Page 2 of 43 FirstFirst 12345612 ... LastLast
Results 31 to 60 of 1274
Thread: Car questions that don't deserve a thread.
    Aug 2008
    2,252
    Quote Originally Posted by Fraud View Post
    Wouldn't disconnecting the line going to the stock BOV be a good start? Probably then just an open air filter away from needing a penis haircut.
    Question that doesn't deserve its own thread, mostly because actually buying another car is a very hypothetical situation at this point:
    What is the deal with NCOP/emissions etc. etc. on old engines that predate stringent emission rules etc.?
    EG. if I had a BBC from the late 60's, could I swap to aftermarket heads, bore it out one or two standard oversizes, bump compression, put a stupid cam in it add injection and not have to worry about engineering/emissions testing as long as I leave the standard charcoal canister in place? I'm guessing if there was a considerable capacity change (ie. stroking a 454 to 496) then thats a different story, but otherwise?
    >20% power or capacity increase require LA3 cert. The general rule is that the vehicle has to maintain compliance with the ADR's it was built to comply with (if any).
    Newcastle
    11,096
    I don't have a clothes hanger in my Hilux for my Hi-vis vest. Should I fit one or is the wrinkled look in this year?
    The Crime Zone
    30,982
    Uncle, you can get high-vis vests from the Big & Tall shop made out of that stuff which doesn't need ironing.
    Save yourself a heap of ironing time each Sunday night, too.
    Quote Originally Posted by Streety View Post
    Where does my key go?
    Under which circumstances is it disappearing?
    Are you sitting down when it disappears, then it appears again when you stand?
    Have you tried turning it off and on?
    10,304
    Quote Originally Posted by Deceiver View Post
    How can I make nopics' car make pigeon noises with a stock BOV?
    15,070
    Quote Originally Posted by Shitbreak View Post
    Ok, uber noob question.
    Car Speaker is rated at 30W RMS (45W Peak). It will be crossed separately with a tweeter rated at 50W. Both 4Ohm (crossed in parallel). Will an amp with a 50W channel be ok to power both (so long as I don't ramp up the volume)?
    Ok, so a related question. From my understanding of the above scenario, each device will get half of the rated channel power (25W each) which is under driving the components somewhat. Is this going to be shit?
    Would I be better off finding speakers that are rated more closer to the 25W power (assuming I don't want to replace the amp)?
    Quote Originally Posted by XXX19X View Post
    The Crime Zone
    30,982
    If your speakers are rated at 30W, putting 25W through them is about the best power-matching you'll get.
    733
    No. having them in parallel presents the amp with a 2Ohm load, means it can push twice the current, meaning power output is doubled. each speaker still gets 50W (ideal, not accounting losses, amp can run 2Ohm load etc. etc.).
    Anyway, it's kind of a useless point.
    overpowering speakers is LESS likely to cause damage than underpowering them.
    as the speaker moves it pumps air through the voice coil, meaning it's cooling itself. Extra power isn't so bad. (not saying you can't overpower a speaker)
    Now if underpowered, and you're pushing it hard to get the volume you want, you risk clipping, when clipping the amp is essentially a DC power source and the speaker isn't moving = no air flow = no cooling = cooks the voice coil = dead speaker.
    GT-P
    Bandsenkowagon
    733
    fwiw,
    I've got 145WRMS amp channels powering my tweeters rated at 50W, 145WRMS powering some midranges rated at 60W, and 445WRMS powering midbass rated at 70W. cranks hard and no damage.
    when playing music, the actual power over any period of time is pretty low (average). so the speakers can handle extra power happily - and love it cause there's plenty of power to move the cones accurately.
    DC voltage (clipping) is high average power, and what will cook them.
    GT-P
    Bandsenkowagon
    938
    So, having trouble with 8 down. 'Late wisdom utilised by rifleman? (9)'. Ideas?
    15,070
    data_mine, thanks for that info mate. Helpful.
    6,445
    What's important with amps & speakers is headroom. Headroom is where you have a big fuck off amp that's so powerful you never have to crank it past half way to get the volume you need. The less you crank it, the less distortion you get because amplifiers have an inherent distortion that increase with gain. The by keeping the gain low the less noise you get as well. Have you ever turned up a stereo to max but had nothing playing? The hiss, the noise. It's there even if no signal is running through the amp. Low gain, means low noise. Some distortion is good, it makes a system sound "warm" but too much distortion just sounds like, distortion. Same for the noise. By oversizing, but under-utilising your amplifier, you will have less distortion, less noise. Say for example a 1000W amp driving a 500W speaker it's good, just keep the gain down low. You get less noise & less distortion. /rdyno
    15,070
    Ah gotcha. That goes against my initial (and obviously misguided) thinking. Cheers.
    6,445
    Another way to look at it... if you have a 500W amp and you crank it to 11 so it's putting out 500W, the output will be noisy and distorted, clipping like fuck. This will kill your 500W speaker in no time. You have a 1000W amp and your crank it to a 500W output, the signal will much much cleaner and with less distortion. So although both scenarios are 500W going into a 500W speaker, the end result is very different.
    Jul 2002
    Brisbane Aust
    1,731
    data_mine is right about the voice coil results from clipping, but not why. DC through a coil turns the whole coil into a heater element. It isnt just because the voicecoil isnt moving.
    It is also super easy to limit the power output from an amp to your speakers. Its called a multimeter. Use ohms law. set your headunit to the max voltage you use (may not be full max, often head units distort and clip before max), now set your meter to AC voltage, and without a speaker connected - up the gain on the amp to suit. https://www.youtube.com/watch?v=gg2gl-fz2Qc
    "And I know that arseholes grow on trees but I'm here to trim the leaves" Peeping Tom, Mike Patton
    teh 20B can nevah lose hostile's Avatar
    redfern oval
    792
    Quote Originally Posted by Disgruntled please View Post
    Hindsight?
    Spending money on cars Neeek's Avatar
    Aug 2013
    1,024
    Quote Originally Posted by hostile View Post
    Hindsight?
    8,339
    Hi Pf Guru's.
    I was after some coolant for my 1948 HQ Falcon and the guy at Super-repco told me they only have Green or Red Coolant but my car is Blue.
    What should i do??
    Thanks in advance. Forg.
    Problem? sssgtr's Avatar
    on a boat motherfucker
    4,364
    You forgot to mention something about gerly trucks.
    8,339
    Oh fuck. I have much to learn about PF's king of Dad Jokes.
    Registered User Imposter Forg's Avatar
    Jun 2010
    France
    4,271
    Quote Originally Posted by pH@tTm@N View Post
    i should know this but...
    internal DAC's in headunits
    if you're using line out on a headunit, are you bypassing the internal amp, and if so, do you still get distortion/clipping when you have it cranked?
    Jul 2002
    Brisbane Aust
    1,731
    Quote Originally Posted by Cameron, Brisbane City's friendly local drug dealer View Post
    Yeah you can. There is still a 'line driver' circuit to feed the RCA out. It hopefully wont be anywhere as significant as the internal amp.
    15,070
    Ok, again demonstrating my car audio noobness, but I was initially looking at installing a 4 channel amp to power my speaker setup. But would it be just as good if I were to get 2 x 2-channel amps. One for the rear and one for the front speakers (obviously)?
    I'm thinking this will avoid me running new cables and allow me to use my existing speaker cable (and also make for a neater install) and just install thicker cabling for the final run from the two amps to their associated speakers.
    Jun 2010
    France
    4,271
    I don't understand how that setup means less wiring.
    Dismember Stang's Avatar
    8,792
    Long story short, is $4800 excessive for supplying and replacing a broken 6spd auto box on a 2010 Holden Epica?
    6,027
    $4800 is an excessive price to pay for a complete Holden Epica
    If in doubt power out
    12,985
    Quote Originally Posted by Rona View Post
    Zinggg!!
    fkn lol
    Manta Manta GTREA's Avatar
    7,639
    An fittings
    Bottom of radiator for trasmission cooler lines
    10mm - 11mm diameter
    Would that be a size An -10?
    NFI
    yeah, that would be great Matty's Avatar
    1,694
    Quote Originally Posted by data_mine View Post
    No, having a crossover means it's still a 4 ohm load. (assuming decent crossover design)
    From a 50W amp you could be driving the speakers with 50W of bass only, which will all go to the woofer, or 50W of treble only which apart from making your ears bleed will all go through the tweeter. So both speakers should be comfortable with accepting 50W.
    Don't disagree with the rest though, make sure it is a clean signal not a square wave.
    Quote Originally Posted by PJ OíRourke
    Name me, if you can, a better feeling than the one you get when you're half a bottle of Chivas in the bag with a gram of coke up your nose and a teenage lovely pulling off her tube top in the next seat over while you're going a hundred miles an hour down a suburban side street.
    on hoes? yohoes's Avatar
    3,352
    Hahaha
    Block off the BOV
    I keep thinking about doing that to my nopics car
    16,732
    Quote Originally Posted by GTREA View Post
    An fittings
    NFI
    The AN "dash" number is the number of 16ths of an inch the internal diameter is - so -4 is 1/4", -8 is 1/2", -12 is 3/4"... so ~10mm is -6
