Page 22 of 23 FirstFirst ... 12181920212223 LastLast
Results 631 to 660 of 689
Thread: ECU Tunes and Installs
  1. #631
    1,873
    Walbro 460. the lines and wiring are both stock, which wouldnt help, but the pressure is jumping around rather than gradually dropping off so i didnt think it would be reaching the limit of flow. could be wrong though..
    Compare the logs showing Fuel pressure and Injector PW
  2. #632
    Mexico
    3,694
    These ones of Jason's are also non-ratcheting. I have a bluepoint set but they don't work as well as these. The machining quality of the dies makes a big difference and while mine are stamped the Engineer ones are machined or EDM or something. Very nice.
  3. #633
    3,527
    anyone got a p/n or link to buy those engineer crimpers?
    good idea, will do
    1988 AW11 9A-GTE - project #1 | 1980 KP60 4K - project #2 | 1994 UZZ31 Soarer 1UZ-FZE - Cruise missile
  4. #634
    Mexico
    3,694
  5. #635
    6,547
    That's the ones!
  6. #636
    3,527
    cheers.
    logs of injector duty on 98 and e85
    98
    e85
    Petrol peaked at 47.9%. E85 peaked at 70.9% The fuel pressure fluctuations start when the injector duty cycle is about 51% on E85, so above the duty cycle seen on 98 octane
    It has been suggested the fuel lines or filter could be blocked/too small etc for the flow. Thoughts? The outlet on the walbro 460 was the same size as the factory feed line so I thought nothing of it at the time
  7. #637
    . crack's Avatar
    BNE
    2,454
    start fuel pump with engine off and gradually increase boost pressure to reg (e.g. with a regulated air compressor supply) to see if the problem repeats itself? not the same flow rate as when engine is running but the same pressure and if the problem repeats itself then you can start experimenting with stuff (e.g. bypass fuel filter, fuel return to bucket, volt meter across fuel pump, listen out for change in fuel pump noise, pinch fuel line and try to feel changes in pressure). i have no idea what the actual cause is sorry.
  8. #638
    1,873
    replace the filter add a second in-tank pump that comes in just over your 110kph cruise RPM
  9. #639
    3,527
    replace filter sure. second pump no - if my 460L/hr pump cant handle 300kw then the pump is broken lol
  10. #640
    3,527
    all good suggestions cheers
  11. #641
    6,547
    What is the purple line? I can't read the legend (too low res)
  12. #642
    3,527
    purple is fuel pressure, as per my previous screenshots. as you can see, on the 98 run it is fairly stable, but on the e85 run it goes nuts in the top end
  13. #643
    6,547
    Have you checked a gauge, Vcc, 0v and signal yet?
    Are the AFR's, torque and power following that trend too?
    That's tripping balls.
  14. #644
    3,527
    Have not gone and checked the signal wiring but I dont think it is the issue as the fuel pressure is stable at all other times
    AFR does seem to go a bit lean on E85. It doesnt jump around like the fuel pressure, it just gets progressively leaner. Torque and power are smooth
    AFR is the red line on these two graphs. First is 98 octane. Second is E85
  15. #645
    Jul 2009
    Inner Westside/Sydney
    1,332
    Does it have a pulsation dampener on it? I'm guessing if you were able to log a decade higher frequency than engine speed you would see clear pulses following injection cycles where as now it is just "smoothed" time sliced aliasing giving you jibberish. Have seen similar with hydraulic solenoid cycling on longwall gear. Although the pump is rated higher flow at that operating pressure the inertia/momentum of the fluid and reg float positon in the system means you can't maintain steady pressure without larger and/or semi elastic lines or an accumulator/pulse damper near the cycling load.
    Several threads about this on rx7 club with guys running big single turbos and 1600-2400cc injectors. I think Andy msy have mentioned it in his fuel reg testing article as well.
  16. #646
    1,873
    460L/hr at what pressure tho?
  17. #647
    Jul 2009
    1,332
    I hate the non bosch suppliers, they only rate pumps at 3 bar half tge time which is useless on ethanol tubo motors.
  18. #648
    3,527
    The same pump is supporting 400kw on my mates engine with 35psi base pressure/30psi boost, so 75 total.
    yeah slides fuel pulsation has been suggested by andy, but he and others wondered at the fact that the pressure doesnt go up, only down.
  19. #649
    Jul 2009
    1,332
    5V rail(s) in ecu/system voltage holds steady?
    Not seeing significantly higher peaks will be a combo of system dynamics and the sampling issue, if the reg is going to a sealed state as you are on the limit of dynamic flow it will probably bounce back a bit or float up with reestablished flow with injector (s) shutting from a seated position from the pressure drop so the "high" cycle is mechanically clipped by the diaphragm bouncing back rather than settling in the seat and stabilising before the positive flow/pressure wave from injector close.
    Probably worth running new pump wiring you could be loosing a fair wack of real flow there heating wires instead of turning the pump.
  20. #650
    gold coast
    1,826
    there is no way you need another pump at 300kw. as stated the 460's should do 400kw worth of e85 without much trouble.
    was going to suggest finding out how much voltage was actually reaching the pump.
    those walbro axial pumps are quite inefficient and their pressure handling falls away big time at lower voltages.
    if you have a pwm speed controller driving it they also surge quite badly at low speeds.
    its the main reason I steered clear of them and went for a Pierburg screw pump.
    Oo___oO
  21. #651
    3,527
    Voltage at pump is a good idea to check I guess. The bulkhead for the pump into the tank is not accessible without removing the tank from the car unfortunately, but I think the connector from the body loom to the tank sits just under the centre console so hopefully it isnt too hard to stick a multi there.
    I wonder how much an F1 style fuel flow sensor costs. Then I could directly check if I have a problem with flow haha
    edit - no PWM control. pump is run at full speed using a jaycar spec relay with some fat wiring from the battery to the terminal in the fusebox, after which it is the stock wiring in the body loom down to the fuel tank and pump
  22. #652
    gold coast
    1,826
    I looked into them a while ago, I was going to install one on the regulator return to the tank and run the fuel pump speed in closed loop to maintain a fixed tank return rate.
    unfortunately as soon as you say ethanol most of them are not suitable. and their un-restrictive flow rate limit isn't amazing.
    Oo___oO
  23. #653
    Nov 2016
    382
    Im going to go with standard wiring from the fuse box being the issue here. According to the above chart, at 25psi boost you would be drawing close to 18 amps. I don't know about Toyota's but with Nissans the first thing we do when running a decent size pump is upgrade the wiring and run a direct feed from the battery all the way to the tank. Even if it isn't your issue, probably a good idea to redo the wiring so its 100% capable of handling the load.
  24. #654
    6,547
    I don't do a lot of mechanical work, because it's usually quite menial, but when it is so closely related to the configuration and setup of the engine management I sometimes make exceptions.
    Enter Sam's 911 fit with a later model motor complete with an early version of Bosch electronic injection and ignition. The vehicles of the era were plagued with the now known flawed trapdoor design air flow meter, along with not a very smart fuel algorithm.
    This is planned to be remedied with the inclusion of some Jenvey ITB's and a new ECU to control the massively upgraded intake. The first step towards maximum bort, but it involves assembly of the ITB's, with is not a trivial ask.
    The throttle is in 3 pieces. First we bolt the generic throttle to the Porsche head flange. This is done with an O-ring seal between the two Jenvey pieces, and a square O-ring seal to the head. A small amount of medium strength high temp thread lock compound was applied to each bolt for posterity.
    Next, the top of the throttle receives a spacer/bracket plate sandwiched between the throttle body and the trumpet. The top of the throttle has no O-ring groove, nor does the underside of the spacer/bracket plate, so a thin smear of sealant was applied. The trumpet was then bolted down with and identical O-ring seal as the bottom throttle body flange.
    Note sexy uniform squish, and repeat 6 times while being sure you have the right throttle and bracket bolted up (each throttle unique).
    The fuel injectors and fuel rail can be fit. The fuel injectors are simply secured by the fuel rail. Each fuel rail is mounted on 2 cast machined brackets off of the outer two throttles of each bank. This is never easy, but everything fit nicely and lined up first try.
    The throttle body brackets were now populated with a bunch of double ended rose joint links, pivot brackets and linkages. The quality of the kit really stands out here, with everything being tight and superbly bushed or rose jointed.
    Now they are assembled, I think I will replace some of the hex pan head screws with some larger hex versions. I also need to change the size of a washer or two to satisfy my OCD with the OD of items and then a inconsistent step.
    The inlet is out, so I'll upload that process later and start on installation!
  25. #655
    9,432
    Nice one. I bet they weren't cheap.
    Shame they ran out of cash for injectors.
  26. #656
    4,887
    They weren’t but the quality is worth it, some people have made kits from triumph throttles but i’d rather this.
  27. #657
    Founder Nick's Avatar
    New New Zealand
    4,556
    What regulator does it have? There is a good bit more on E85 of fuel pressure. Regulator maybe failing? Hence pressure dropping. Acting like a water hammer. Just a thought.
  28. #658
    3,527
    i have a brand new turbosmart FPR800 v2. water hammer is quite likely which is why i just recently bought a radium engineering inline fuel pressure damper will let you all know if it fixes the issue
  29. #659
    6,547
    Did you pull the OEM damper off the rail?
  30. #660
    3,527
    20v 4A's don't have dampers, and I am using a custom top feed rail anyway. so no damper
