Page 14 of 16 FirstFirst ... 410111213141516 LastLast
Results 391 to 420 of 458
Thread: CNC machining
  1. #391
    BLING BLING PLAYA's Avatar
    adelaide
    6,274
    Quote Originally Posted by Kris View Post
    Ben can't do it, tools are booked out for months.
    Is this like a business thing or for you personally
    3D scanning
    3D modelling
    Structural certification
    3 and 5 axis milling
  2. #392
    V4 Goodness Kris's Avatar
    Feb 2003
    Earth
    1,851
    For me personally. Remaking a damaged part on my bike
  3. #393
    Sep 2004
    1,267
    Making something to hold it and probably a couple of set-ups for a onesie project, won't make it cheap, unobtanium team piece I assume?
    Could try Wayne, if you want to make a trek out to the badlands again, to see if he has any interest and what he'd charge 4587-9733.
  4. #394
    9,461
Size:  33.5 KBGuys, I donít know a lot about much. If a drawing was supplied, could this be Cnc cut?
    Iíd be looking to make approx 50. Itís a helical gear for a distributor
  5. #395
    Chopped BigMuz's Avatar
    12,588
    Pretty specialised tooling or an old guy who knows his shit with a powered indexing head. It's a big ask, try to buy one as a spare part from holley or someone.
    Retard Honour Wall.
    Rob Sloth Young did i ask for your opinion? no. i only want it for a paddock bomb. go play with traffic.
    you stupid fucken imbicle.
    your are a fucken idiot of the highest level.
  6. #396
    adelaide
    6,274
    Yea but gear cutting is a bit special anyway, 5 axis can do it but that is not how the pros do it, they use more specialised machines, sometimes they are hobbed or ground or machined.
    3D scanning
    3D modelling
  7. #397
    9,461
    So not straight forward? Thanks for the insight guys
  8. #398
    Ease Up Turbo Commotion's Avatar
    Apr 2010
    Bogan City
    842
    I had ABCO in Archerfield cut me some pinions on their cnc gear and get it heat treated for me. There was 8 of them tho, not many companies will undertake a one off.
  9. #399
    Registered User John's Avatar
    2,203
    We mill gears, it's common enough on special stuff, and where the ends justify the high cost versus traditional gear manufacturing methods of hobbing, shaping, skiving, and grinding.
    There are a few options for you for 50off; if it's a standard module, you could get them hobbed at quite low cost and this is where I'd start. Milling them is going to be expensive. As muz said, an old guy in a shed might be an option, or if you go to a modern workshop with better gear (although you only need 4 axis, not 5) you'll be needing to provide them a model of it, and that might be tricky for you if you are reverse engineering something.
    Another option, although probably getting a bit upmarket is to find someone with gear generating capabilities on a lathe. I know Holinger have Okuma's that can do this, there are probably others also. This would be a good way to go because they can be made in one hit, and 50off they might even be interested.
    "What in the gay caped fuck is that?" by Shonky
  10. #400
    12,588
    Just measuring it is a big deal unfortunately, it's not a straight forward thing to make. Find something else that uses the same or similar gear is my genuine suggestion.
    Retard Honour Wall.
  11. #401
    9,461
    I basically want to copy that Nissan gear but extend the shaft and change the bore diameter.
    Iíve have a good look and I canít find a Ďoff the shelfí option
  12. #402
    adelaide
    6,274
    Quote Originally Posted by John View Post
    Modelling gears is not that hard, there are plug ins to Solidworks that do this, from what I have been told this is how most of the gear guys are doing in. I know a guy who was involved in making a lambo gearset for an Aus company. Anyway the plug in is like only 1000 or something so not that out there.
    3D scanning
    3D modelling
  13. #403
    2,203
    um yeah modelling is not the tricky bit, knowing what parameters to put in however....
  14. #404
    Jan 2016
    300,103
    If you are copying the Nissan gear, could you not just send a sample to somewhere like Gearco or Ronson Gears and ask them to quote for 50 off? Include a drawing showing all your other requirements without the gear detail if this is unknown. They will be able to measure the gear to machine it.
    No idea who to recommend in Brisbane though.
  15. #405
    220
    Quote Originally Posted by tim510 View Post
    Call Hardman Bros. in Vic and have a quick chat about what it might cost you. could definitely make it, cost I donít know.
    http://www.hardmanbros.com.au/
  16. #406
    Feb 2003
    Earth
    1,851
    Quote Originally Posted by gxxr View Post
    Wayne... ? Yep, unobtanium
  17. #407
    Sep 2004
    1,267
    This one's out at South Windsor....so not quite as far as before! Sort of recall he mentioned he had a waterjet last time I spoke to him - which was quite a while back - basic shape cut out and the features added manually might be another way perhaps?
  18. #408
    9,461
    called and emailing them for a guestimation of cost. if under $100 ea the project is viable.
  19. #409
    Feb 2003
    Earth
    1,851
    haha roger! That said Brian @ Glossodia is a legend - guru! He's made me some very nice items, including a titanium steering stem. I just wanted something a bit swifter this time around
  20. #410
    Registered User tc josh's Avatar
    435
    Designed by Playa machined by me, SR20 flex plate. Terrible quality pics I know
Size:  63.6 KBClick image for larger version.
ID:	105373Name:  flex3.jpg
  21. #411
    435
    Have also over the past few months been doing a lot of the machining of the main bodies of the arms for Acostal https://www.facebook.com/acostaldev/ Some pretty cool kit if your in to drifting nissans.
Size:  91.4 KBClick image for larger version.
  22. #412
    12,588
    Awesome work man, wow.
    Retard Honour Wall.
  23. #413
    9,461
    Hardman Bros got back to me. $30-$40 per unit depending on exact QTY. its go time!
  24. #414
    16,382
    Nice!
  25. #415
    Apr 2010
    Bogan City
    842
    Press is finally up and running. Still a sh!t fight over tooling. What was quoted and invoiced was not what was supplied. Two of the vee dies are now damaged. One damaged on arrival the other damaged by the installers during setup. A replacement was air freighted Over and should be arriving tomorrow. But the combination of dies still doesnít allow us to press all the drawings we sent to them on day one.
    I did get half a days training so that in combination with reading the manual has allowed me to press a couple parts to get us out of trouble. Did a couple parts this morning which involved bumping to form a larger radius. Chewed through a few bits of scrap until I had it dialed. Hopefully Will have some more training soon after the new tool arrives.
  26. #416
    1,244
    F! When your press has an access ladder with safety cage on the side to reach the top, you know its probably large enough.
  27. #417
    17,400
    I'm im-pressed.
    Sent from my Pixel 2 XL using Tapatalk
  28. #418
    17,400
    holy ass -
  29. #419
    Apr 2008
    527
    anyone around Sydney that can do some surface grinding of a part?
    its a small 50 mm x 40 mm x 3.45 mm hardened steel plate that needs to be ground down to 3.30 mm.
    i was thinking a linisher would work then hand lapping but probably wont retain the required precision (parallelism)
    E30 325is M20 3.1L
  30. #420
    435
    send it to me in Adelaide and I'll do it for nothing (we are predominately a grinding shop) just including a paid envelop or bag so I can send it back.
