Results 1 to 30 of 42
Thread: School me on nutserts/rivnuts
    VIC
    971
    Morning gents,
    Looking at getting an el-cheapo set of nutserts/rivnuts like the one in the link - http://www.ebay.com.au/itm/515-PIECE...item1c24be2f32
    Unfortunately not baller enough and wont be using these things enough to justify buying the expensive ones. Basically want to use a few of these to hold down my fuel pump bracket, surge tank, battery box etc to my boot floor. Is there any reason why I shouldn't do this? Ie are they just more of a screw something light like fibreglass gaurds sorta use, or can they actually be used for something that can kill you if it comes loose and falls over [ie fuel pouring on battery because the surge tank fell over]
    Cheers,
    Rdynos cousin.
    Meh
    Jan 1970
    26,940
    Looks like a very good kit for the price.
    They can be used in a lot of different areas. The problem occurs when the nutsert starts to loosen and then spin in the parent panel ..... that's a pain.
    15,795
    M8 steel is going to be a cunt to set with that style of tool.
    M10 steel - don't even think about it with that tool.
    If they come loose, insert the tool and re-set it - but if you're worried about it ever spinning, smear some epoxy around the insert before you insert it and set it.
    Warwick
    15,134
    Yeh, M6 steel is the limit with that kit. Once you get a kit you'll wonder how you did without one, very handy.
    ― Jim C. Hines
    ― Daniel Patrick Moynihan
    ― Napoleon Bonaparte
    940
    Awesome for fixing chewed out holes in sheet metal which only had a screw in them from the factory.
    VIC
    971
    Is the nutsert loosening a result of the sheet metal its in opening up, or the flare itself losing its grip? Judging by gammas response im guessing the flare is the issue?
    Im not really worried about it spinning, just worried about it [either the sheet metal its inserted in, or the nutserts flare] failing and as a result having 2.5L of fuel in a metal tin ready to top over the next time I go around a corner. Smear of JB weld would do the trick right?
    As for the tool, what other alternatives are there?
    Thanks for the replies gents.
    3,207
    generally speaking you dont want heavy shit hanging off them no
    VIC
    971
    Was thinking along the lines of using the steel M6 insert x6 to hold down a 2.5L surge tank - say 3.5kg all up? Sheet metal its being inserted into is 3mm. The other option was to bend up an alloy platform out of 5mm and bolt that to the floor using the bigger rivnuts then bolt the surge tank to that.
    It might be a Gemini but im trying to move away from the more traditional building techniques [bog and tech screws ]
    5,896
    I hang 6mm armour plate off rivnuts, has passed full vehicle certification (250 rounds into the vehicle) without a single plate falling off.
    15,795
    Probably overkill - but would probably be ok with 6 alloy ones - you'd be using them for the hold-down straps i guess?
    The issue with them spinning tends to be the alloy ones being a bit soft (limits the clamping force available before yield), or the steel ones not being set hard enough - this is where the big fuckoff double handed ones are excellent. At a pinch you can use the nut/bolt/washer technique to pull them a bit tighter (thread a nut, then a greased washer onto appropriate bolt. thread bolt all the way into the insert. Try to wind nut off the end of the bolt, the washer protects the nutsert.)
    Sep 2012
    861
    that will be ok. That tool will do 6mm steel all day long, i probably did about 50 x 8mm steel with mine before it died, so best to avoid 8 mm but the odd one would be ok if youre desprate.
    Edit beaten
    5,896
    Sheet metal its being inserted into is 3mm. ]
    the maximum grip range of those m6 rivnuts is 3.5mm, should be ok.
    Brobdingnagian Member Mighty Mouse's Avatar
    croc country
    2,374
    does anyone do UNF/UNC nutserts? a quick ebay search tells me no?
    1,309
    OK, you've sold me. I just bought the one linked.
    I've been holding out for two years asking for one for Father's Day/Chrissy/bday to no avail because no-one in my family can get their shit together two weeks in advance.
    So I also ordered these safety wire pliers: http://www.ebay.com.au/itm/271855123417
    syd
    2,663
    i have the one in the OP and it does the job, i dont use it to mount anything heavy as mentioned.
    3,207
    Quote Originally Posted by Don Mega View Post
    I'm guessing that they aren't 5cent alloy rivnuts off ebay though?
    15,795
    Those alloy ones are great for holding small shit on, but they're a fucking long way from being structural!
    428
    I used quite a few building my race car, all steel ones, and then just put a very small tig tack on the ones that I wanted to torque a bit more than might be considered normal.
    Radical SR3
    HSV R8
    Jan 2008
    Bris
    1,085
    Quote Originally Posted by Passion-Fingers View Post
    I buy them from my local bolt shop. Mandrels are a bit harder to find though..
    VIC
    971
    Genuine thanks for the advice/help guys, will be acquiring one of these shortly.
    Cheers
    Nick
    New Zealand bro Dave's Avatar
    Dec 2004
    Powernats
    5,849
    So easy to rip the threads out though in the small sizes. I generally use steel ones on everything now.
    Aug 2011
    21
    to help stop the rivet nuts spinning i get a small triangle file and file a small nick in the hole before you pull it in there just helps them to bite in a bit better
    5,896
    Quote Originally Posted by Africa View Post
    Use a shit drill bit that leaves a nice burr on the backside of the hole also works.
    4,051
    Yeap, tight shitty drill bit ftw
    If you have to smack the back of the tool to get them in you have done it right.
    and if you want to be a sick cunt to a future owner who wants to remove shit, do the bolts up with 277 ft spec, nothing fucks your day like a spinning rivnut lol
    5,786
    ...nothing fucks your day like a spinning rivnut lol
    lol? It's no laughing matter... many headfucks thanks spinning rivnuts...
    4,051
    If its a blind cavity your fucked, just hope you can cut the head off and go for an oversize bolt.
    I find it best not to mention that there will be a rattle for the rest of eternity lol
    5,786
    Had a few spin, blind ones at that, they were in thin-ish ally and I ended up yanking them out with some vice grips, left a fucking big hole though....
    4,051
    Total fucking nightmare, I had a crack at removing one but after die grinding and slide hammering the fucking thing out the mushroomed and warped sheet metal quickly taught me that they grind and punch in a lot easier.
    5,786
    Fucken rusted bolt shit cunt fuckers, holding glass-fibre reinforced plastic aero panels in place.
    £200 plastic undertray, destroyed because of 20p worth of rivnut, and 50p stud and nut.
    15,795
    Big dollop of sikaflex will fix that.
