Page 4 of 16 FirstFirst 1234567814 ... LastLast
Results 91 to 120 of 458
Thread: CNC machining
    BLING BLING PLAYA's Avatar
    adelaide
    6,261
    Must be why ppl tell me stick to Mitsubishi or fanuc controllers.
    Registered User tc josh's Avatar
    435
    If i never see another fanuc controller in my life, ill be a happy man.
    Registered User brypar's Avatar
    Mar 2015
    146
    Managed to get some fasteners today so I could get this job sent out.
ID:	84504   Click image for larger version.
ID:	84505   Click image for larger version.
ID:	84506   Click image for larger version.
    Meh
    Jan 1970
    26,940
    Veeeery nice.
    Mar 2015
    146
    Thanks Bill.
    Apr 2010
    Bogan City
    841
    What do u guys coat a steel component in when finished to stop it from rusting?
    adelaide
    6,261
    For how long?
    Just the coolant is good for a while, if it's heaps long I have this grease spray tectyl or something.
    Meh
    Jan 1970
    26,940
    Got this in my FacePalm feed. Pretty small but it'd be handy for some small jobs.
    A five-axis mill.
    https://www.kickstarter.com/projects...for-your-deskt
    435
    Quote Originally Posted by Commotion View Post
    Oil based coolant will leave a film which will stop it rusting for maybe a week (at my work anyway, we have lots of coolant in the air from the grinders which doesnt help) . Other then that rustilo is what you want, we just use some generic brand of it which does the job
    435
    A five-axis mill.
    Pretty cool toy
    Oct 2005
    adelaide
    418
    Some parts that i machined up at my last job, everything was done on a CNC lathe with live tooling. most parts where for plastic injection mould tooling, so attention to surface finishes and real tigh tolerances on part sizes
    Aug 2011
    21
    nice okuma there does it have a y axis as well
    Oct 2005
    adelaide
    418
    Quote Originally Posted by Africa View Post
    You know your okuma's. Loved the IGA one step and 2 step programming. No Y axis, it would have been handy those particular times it was needed, but we just done that operation on a machining centre.
    Aug 2011
    21
    yep its a great machine i have a LMY300 the y axis was the best 35,000 i have spent opens up machining options heaps will have to post up some of my projects
    Apr 2010
    Bogan City
    841
    Quote Originally Posted by tc josh View Post
    Cheers,
    Just grabbed a 20L drum. Not cheap but if it does what they say it should be worth it.
    16,340
    Ha!
    There's still quite a bit of old shit out there no self respecting shop would consider if you keep an eye out. Was offered an old Aussie vmc a couple of years back, as long as it was removed, for zilch, toolchanges were glacial and rapids sun-dial territory and control that was probably lucky to reach double digit production numbers.
    I'd be completely fine with that sort of speed:cost ratio!
    1,258
    Not quite the same PE ratio, but he'd probably accept a reasonable offer. A guy on the northern beaches here was offering one of these toolroom mills for several years, which he probably still has, if you're keen for obsolete controls (grundig?) and could cough up for transport
    he was using it for surgical implants. From memory, poor man's 4th - universal table - you're the toolchanger and the enclosure is/was removed, so you wouldn't rust.....just get dermatitis!
    Apr 2010
    Bogan City
    841
    Had an interesting day yesterday. Air blast copper tube got jammed in the spindle during tool change so powered it down. Needless to say the old boy wasn't thrilled about spending an hour to reset the tool change mech. Anyways get that sorted then it throws errors saying spindle not indexing so won't complete a tool change. Do some investigating and spindle only has 30 deg rotation before hitting a mechanical stop. Gear changes okay so pull gearbox covers off and inspect. I found there was a 2 piece collar with a gear for the encoder on the main spindle shaft which was sitting about 40mm higher than it was supposed to be and the cap screws holding the 2 piece collar was fouling on the encoder gear. I figure that's weird something should be holding that collar to the shaft so look in the parts book and there is supposed to be a plate with 2 cap screws holding it on. Pull the encoder out and pull the collar apart and find the said cap screws were missing. Find some m6 x 15 cap screws and reassembled it all. Got it all up and running again but have no idea how it moved up or how long it's been like that. There were witness marks on the shaft from the encoder gear so it may have been like that for a while. Was thinking fark, lucky it did it during a tool change and not during milling.
    Apr 2010
    Bogan City
    841
    Edit: dunno why the stupid attachment manager thing got the image on its side
    16,340
    How big do you reckon it is?
    All academic really - I've got no 3 phase, 6ft ceiling limitation where I'd need to put it, and no cash to buy or transport...
    1,258
    Probably 8' to the top of the head hydraulics, no travelling column though. To ensure a reasonable electronics supply, you'd probably have to buy a second one too!
    16,340
    If the electronics took a dump I'd rebuild it with kit controllers - Know a guy in the UK who's done this a couple of times now...
    Mar 2015
    146
    The next iteration of this caliper will be the final design what will be released to the market.
    The full range will be ready in 4-5 weeks
ID:	84969   Click image for larger version.
    Meh
    Jan 1970
    26,940
    FARKEN Niiiice!!
    Mar 2015
    146
    FARKEN Niiiice!!
    Thanks Bill. Would look great on an old school Cortina 😉
    Meh
    Jan 1970
    26,940
    Conveniently, I just happen to have one.
    10,741
    These would also look good on the front of an xw
    Apr 2003
    449
    PF Price????
    Mar 2015
    146
    It has been a couple of months and the BryPar team is happy with the final designs of our brake calipers. There are some minor visual adjustments we will be making. Waiting on some CNC x-over pipes and we are ready for go.
    Input/thoughts on the designs/look would be great...
ID:	88224   Click image for larger version.
ID:	88228   Click image for larger version.
ID:	88227   Click image for larger version.
ID:	88226   Click image for larger version.
ID:	88225   Click image for larger version.
ID:	88230   Click image for larger version.
ID:	88229   Click image for larger version.
ID:	88232   Click image for larger version.
    Meh
    Jan 1970
    26,940
    Farken gorgeous!!!
