Page 1 of 22 1234511 ... LastLast
Results 1 to 30 of 653
Thread: ECU Tunes and Installs
    6,244
    I'm back from my day job and have a bit of a backlog to work through for ECU installs and wiring. I thought I might post some pics and details of how I install and tune on different cars and ECUs.
    Starting off with this 1JZ Soarer, running some cams, a new turbo, 6 boost manifold and a 1280 ECU. It did come in with a dead PowerFC, and had it not broken they are really capable ECU's if you can work around their idiosyncrasies. This one was faulty (Failed chip when warm causing hesitations), so we decided with the Adaptronic due to many factors.
    The Adaptronic has 12 injector outputs, 8 ignitor outputs, 8 high current aux outputs, 8 digital inputs and 16 analogue inputs. The beaut thing about these ECU's is that the injector and ignition outputs can be re-purposed to high current aux outputs should you not have 12 cylinders. The wiring diagram does assign wires to specific roles like MAP and TPS to certain analogue inputs, but these too can be changed in software should you make a mistake wiring or want to do something different.
    I always start with a IO (Input/Output) count and either write it down, write it on the wiring diagram, or if the software allows, just enter it straight in to the ECU. After playing with the new Haltech range, they have this function now too. An IO count and diagram really helps you get your head around where to start and gives a good indication of progress.
    From there I start wiring, usually ECU power, relays and anything 12v. With most modern ECU's, you can retain the standard EFI relays, ECCS etc etc sort of stuff and have it triggered by the ECU as if it was the stock ECU. This is a very nice way to do things, as it retains fuse/relay functions and wiring diagrams. Often you have to drive ECCS relays high, which is something some ECU's are not capable of doing without an interposing relay. The adaptronic can do it with the tick of a box in the software. Aux out 7 is used to turn on main efi relay in this car.
    We are doing some cool things on this car. Turbo speed can be wired straight in to the ECU as a hall effect. Re-purposing VSS4(vehicle speed sensor) input, we are able to scan incredibly high frequencies and do simple calculations on them in the ECU to output turbo speed. This will later be used to dynamically check boost against turbo speed for compressor efficiency as a calculation within the ECU and for logging. Here you can see the logic change involved. This change had to be done in advanced view, as it is somewhat of a hack to the standard ecu firmware, simple never the less.
    Another cool thing is oil pressure and fuel pressure. Using sensors mounted in the rail and the filter housing, pressures will be monitored and checked against a expected value for any given RPM or MAP and flash CEL or initiate fuel cut if out of tolerance. Fuel will be done by using a measured base fuel pressure and subtracting MAP from it. so if we say there is 270kPa of fuel pressure and we are 30 kPa on the MAP (70 kPa vacuum) then the fuel pressure should be 200kPa. This assumes a 1:1 fuel pressure regulator. If this doesn't work we can always do a log of fuel pressure and just use a 2D table to compare with. Oil pressure will be a 2D table of RPM vs pressure, and compared to actual pressure. A banjo bold was skillfully machined to fit a 1/8th sensor.
    As always, triggering is very important and although this is a very well documented trigger system, I thought I would run through the motions of setting up triggering with an unknown CAS for demonstration. Using a scope, we can see the top wave as the crank wheel and the bottom wave as the cam reset wheel. The crank has many teeth and is used for high resolution fuel and timing triggering as the motor spins. The cam reset wheel is to tell the ECU that the engine is at TDC as a reset/refresh of the engine rotation counting. The bottom wheel alone, with no missing teeth, isn't helpful to the ECU without a reset pulse which the cam provides. Fun fact about the 1280 is that it has an internal scope on all calculations and IO. This is very handy as it lets you see engine angle count up while watching ignition, inject and CAS events. It's interesting to note the waveform rises first then sharply falls. If polarity was incorrect on the sensor, it would fall first then rise sharply. I wire in a rush and get this wrong seeming more than random chance would allow. My scope pic followed by the adaptronic internal scope and ignition/inj events.
    This car is now running and after tomorrows road tune we will head to the dyno for a power run.
    i need more letters
    May 2010
    Melb
    343
    Awesome. Very informative.
    24,196
    So much nerd. well done.
    8,258
    Cheers, mate, the way you sorted shit out on mine was awesome. Great to see in this level of detail.
    DJ's don't need sigs
    Living The Dream
    7,222
    2 789's, bastard..... I want one of those, struggling to justify it though.
    Nice setup and rather informative.
    9,034
    I popped in during this install. I can confirm dr who and Star Trek were playing on the tv whilst Jason watched the owner work
    Mar 2006
    Not Mt Druitt
    1,130
    Very cool, and relevant to my current interest!
    Opposed to the PFAD Bill
    Feb 2005
    9,317
    Start a blog. Nekminnet: #tunedbybuthurts
    Wrong.
    6,931
    Should really get you to spend a few hours fine tuning ute on street with me for super economy. Love it
    Mar 2011
    Quindanning WA
    436
    Great write up... Have been interested in the adaptronics for a while so keen to see more.
    2,784
    Appreciate the insight.
    Love the turbo speed measurement!!
    5,627
    great write up!
    Jul 2009
    Inner Westside/Sydney
    1,177
    No Haltech, no care.
    So keen to actually do something with my project.
    Sunshine Coast, Qld.
    7,564
    Needs more Ethrottle.
    6,244
    JZ are my bread and butter lately it seems How is yours going?
    Quote Originally Posted by The Pupat View Post
    One for simulation and one for verification
    It hasn't been the same without David Tennant
    Quote Originally Posted by rolin7 View Post
    Shutup and update build thread
    Nekbeardminnet. I could get some stickers made.
    Bring it around already.
    Monday coming is a haltech FJ20 DR30 FWIW
    If it were up to me
    7,564
    Is the scope a requirement to set a trigger pattern?
    6,244
    Not at all. Just like most ECU's, you just select your motor from a list.
    If your motor it isn't in the list(unlikely it wouldn't be), you can use the scope to obtain the settings to put in the ECU. Similar to if you have added your own toothed wheel setup, just put those settings in and or use the scope to confirm.
    Opens AxGT's Avatar
    Brisso
    1,866
    I have a similar Tektronix TDS2XX scope here - missing a similar number of knobs etc. They just keep trucking
    Dirty Subaru owner
    6,244
    I've been meaning to get on ebay for new knobs... for like years.
    syd
    2,487
    but i like it, keep posting.
    Jun 2007
    Approaching Uranus
    467
    Are you going to put an Adaptronic on your Stagea??
    6,244
    I would really love to!
    It would be very complex to do so however, due to the canbus and controlling the auto. I could run an Adaptronic alongside the stock ECU and get it working in a weekend, but I would love to replace the lot and have it all run from the ECU, perhaps even the auto computer.
    To do so I would have to build a canbus to canbus converter to control the car side canbus requirements, which is something I wouldn't have time to do as it's my daily. On a side note, if done and working I could do a standalone R35 ECU which isn't something that is available readily yet.
    Jul 2006
    1,102
    The stagea auto and throttle do need a touch up in the control department. Find I have to predict my driving a lot more than I'd like to. Having the throttle go when I pressed it or the auto change gears when I tell it (and not a full second or more later) would be magic. Thought about putting a faster solenoid box on the auto but again it's the family daily.
    Having said that it's still my favourite family car I've ever had.
    Jul 2009
    1,177
    Its funny, in 2008 when I was looking at the way Andy set these up on the prototype (admittedly he didn't have the retard safe front side all going then) I was telling everyone how flexible and powerful these would be and all you heard was "jaycar shit mate".
    Registered User MWP's Avatar
    1,689
    So how exactly does the turbo wheel speed measurement help with tuning?
    Im trying to work out how that data would be of any more use than say a pressure sensor on comp outlet.
    Opens AxGT's Avatar
    Brisso
    1,866
    Diagnostic mainly I expect - it would give you an easier way to determine where the turbo sits on its efficiency map during varying loads.
    I think its more a "Thats cool" feature than anything else.
    Dirty Subaru owner
    7,564
    That's because they often failed or in my case the 1280 just didn't work at all. 1280 is punching with the big boys price wise so don't expect it to take over the world. Nissan connector is gayer than aids too.
    6,244
    These are advanced ECU's. Lets not let this run away with technophobia hey lads.
    Turbo speed will be helpful to know when you are wasting your time adding boost, or it is something else restricting power being produced. It's not always a case of add boost until you dont make any more power, as other things can be the cause. This way we can know it isn't the turbo very easily.
    Registered User TimK's Avatar
    Jul 2004
    Brisbane, Australia
    20
    The 1280 looks really neat. I'm running a 440 and can't really fault it. I've fed in oil and fuel pressure and I'm using the engine protection stuff for peace of mind.
    I'd love to have a closer look at a 1280.
    6,244
    Happy to have a chat one day TimK, I'm in Nudgee if you are ever around.
