Page 1 of 4 1234 LastLast
Results 1 to 30 of 109
Thread: Brad's UZA80 Supra
    Registered User Brad88's Avatar
    Oct 2008
    311
    Brad's UZA80 Supra
    Had this thing for a bit over 7 Years now and as various other cars have come and gone it has remained. Thought it was about time I shared it with PF.
    Brought it as a completely standard 1993 SZ JZA80.
    Spent a way to much money on a bodykits, various wheels and carbon bits over the years.
    By mid 2011 I purchased a 1UZ-FE for it and planned to make it look as if it looked factory delivered with cruise control, AC etc as a nice daily.
    Before I had even driven it around the block, I decided that the W58 5 speed wouldn't but up for the task and a 1993 RZ was purchased as a donor for its V160, B03B diff and a few other bits and pieces.
    Fast forward 2 years later and by mid november 2013 the car was running nicely on the Haltech PS2000. Did a timeattack track day at QR and followed up with a Dyno Day a fortnight later. Made 213rwhp with Rush Headers, CoP and the Haltech on a self tune.
    Power and handling was much better than with the 2JZ-GE, but the next step was boost. Brought a set of VNT25 Turbos off a kit in the UK and got stuck into fitting them.
    Wasn't really satisfied with the fitment so on-sold the kit and more recently brought a Genuine T04Z for it. By now another 12 months (Nov 2014) have passed and I've only done 400km in it since 2011. I thought I'd reassemble it as naturally aspirated and just drive it around for a while until I could afford to throw more cash at it.
    After purchasing a new battery the car would not crank over, turns out one of the belt guides had broken off around the front crank seal and had severely damaged the timing belt. A 100,000 km service was undertaken with new Water Pump, Idlers, Tensioner and Belt while the car was apart.
    Reassembled and the car fired ran for 30 seconds before ceasing up. After a lot of confusion it was revealed that it had crank walk when engaging the clutch and the crank had walked far enough forward to lock it it up.
    Turns out most of the thrust bearing was now in the bottom of the sump. The crank was nicely scored and it had also spun the #3 main bearing.
    Pulled the heads off to find it had also done a head gasket. Makes the 213RWHP Dyno result the last time it was driven quite impressive.
    Time to find a new motor.
    Current Spec List reads a bit as follows
    Drive Train
    1994 1UZ-FE
    Hydraulic Fan Delete
    Fluidyne Radiator
    Spal Twin Thermo Fans
    Twin Bosch 044's
    Custom Surge Tank and DeatschWerks 300+ LPH Fuel Pump
    -8AN Feed and Return Fuel lines
    Turbosmart FPR 2000
    Haltech PS2000
    Racepak IQ3 Dash
    3.5" Titanium Trust Exhaust
    30 Row Oil Cooler W/ Greddy Remote oil Filter
    RX-7 Series 5 550CC High Impendence Injectors
    2UZ-FE Coil on Plugs
    6spd Getrag V160
    B03B Diff W/ TRD LSD
    Quartermaster 8.50" Twin Plate Clutch
    TTC Adapter Plate
    FZJ80 3/4" Master Clutch Cylinder w/Braided Clutch Line
    Handling
    OEM Factory 17" Wheels
    Solid Rear Diff Mounts
    Solid Front Diff Mounts
    Solid Front & Rear Subframe Mounts
    Whiteline Sway Bar Bushes Front & Rear
    TTC Underbody braces
    iMec Front Strut Brace
    RZ Sway Bars
    Brakes
    LS400 4 Pot Front Calipers
    RZ 2 Pot Rear Calipers
    Slotted DBA Rotors with A1FM Pads all round
    TRD Braided Brake Lines
    Exterior
    Modified Top Secret Front Bar
    Modified Blitz Side Skirts
    Trial Rear Bumper
    Greddy Rear Wing
    Series II Head & Tail Lights
    Shaved Aerial / Rear Wiper / Badges
    Interior
    Recaro SR2 Seats in Black Leather & Alcentra
    Cusco 5 Point Rear Cage
    Momo Steering Wheel
    Rear Seat Delete
    '93 6SPD T04Z UZA80 Supra
    '93 Auto T04Z JZA80 Supra
    '97 5SPD Corolla RallyX Shitbox
    PF F1 SuperBru Tipping Champion '15, '16 & '17
    2,278
    Love it.
    Were you the guy that bought the TT kit and only half of it showed up?
    Oct 2008
    311
    Quote Originally Posted by Tyrie View Post
    Love it.
    Yeah, missed a heap of bits as far as dump pipe, air filters. Wastegate was damaged and all the braided lines were fucked.
    Sep 2007
    5,130
    Ouch not much luck here
    Clutch/adaptor plate caused the crank walk ?
    Is that the kit from that cowboybebop guy in the States?
    3x1UZ+1x2UR...
    Registered User Swang's Avatar
    Mar 2015
    Parramatta
    214
    love 1uz's so subbing and hoping your luck improves. I've got a mate with a crown (factory 1uz) but it's fairly sedate, might link him to this so he can get a bit more out of the car (pre vvt motor).
    8,364
    Nice brad, bad luck on the motor.
    DJ's don't need sigs
    1,588
    interested to see where this goes....
    Aug 2009
    1,676
    Fantastic! Always been a fan of the UZA80 conversion, keen to see where this ends up!
    Oct 2008
    311
    Quote Originally Posted by Muz is a cunt View Post
    Possibly, pressure plate isn't overly heavy. I don't think its related to the adapter plate which is a cowboybebop (TTC) one, however the clutch was brought separately.
    Will put another standard motor in and see if it happens again.
    Interesting damage to #7 & #8 Pistons, they are very heavily scored. I'm assuming caused by the crank pushing forward?
    1,588
    I'm guessing the clutch is a fairly small diameter unit with a lot of clamping force? might be better going for something that's larger diameter that has a leverage advantage for the throw-out bearing and/or adding more thrusts to the crank!
    1,588
    p.s there is a v8 soarer on here for peanuts up your way might be worth getting for the motor!
    Registered User E-Z's Avatar
    3,777
    Sold yesterday
    caprice nugget.
    Oct 2008
    311
    Pretty much on the money there, clutch is 8.5 Twin Plate QM".
    1,588
    for a road car I'd be looking at the largest diameter twin plate organic/carbon you can fit and then look at power goals vs dead thrusts vs required clamping load of clutch
    1,588
    also got a photo of the clutch now? interested to see where the throw-out bearing is touching on the fingers... could also be a cause of excessive loading if it's pressing half way down the fingers
    Oct 2008
    311
    Car is likely to be 80% track, 20% street so not to concerned regarding street ability, it will need to do for now.
    Clutch is in a box in the garage somewhere at the moment as I've just moved but will dig out later in the week and grab a picture.
    Oct 2008
    311
    throw out is only just touching the end of the fingers as pictured below.
    1,588
    hmmmm you don't have a clutch switch that requires pressing the clutch to start the car do you?
    Oct 2008
    311
    Negative.
    Replacement motor has arrived a few weeks ago, looks to be in mint condition compared to the last one. I've taken a few shims out of the Quartermaster hydraulic throw out bearing this time round.
    Bolted up the Gearbox and dropped it in this afternoon. Can't find a heap of the bolts to re-assemble it since I moved in March so might take a bit longer to reassemble.
    3,777
    Meh. You never put 50% of the bolts back in after a swap anyway.
    caprice nugget.
    Wrong.
    6,969
    This. 2.1kg of bolts and brackets weighed I didn't reinstall just from pulling heads...
    3,777
    Far out wouldn't imagine that kinda amount
    caprice nugget.
    Oct 2008
    311
    Agreed but the trouble is they are a couple from the Adapter Plate to Bellhousing and all gearbox mount bolts.
    Jul 2007
    Blackwater, QLD
    1,555
    the pistons look like it's siezed at some point. have you ever run it out of oil? or maybe had a lean out on those cylinders? do these engines have piston oil squirters?
    Oct 2008
    311
    I think there are a few variants of the 1UZ that does have the squirters but neither of mine have had them. Not aware of any oil issues.
    Took this around the block for the first time today after not driving it for 18 months. No skids just yet.
    Obligatory phone pictures.
    Oct 2008
    311
    Decided to buy a TIG Welder and teach myself to weld. Thought I'd start off with making my own turbo manifolds for the TO4Z that I plan to put on this thing. Due to space, logs are about the only option and even then it is going to be tight.
    Picked up a pair of flanges and set about learning to weld.
    Progress so far...
    First attempt was pretty shit house but its a start.
    Looking at keeping the banks divided right to the turbo but not quite sure how I'll set up the waste gate yet.
    2,278
    Looks a shitload neater than my welds and mine have held the weight of the turbo just fine.
    Mine has the wastegate coming out at right angles where the two pipes merge at the flange. Seems to control boost well.
    Aug 2014
    New Zealand
    604
    Looks all good man dont be afraid with that thick walled pipe to crank it up. Just off memory you should have no probs at 100-120 amps with that, cook it up bro. But beware the wobbly hand, wrap the lead around your arm to take the weight off the torch, helps a fair bit.
    Oct 2008
    311
    Any pictures? Is the turbo braced at all?
    Quote Originally Posted by Mc Juicy Hairy Balls View Post
    Cheers, that was at 85 Amp from memory, will bump it up on the next go. Penetration seems to be alright.
    2,278
    It's just butt welded with a couple of straps welded perpendicular to the butt. I was planning on bracing the flange back to the block but never got around to it.
