Page 2 of 2 FirstFirst 12
Results 31 to 42 of 42
Thread: School me on nutserts/rivnuts
    8,471
    I used 6 x M8 alloy inserts for my old fuel system using the Trade Tools cheapy rivnut gun.
ID:	85061   Click image for larger version.
ID:	85062   Click image for larger version.
    May 2004
    5,120
    trade tools rivet gun is pretty good for the price too. Anything under M6 it works well for. Honestly, if you guys are using anything larger and/or using stainless nutserts, really should either look at one of the air operated guns or at the least the one that can run in the end of a drill. Air ones will laugh at m10 stainless ones all day.
    12,826
    Thread bump!
    Hows everyones rivnut guns going? Going to need one for a few little jobs soonish. Would like to be able to do M8 steel nuts if possible, and be able to get into tightish spot would be a bonus.
    Trade tools air guns still the go?
    Toowoomba
    1,241
    I got the Dafra ratcheting one, it goes up to M10 though I haven't tried it past M8 yet.
    https://dafra.com.au/product/drt512nm/
    2,408
    I have this one, only have alloy nutserts for it so far but it seems good. My little 12v drill can just insert an alloy 10mm nutsert.
    http://www.gasweld.com.au/nutsert-at...drivers-511617
    VIC
    1,060
    Holy fuck that looks nice as. Hows it work? Hold one handle and ratchet the other until tension on upper handle says your done? One for the cordless ratchet looks interesting as well.
    Mines a cheapy but does ok, none of them have come loose yet, for eg im using 4x M8 inserts to hold the battery tray down in the Gemini. Done around 15k so far and battery is still where its supposed to be.
    Sep 2012
    Else Where
    461
    Got one at work bloody brilliant tool
    Melbourne - Vic - Aus
    1,076
    http://www.ebay.com.au/itm/1064-Piec...QAAOSwKtVWw9cB
    I have this one. Works well enough and haven't had one fail yet.
    Toowoomba
    1,241
    Yeh just hold one handle still and ratchet the other. You can feel the resistance increase when it's done.
    Registered User MZ21's Avatar
    Sydney, NSW, Australia
    6,531
    Thread bump
    I want to get some rivnuts on fibreglass, to attach some stainless sheeting to it. Last time I tried this the fibre glass crumbled, so I used jacknuts. While jacknuts are ok you can torque up the fastener as much with a rivnut.
    So what the best approach? maybe put a washer on the other side to give the rivnut something to grab on and spread the force over?
    May 2004
    5,120
    longest nuts you can find with a knurled shank + epoxy. Even with a washer they tend to turn in the fibreglass, especially as soon as someone overtightens one (then you're well fucked because you can't remove it, you have to drill it all out).
    6,531
    OK, Maybe back to plan B, just use regular locknuts with aluminium back plate (strip) that runs across the width of the sheet. Top, middle and bottom. That should stop the nut lock nuts from digging in from over tightening as well.
