb questions lol
    06/07/2011
    1,124
    I noticed these today at Trade Tools,
    http://www.lenoxtools.com/pages/lenox-metalmax.aspx
    About $135 for a 136mm blade, max RPM was around 4,300.
    Might be a cheaper alternative to use a Ozito brand drop saw with one of these blades but despite what the packaging says, I unsure how the speed will go on some metals.
    Registered User Dimi's Avatar
    Sep 2012
    1,684
    Quote Originally Posted by [RX3] View Post
    Just a heads up, i bought an ozito saw as a shitter for when i have to go build stuff on site. Regardless of any amount if adjustment the cuntofa thing will not cut square. the head actually flexes in relation to the base plate as you press downwards on it. OK for chopping RHS to roughly fit making fences, gates, tables where you can mig it and who cares. Not so good for manifolds.
    1,124
    haha, I have one and use it for some stainless pipe. Seems okay but I always over cut so I can get it flat on the linisher, by the time I add a little bevel it's quite square. Just a pain having to rotate the pipe 3 times to get a nice clean cut.
    Mar 2013
    Melb
    80
    For the guys with the trade tools saws... How have you found the performance cutting stainless tube? The blades are pretty expensive https://www.tradetools.com/product-r...r-steel-drc355
    Wrong.
    7,134
    No problem cutting up a bunch of stainless on mine for a mate.
    But I used a bit of wax, and a water/metho mix sprayed on the blade while cutting. Means you need to wipe and clean it later but thats easier than me chipping a tooth.
    There's other blades cheaper, $80 from sharpening shop for one as a spare hanging on the wall if I need. Sadly it's been months since I've been home to use mine
    Suspended
    mebourne
    3,964
    I've got a dry saw cutter the blades are awesome. Ive had the same blade and years and I've cut through so much shit very suprised.
    Apr 2009
    2,251
    righto lads. i have tried to buy the trade tools dry cut above. but the guys want near 300 in shipping. i asked if they could check seeing as i got a gearbox shipped from their last year for 85 and ego only wants 75... but i was kindly told to go play with myself thats what freight costs.
    so ebay it is
    does anyone have any feedback advice on this bad boy???
    http://www.ebay.com.au/itm/Steelmax-...25.m3641.l6368
    cheers gents
    06/07/2011
    Apr 2009
    2,251
    and is this better enough to justify the 200 price difference?
    http://www.ebay.com.au/itm/355-mm-dr...QAAOSwFdtXxhCw
    06/07/2011
    5,505
    Whats the current hot shit in cold saws under 1k? The trade tools one cracka has is nla, adelaide tools has the evolution rage 2 for $500, sydney tools has the bayer something 2400w 355mm thing for $450 shipped. Then theres bosch and makita for 700ish and dewalt for 850. Dewalt looked fancy but is still a pressed base whereas the bayer chinesy deal has a milled alloy base...
    All I want is less shit flying around the shed and square cuts.
    Cheers!
    Apr 2009
    2,251
    Just had a quick look on eBay qnd the rage saw looks very similar to the eBay spec saw I got a while back... It's cheaper than the one I got and the base looks like pressed Steel not cast alloy like mine, but the saw looks the same and the clamps etc...
    I have only used mine a few times but absolutely fucking love the cunt. It's fucking amazing for what it is.... But I can't seem to find it online right now... :/
    06/07/2011
    5,505
    Look up the bayer at sydney tools, might be the same unit.
    Annoying that the tradetools one is nla because it looks to be the best of the no name ones.
    Wrong.
    7,134
    Cheers!
    ttade tools told me they had 26 on order, so maybe not nla?
    5,505
    I just went off the website.
    Is it just me or is it hard to find people to take my money in exchange for goods? Like 90% of the time the exact thing I want is on back order by 50 units or some shit. Then I look on US forums and they have 20 other options all cheaper and better (usually the case with tools). I really hope Amazon will stock proper tools, I'm over hunting shit down.
    16,340
    yeah i'm not seeing it either, reckon the way to cut bends is on a vertical bandsaw with some kind of slider on it one clamps the bend to. half the reason I want to cut better is to allow me to do lobster bends, which doesn't require any bends. although bends don;t cost much more than straight tube anyway...
    Missed this last time round - knock up a bit of 3/4" ply with a Ubolt through it for holding the tube (add spacer on back for clearance on nuts). Add stopper block with batten screw if needed. When it's got too many holes in it, go for a new piece of ply.
    Hey Cracka - reckon that saw of yours will cut 6061 in 4" round bar?
